Show me your shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by Oscar 319, Aug 28, 2008.
  1. Jun 15, 2020 at 5:47 AM
    #8221
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I believe mine is about the same exact height as the cab
  2. Jun 15, 2020 at 1:56 PM
    #8222
    Omegaqft
    Omegaqft Member
    2020 Black Tacoma TRD PRO
    Couple of questions for a shell i'm thinking of purchasing. New to the whole truck thing, so bare with me. I have a black 2020 TRD PRO DCSB. I'm debating on either a LEER or ARE, since i dont have snugtop dealer near me. If i plan on putting a rack on later, what type of rack hardware do i purchase or does it come with the shell? I most likely plan on getting a prinsu rack for the cab and shell. Is there anything i'm missing? Any help would be appreciated before i spend a chunk of money on a shell. Thanks.
  3. Jun 15, 2020 at 1:58 PM
    #8223
    joechef
    joechef Well-Known Member
    Joe
    Seattle, WA
    You'll want to make sure the shell has roof tracks. Yakima or THule are the common brands used in a lot of shells, doesn't matter which you get. If you plan on putting on aftermarket racks in the future, the last thing you want to do is get a shell without tracks and get them installed later on. They're super expensive to add-on later and challenging/warranty killing to put them on yourself.
    ready6delta likes this.
  4. Jun 15, 2020 at 4:14 PM
    #8224
    RoughRder
    RoughRder What fresh hell is this?
    Garrett
    Hampton Roads, VA
    2011 DCSB TX TRD
    5100s and OME 885 coils front, 5100s and AAL for the TSB leaf pack (overload left in) rear. Jeraco camper shell.
    I have a Jeraco shell on my 2nd gen. It’s used, like most things on my truck and used to be silver. I outfitted it with a 3rd gen 4Runner rack by running some 1/4” bolts through the top and rewired the interior with LED lights. It recently came back from paint good as new.
    For the 2nd gen, plastic bed rail caps on or off? I read somewhere they had to stay on for strength. I also see so many of you with them off and it looks so good. I also have leaks in the front corners no matter what I do. I’m guessing the leaks could be solved by removing the plastic. Thanks
  5. Jun 15, 2020 at 7:02 PM
    #8225
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    I’m not sure the liquid nails thought would make a difference, unless you’re building a submarine? It will never be fully water proof, since the tail gate isn’t sealed and the topper lid doesn’t exactly seal agains the tailgate either. I’ve have mine for three years with just the foam and there is very little water that ever gets in. I think just a new foam gasket and 6 bolts etc instead of 4 would work?
    I’ve run six of these that slide into bed rail system for about 2 years and they work amazingly well. No bolt holes required.
    I’ve had them on for about 70k miles with several cross country road trips and plenty of washboard roads and proper off-roading. They have held the shell on super tight, no leaks and no movement, through 5 cross country road trips with kayaks on the roof, a gun case full of recovery gear, a box of camping gear and firewood
    just my two cents. The 6 tie down points (bolts or something like what I’ve got) will do you better with a simple foam gasket, no messy sealant needed.
    The middle of a 5000 miles road trip last summer with the kayaks.
  6. Jun 15, 2020 at 7:10 PM
    #8226
    Fab#1
    Fab#1 Well-Known Member
    Joe
    Arizona
    2019 Toyota Tacoma OffRoad
    Pro Grill, Pro Wheels, Roof Rack, PRO Exhaust and ect........
  7. Jun 16, 2020 at 8:52 AM
    #8227
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I wanted a shelf inside the shell but not from the floor. Found this piece of 8020 at work and used a piece of 1/4” thick lexan for a bottom.
  8. Jun 16, 2020 at 9:03 AM
    #8228
    FJ to Taco
    FJ to Taco Well-Known Member
    Tony
    Lacey, Wa
    2015 DCSB 4x4 TRD Off Road,Snugtop Rebel
    Bilstein 5100's all around, OME 885's and OME Dakar CS047R Leaf Packs. Snugtop Rebel, pet screens,front slider drop down window. WeatherTech mats. Interior LEDS
    Snugtop Rebel with pet screens, front slider drop down window. I dig mine and so do the dogs! I just put in a bed rug for the dogs and me so there are no more ridges. Comfortable to sleep on when hunting Sasquatch here in Washington. :)
  9. Jun 16, 2020 at 5:45 PM
    #8229
    trdmikey8
    trdmikey8 Well-Known Member
    2016 Tacoma TRD Sport
    Snugtop Camper Shell
    Got mine installed yesterday. Love the prolock and 2 port usb charger on the rear of the shell.
  10. Jun 23, 2020 at 7:04 PM
    #8230
    smokering
    smokering Active Member
    Tracy
    Longmont, CO
    1996 White 4Runner; 2016 White DCLB TRD OR Premium
    A.R.E. Topper, Ham Radio , TRD Pro 17 wheels
    Yesterday I picked up a nice used commercial A.R.E. shell with windoors and a tool box. Need to add carpet, wire brake light and possibly add sliding window behind cab. Worth the half day of driving and $600.00 price. Plan to use tool box for camping gear. If not, may remove to make a bigger sleeping area.
  11. Jun 24, 2020 at 7:39 PM
    #8231
    dil
    dil Well-Known Member
    Rocklin, CA
    2019 SR5 DCLB V6 4x4
    Stock
    Finally got my shell installed today! I went with the ARE V series with minimal accessories. Shopped all northern CA and southern Oregon but went with the local dealer as prices were all about the same. I’m now part of the club!
    Edit: Ordering took 9 weeks from order to install due to covid
  12. Jun 25, 2020 at 4:20 AM
    #8232
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I added some fishing rod holders to the shelf I made, to get them off the floor of the bed and out of the way.
    mcgov303, Fatback17, Tnc and 9 others like this.
  13. Jun 25, 2020 at 9:51 AM
    #8233
    gnarthirty2
    gnarthirty2 Well-Known Member
    Brandon
    2017 Toyota Tacoma TRD Pro
    Finally had my SnugTop Rebel installed. Sliding windoors on both sides, pro lock and Yakima tracks.
  14. Jun 25, 2020 at 9:58 AM
    #8234
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I was looking at your rod rack and remembered this from the other day.
    I had a similar issue.
    Crawl in there and have a look at the plastic channel the glass slides through. The one on the bottom is likely ruined. If it doesn't look straight but swollen and squiggly, then it needs replacing like mine did. There was enough length on the lower section that I was able to cut off the bad section and use the remaining for the glass to ride on. If there isn't enough left, the upper channel may need to be cut to make it work. I never did find a suitable replacement online but stopped looking after realizing I could use what I had on hand.
    six5crèéd[QUOTED] likes this.
  15. Jun 26, 2020 at 2:26 PM
    #8235
    bnv
    bnv Boy I say, use CRAWL to sneak up on that dawg!
    Bruce
    San Diego
    2016 Access Cab TRD Off Road 4X4 Quick Sand
    Kings adj, TC UCA, Zeon 10s, PB bumper, BD 30" light bar, BD cornering lights, Line-X Grill, Wheels, Tires Duratracs, tint, gate lettering, glove box lettering, ARB compressor
    New SnugTop Hi-Liner.
    I like it.
  16. Jun 28, 2020 at 7:37 AM
    #8236
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    @Omegaqft You may want to consider getting a reinforced shell if u plan on putting a rack or rtt up there. Something like the ARE HD series, that way you can mount a lot of weight uo there and not worry about stress cracks. You’d attach a prinsu with something like yakima tracks (they have like a t slot)
    I got the V series with windoors, windoors are awesome. Spring for interior lights if you can afford it but i went for windoors instead.
    I personally think ARE has a better rear window hinge than leer and looks marginally better.
    Last, when they install it, ask for the rubber gasket, not the foam tape. The guy used foam tape on mine and it was a bad idea.
    One more thing, i see you have a short bed. I do too. But i didnt realize how much better it would be to get a shell if you have a long bed because then it would be worth building a sleeping platform inside.
    If i knew more when buying the truck i probably wouldve got the long bed. And if i knew more when considering a shell for my shortbed i might have gotten a bed rack and rtt instead
  17. Jun 28, 2020 at 11:56 AM
    #8237
    trailbound
    trailbound Well-Known Member
    Rob
    Surprise, AZ
    2016 DCSB TRD OR 4x4
    Century DCU 26" high with factory installed Thule Tracker II. I had them add two 1/8" 6061-T6 plates the length of the shell for structural support to mount the rack.
    20200623_151705.jpg 20200623_154316.jpg 20200623_154340.jpg 20200620_140831.jpg 20200620_140851.jpg
  18. Jun 29, 2020 at 12:04 PM
    #8238
    dixiedog26
    dixiedog26 Well-Known Member
    Jeff
    Tomball, Tx
    2017 Quicksand Sport TRD
    Picked up this Leer used in MGM and had it painted to match. Getting the brake light wired up tomorrow at a Leer dealer, hoping they might be willing to change out the gaskets as well.
    drvn, ready6delta, RoughRder and 4 others like this.
  19. Jun 29, 2020 at 7:28 PM
    #8239
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
  20. Jul 5, 2020 at 9:42 PM
    #8240
    FashTaco
    FashTaco Jungle Asian
    Oregon
    2022 TRD OR 6MT DCSB <- 2018 TRD SPORT 6MT ACLB
    Testing out the new tires and wheels today.
