Show me your shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by Oscar 319, Aug 28, 2008.
  1. Oct 20, 2020 at 7:00 PM
    #8501
    G3Fab
    G3Fab Eric @ G3 Fabrication
    Eric
    Northern Illinois
    '12 TRD Off Road DC
    Got this done a couple weeks ago but haven't had the chance to share it yet. Stainless sides with aluminum cross bars. Worked out fantastic for mounting my awnings, Maxtrax and hauling our RV5 and some other gear the last few weekends.
  2. Oct 20, 2020 at 7:07 PM
    #8502
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    It’s similar but it’s actually unistrut. I wanted the the unistrut instead of t slot alum. 148F2237-20D7-49C6-8190-22F84ECADD25.jpg758F4B01-49E9-47CA-83B5-C3474DAC526E.jpg
    I added tracks on the inside for max strength
  3. Oct 20, 2020 at 7:22 PM
    #8503
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Solid. A heavier setup for sure but with increased durability.
  4. Oct 21, 2020 at 7:54 AM
    #8504
    RubenZ
    RubenZ Well-Known Member
    South Texas
    2020 Cement Tacoma TRD Off-Road DCSB
    Interesting. Have you thought of taking it a step further and mounting some downward supports to connect to the Track System? to support more weight.
  5. Oct 21, 2020 at 8:27 AM
    #8505
    G3Fab
    Eric
    Northern Illinois
    '12 TRD Off Road DC
    I thought about it for a little bit. The cap already has the reinforced roof from Leer as well. If I was putting a large RTT on it I might consider it more but for what I carry up there I don't see it ever being an issue.
    Plus. I am building a flatbed and canopy over the winter. The cap and rack will all end up for sale.
    RubenZ[QUOTED] likes this.
  6. Oct 22, 2020 at 12:46 PM
    #8506
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    Hi All
    I picked up a used Leer 100XR For my 2017 Tacoma - plan is to put the tent on it in the summer with a Sherpa Equipment Rack. Already have bed stiffeners installed from my previous setup.
    I'm struggling to figure out the mounting bolts and how they should properly be placed and torqued. Online I'm seeing photos of Leer bolts that seem to perfectly fall flat with the washer.
    When I tighten mine down, it seems only the edge of bolt head (on the outward size) is catching the washer. Can any confirm if the full head of the washer is supposed to sit flat on the washer?
    I've also heard of the shell shifting... Could one not flip the bolt so the threads come up through the fiberglass and add a nyloc on top? I can't fit the nyloc with the bolt going downwards as it contacts the utility rail.
    Finally, any torque specs for these thing once (or if) I can get it right?
    Thanks
  7. Oct 23, 2020 at 6:14 AM
    #8507
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Post pics and we can tell you if ours looks the same. As far as torque specs, I have none to give but mine are pretty tight but be careful you don't crack your shell snugging them down. They don't need to be super tight for them to do their job.
  8. Oct 23, 2020 at 8:20 AM
    #8508
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    Sounds like you're on the right track. Mine was professionally installed new at a reputable shop. No leaks after a year. I did call them recently and asked if there was a torque spec because I go around and make sure everything is still tight every now and then. They said NO torque spec
  9. Oct 23, 2020 at 12:06 PM
    #8509
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Find a nyloc nut to fit the bolt and run it up snug.
  10. Oct 23, 2020 at 1:14 PM
    #8510
    Rocky.Mtn
    Canada
    The nyloc would contact the utility rail before contacting the Leer mounting metal bracket?
  11. Oct 23, 2020 at 1:24 PM
    #8511
    DiscoYaker
    SE USA and Alaska
    Most likely. Might be able to get it all the way to metal t-bracket but it'll probably marr up the rail. If you really want a nut on the base you can always add a washer and snug it up to the rail itself. I dont think there is a need for it though, mine haven't backed out one bit over the past year. I just double check mine every couple months to make sure all is well. So far so good, no snugging needed
    There is a gap between rail and bolt but not much
  12. Oct 23, 2020 at 2:56 PM
    #8512
    G3Fab
    Eric
    Northern Illinois
    '12 TRD Off Road DC
    Any more info on the mounts you made up? Digging that idea!
  13. Oct 23, 2020 at 7:31 PM
    #8513
    Brake Weight
    You could use a sleeve like from the leaf spring bushings. Space it further down and away from the bed rail.
  14. Oct 26, 2020 at 8:17 PM
    #8514
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    So is this the un-official BS thread? I've got a mess I could use some help unravelling, mostly because I'm at the beginning of this particular path on my truck.
    What I have and what my current goals are:
    • I have a SnugTop Rebel with Yakima Rails already installed
    • Want to eventually run RTT (looking at the GFC SuperLite ~80lbs) but that's down the road some
    • Friend going to be selling me Rhino Rack 270 Awning in the near-er future.
    Problems:
    • Has anyone mounted Rhino Rack roof rails to Yakima roof tracks?
    • Has anyone mounted a Rhino Rack awning (or something similar) to Yakima rails?
    • Has anyone mounted a Rhino Rack awning to a Prinsu Top Rack?
    • I've seen prices for Rhino Rack and Yakima rails all over the place, what is the general price for just two bars and the bits that mount them to the tracks generally run?
    • I don't need nor want to get new tracks since I've already got some installed.
    I was originally wanting to get Prinsu front and rear, but the price has made it very unattractive and I'm not entirely sure I have a need for a rack on the roof of the cab anymore at this point, so I figured bars for the shell would be cheaper and more than enough.
    If I go Yakima rails, then I need to get an adapter for the Rhino Rack awning ($34). The problem is that the adapter states it's for "...your square bar Thule or Yakima racks" and Yakima doesn't have any square bars (?)
    If I go Rhino rails, then I need to get a base adapter kit ($46~) in order for them to work with the Yakima tracks.
    EDIT: I guess writing this out lead me to the solution I needed, but if anyone else could offer their insight, experiences and advice, I'd still appreciate it.
    EDIT2: Weight limits is a concern with just the bars. If I do multiple bars, does the weight limit go up? I'm mostly concerned about when I'm (eventually) sleeping in the tent up there, so dynamic loads won't be as much of an issue when the vehicle is moving. The SnugTop has the Sportsman's upgrade, so it can handle ~600lbs, but the Rhino Rack Vortex bars seem rated for ~220lbs, which isn't a lot when you consider my big fat *** will be up there, and god forbid a lady friend.
  15. Oct 26, 2020 at 10:13 PM
    #8515
    DiscoYaker
    SE USA and Alaska
    I didn't read your whole post but the rails on leer and are ... whether they are Yakima or Thule are interchangeable. I guess what I'm trying to say is that I have a leer shell which came with Thule tracks/rails and I put my Yakima towers and bars (round) in them no problem. They are standardized..... the rails/tracks.
    Hopefully that helps a bit. Ive never heard or dealt with rino racks but I've stacked alot of stuff on my Yakima racks. Id be more worried about the shell failing before the racks. But better to contact a distributor or dealer. And yes Yakima is round, Thule square usually
  16. Oct 27, 2020 at 8:57 AM
    #8516
    Scontroneboy
    Scontroneboy Well-Known Member
    2013 Tacoma
    I had Thule tracks on my fiberglass topper and had both Thule and Yakima feet attached. Have generic tracks now on my stainless steel topper and the Thule feet mounted without issue. Was going to get a Prinsu or similar topper platform and ended up building my own from aluminum extrusion to save money. Spent $300 on all of the parts and another $80 on the Prinsu mounting feet since I don't have the chops to fabricate my own. Have my tent mounted to it and it's solid, I've walked on it and also anchored my hammock from the rails so have no worries about strength or longevity.
    Plus, with the sides of the rack being built from 2x2 extrusion I've got endless mounting possibilities for; my awnings, lights, shovel/axe mounts, etc. Since most of the newer companies use the extrusion all of the accessory mounts from Prinsu, Victory 4x4, Front Runner, etc. will work. As a bonus all of the Thule mounts like the ski/snowboard, kayak and cargo baskets will attach to the 1x2 load bars. Hope that helps...
  17. Oct 27, 2020 at 4:07 PM
    #8517
    Snaeper
    Martin
    Phoenix, AZ
    Do you have any pictures of your set up?
  18. Oct 29, 2020 at 11:50 AM
    #8518
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    I have Rhino Rack rails on my leer. I have Yakima towers and cross bars mounted on them. Does that help a little?
  19. Oct 29, 2020 at 11:58 AM
    #8519
    Scontroneboy
    2013 Tacoma
    I'll send them to your inbox...
    Snaeper[QUOTED] likes this.
  20. Nov 1, 2020 at 11:37 AM
    #8520
    G3Fab
    Eric
    Northern Illinois
    '12 TRD Off Road DC
    I'll be listing my 100XL up for sale later tonight or tomorrow. Just a heads up for anyone interested. The roof rack, MaxTrax mounts, inside cap supports and ARB awnings with the large awning room will all go with it.
