Show me your shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by Oscar 319, Aug 28, 2008.
  1. Nov 10, 2020 at 10:59 AM
    #8541
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    Here is a shot for more perspective for where my brackets are located
    crackils[QUOTED] likes this.
  2. Nov 10, 2020 at 11:06 AM
    #8542
    DiscoYaker
    SE USA and Alaska
    @crackils 8t seems like the biggest difference is that mine are 24 lbs and the other poster are 35lbs
    @markgphoto do you have a frameless back window?
    If guess if Mark has a frameless than the window and hardware are heavier than mine.
    Good luck and like you said you can always return the other
    crackils likes this.
  3. Nov 10, 2020 at 11:41 AM
    #8543
    markgphoto
    markgphoto Well-Known Member
    Mark
    Middle Tennessee
    2020 Tacoma ArmyGreen TRD Pro
    Yes, I have the Leer 100XQ. Frameless back window. Manufacture date was last February.
  4. Nov 10, 2020 at 12:30 PM
    #8544
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
  5. Nov 10, 2020 at 5:40 PM
    #8545
    SandTacoma916
    SandTacoma916 Member
    2016 Sand Trd 4x4
    Anyone Running the ARE Z2 or do they even make them for the Tacoma's?? Thanks!
  6. Nov 10, 2020 at 6:16 PM
    #8546
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    LEER 100R. I like the t-handles on the rear glass. My pup figured out how to open toppers with exposed cables on the frameless rear glass doors. The windoors were supposed to be vented, waiting for the replacements to ship so they can be swapped out.
  7. Nov 10, 2020 at 6:50 PM
    #8547
    DiscoYaker
    SE USA and Alaska
    That's a frameless back window with cables? It looks different from the other frameless/all glass that I've seen.
    Oh damn just re-read your post. Im with you, I'd rather have the t handles as well. Smart pup, good job trying to keep it safe!
    Shell looks awesome
    Same rear window as mine other than the extra lip for your tailgate
    TroutBum[QUOTED] likes this.
  8. Nov 10, 2020 at 7:31 PM
    #8548
    TroutBum
    Michigan
    Leer 100R
    Yup - I’ll gladly sacrifice a few style points to not have the rear window open on its own (after a few winters in the rust belt, the cable system sucks) or if my pup hits the cable.
  9. Nov 11, 2020 at 7:28 AM
    #8549
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    What is that? The rear window and hardware are identical to my old Century as well as the sliding window.
    I replaced mine with some struts from a Jeep, I think it was. The ball ends are likely 10mm and all you need is the extended and retracted lengths. Just like picking shocks really. The weight rating should be on the existing strut and then when you search for a replacement you can kind of gauge what would work best for you. The ones I have now are a little longer actually and stiffer. So it'll pop open pretty easy once it breaks over and it'll swing up higher out of the way. You just need to always close it by grabbing the middle of the door. The pop rivets had already worked loose so I replaced them with some small bolts, m3 or m4 I think it was because it came from my RC stash. The set I bought actually came as a set of four and the shorter struts fit my VW mk4 hood almost perfect. Hood opens maybe 6" lower but being basically free compared to paying $20 for one, it's just fine.
  10. Nov 11, 2020 at 7:52 AM
    #8550
    DiscoYaker
    SE USA and Alaska
    Its a leer legend. I think they are pretty much identical to century
    Brake Weight[QUOTED] likes this.
  11. Nov 11, 2020 at 8:29 PM
    #8551
    Furcata
    Furcata Well-Known Member
    Dave
    2017 TRD Off Road Long Bed
    Snugtop Rebel with windoors; Yakima towers and Jetstream bars, Yakima skybox
    Gearing up for the weekend!!!
    I have a very modular sleeping platform which I love, but I'd love to install a custom bed slide slide for the central channel.
  12. Nov 15, 2020 at 10:01 AM
    #8552
    norsea
    norsea Well-Known Member
    OK, I gotta know...
    How much does this thing weigh? I'm guessing in excess of 50 lbs., minimum...
    Curiously yours,
    Jim
  13. Nov 15, 2020 at 2:17 PM
    #8553
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Probably around 50lbs. It’s not too bad.
  14. Nov 15, 2020 at 3:02 PM
    #8554
    norsea
    That's why I did not purchase a Rhino Rack; the 72" x 45" was 52 lbs.
    I suspect that yours weighs even more. Why do I think that?
    I work with strut, a lot. In fact, I have a small love affair with the stuff. Two walls in my garage have strut mounted to the wall and hung from the ceiling rafters to support two foot wide plywood shelving. One wall is 45' long. This will be standing when the rest of the house falls down from an earthquake.
    But, it weighs a lot. I fear that all that weight on a fiberglass shell (I used to have an ARE on a Ford F2350) will lead to problems with the fiberglass. I could be wrong; I hope I am but I think you are taking a huge risk.
    Regards,
    Jim
  15. Nov 15, 2020 at 3:33 PM
    #8555
    anthony250f
    Anthony
    San Diego, CA
    might be heavier, not sure, I should have weighed it lol. I have zero concerns with the fiberglass, although i am going to watch it. Others have huge RTT on theirs and what not. this is why I added rails underneath to distribute the load. I also have the reinforced fiberglass roof.
    Brake Weight likes this.
  16. Nov 15, 2020 at 3:46 PM
    #8556
    Brake Weight
    Furcata and anthony250f like this.
  17. Nov 17, 2020 at 6:48 AM
    #8557
    G3Fab
    G3Fab Eric @ G3 Fabrication
    Eric
    Northern Illinois
    '12 TRD Off Road DC
    Those who have asked questions and anyone else that hasn't seen it yet. The round 1 group buy has 9 of the 10 spots full for the cap brackets. Pics and link in my quoted post below.
  18. Nov 17, 2020 at 9:59 AM
    #8558
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
  19. Nov 24, 2020 at 8:25 PM
    #8559
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I had a few Leer canopies over the years until I realized they are too heavy. I like driving the truck more when it handles like a compact pickup instead of a fullsize.
    These alucabs are easily half the weight and just as strong as a fiberglass cap, the side doors sealed the deal
    drvn, FashTaco, Tacman19 and 7 others like this.
  20. Nov 26, 2020 at 12:47 PM
    #8560
    camdenthekid
    camdenthekid Well-Known Member
    Camden
    Sacramento, CA
    08 Silver ORAC
    5100s, 886, super bumps, Deaver progressive AAL, u bolt flip and timbren bumps. 295 70 17 Falken MTs.
    I just picked this thing up for real cheap from FB market place. Wife and I are going to build it out with some insulation and sleep platform with at least one drawer for kitchen stuff. I had a junk roof basket laying behind my shed, might see if we can make it work for some extra storage.
    Oh and like b_r_o said the aluminum is pretty nice and light. The wife and I can lift this thing off the truck easily with just the two of us. We'll see how much weight we add throughout the build up though.
