Show me your shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by Oscar 319, Aug 28, 2008.
  1. Feb 18, 2021 at 2:19 PM
    #8741
    Rhann86
    Rhann86 Well-Known Member
    2017 TRD Off Road Crew Cab Long Bed
    I've seen the swing out racks but the price tag on them is up there. I'm sure that bike shreds in BC. I preordered a Commencal Clash which is more than enough for where I'm at, but will be great for trips out west. Thanks for the info!
    Andocalrisian[QUOTED] likes this.
  2. Feb 18, 2021 at 2:30 PM
    #8742
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Can you sit upright on your platform with the shell installed? I'm wondering if the 180 still won't be tall enough with a platform and matress to be able to sit up.
  3. Feb 18, 2021 at 2:30 PM
    #8743
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    Any interior shots??
  4. Feb 18, 2021 at 2:42 PM
    #8744
    Andocalrisian
    Andocalrisian Well-Known Member
    North Vancouver BC
    2015 Tacoma SR5 Access
    that bike is a weapon, enjoy, shoot me a PM if you need a tour guide when you come out this way. Bike rack got spot for another
  5. Feb 19, 2021 at 6:03 AM
    #8745
    Rhann86
    Gotta love the tacoma/MTB community, thanks!
  6. Feb 20, 2021 at 3:29 PM
    #8746
    Nigelcorn
    Nigelcorn Active Member
    Just switched my RTT setup from a soft shell to this so I could have a shell and still fit a RTT in the garage. It's the alu-cab canopy. I really like it so far, it was really quick and easy to put on with just my wife helping.
  7. Feb 23, 2021 at 5:07 AM
    #8747
    1SHADEofGREY15
    1SHADEofGREY15 Well-Known Member
    MD
    2015 TACO TRD OR MGM
    I’m looking to sell or swap my shell for a cab high one. It’s a ARE MX DCSB Shell. I’m located in Maryland. Is there a shell swapping thread?
    ohcaltexscar and Tacman19 like this.
  8. Feb 23, 2021 at 6:08 AM
    #8748
    Rhann86
    There is one on the buy/sell/trade section. You'll need 50+ posts to qualify to post something for sale or trade.
  9. Feb 23, 2021 at 6:09 AM
    #8749
    1SHADEofGREY15
    MD
  10. Feb 26, 2021 at 12:57 PM
    #8750
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I have an aging Century topper and on the rear hatch one of the screws began rusting/oxidizing enough to pop the little cover off of it. So I removed the screw and went to Lowes. Found a zinc screw of the same size as well as some little caps, too. Being an aluminum housing you don’t want a stainless screw because it will lead to dissimilar metal corrosion of the screw and housing. I also replaced the pop rivets holding the strut mounting points with m4 bolts and nylon nuts from my RC parts. The hatch would tend to walk side to side if driven with it open so I found some tiny black screws to add stops in the channel it hinges in. Spent some time and removed the foam strips and tacky goo that held it. I gave in and lightly wire wheeled it all off and buffed the surface rust off on the bed rail while I was there. I then measured out and added a 5th and 6th bolt hole above the wheel wells. Acid primed and hit a light coat of proper Duplicolor green. Then laid down a 3/8” bead of Liquid Nails and bolted her back down.
    Old style
    Lowes style
    Tightened up and snapped closed.
    3x 7/16” per side now with a bead of Liquid Nails. Need to clean up that wiring next time, too.
  11. Feb 26, 2021 at 1:31 PM
    #8751
    pridgway
    pridgway Well-Known Member
    2014 TRD Off Road
    Shell bros!
    I originally bought my truck with the soft top shell, and rocked it for a while as i saved up money and dialed in what my needs were. I pulled the trigger last summer on a ARE MX with dual vented windoors, carpeted interior and lighting, roof racks and so on. got all the bells and whistles since i reckon to have it or the life of the truck.. now i figure out a bike rack situation that allows the rear glass and tailgate to be functional without removing the bikes and hitch.. ideas?
  12. Feb 26, 2021 at 1:40 PM
    #8752
    Giusejuice
    Giusejuice Well-Known Member
    South Florida / Boulder
    2020 MGM 6Spd OffRoad DCSB
    Eibach Lift | 33s
    Used Leer legend. Works great
  13. Feb 26, 2021 at 2:03 PM
    #8753
    Andocalrisian
    North Vancouver BC
    couple options that I can think of:
    1. Mount bikes on roof of canopy
    2. Swing out bike hitch (pretty spendy though)
    I basically have the same truck/canopy as you, I can just crack open the back window with a bike mounted in the “closer to the truck” position. That’s where the windoors are really nice
  14. Feb 26, 2021 at 2:11 PM
    #8754
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    The vented ARE windoors look so much better than the LEER ones. I only had a LEER dealer near me so went with it. I definitely needed vents and was thinking about vented windoors but decided just for the vents (maybe because the Leer ones burn my eyes) The Leer vented windoors look so bad. Happy with what I got for sure. Enjoy yours as well
  15. Feb 26, 2021 at 5:17 PM
    #8755
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    I was able to haul my mtb's on the inside after removing the front wheel. Rolled it in backwards, rear tire first, and then clamped the forks to a fork clamp I had mounted on a 1x6 near the tailgate. Fit two bikes inside like that with gear with a ARE MX on my previous 06 Tacoma.
    sorry no pics of bikes in the back.. but do have a pic of the truck
  16. Feb 28, 2021 at 6:27 PM
    #8756
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    I have a Kuat rack. When I’m only carrying one bike, I can open the rear glass. The rack pivots down to allow the tailgate to open. I like it, but would probably take a hard look at a 1Up if I were going to get another...
  17. Feb 28, 2021 at 6:59 PM
    #8757
    PiñonTaco
    PiñonTaco Well-Known Member
    2020 TRD OR DCLB
    D98F0106-596A-41CF-A7AA-968649365E7C.jpg Different approach, consider a front hitch. $139
    https://www.amazon.com/dp/B01B88U426/?coliid=I3RDBP8K1BFF8Q&colid=2P9OYA307WHWX&ref_=lv_ov_lig_dp_it
    pridgway[QUOTED] and Tacman19 like this.
  18. Mar 1, 2021 at 5:22 PM
    #8758
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    Just got mine today!
    ARE Overland with the sliding windoors and sliding/folding front window
  19. Mar 1, 2021 at 6:08 PM
    #8759
    trailbound
    trailbound Well-Known Member
    Rob
    Surprise, AZ
    2016 DCSB TRD OR 4x4
    @kairo nice shell. I like the black strip on the roof with the quicksand.
    kairo[QUOTED] likes this.
  20. Mar 1, 2021 at 6:09 PM
    #8760
    kairo
    kairo >_>
    Nor Nev
    Thanks. I ended up going with this model partly because of that. It breaks up the colors a bit
    trailbound[QUOTED] likes this.
