Show me your shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by Oscar 319, Aug 28, 2008.
  1. Apr 3, 2024 at 7:22 PM
    #9861
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    Make sure you take in consideration any taper. I did this on my dodge because it didn’t come with it and there was a huge taper to make them “even”
  2. Apr 4, 2024 at 6:28 AM
    #9862
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have a Snug Top Hi-Liner Sport.
    The distance between the tracks is 32 1/2", center to center.
    Mine are mounted through the honeycomb, not outside of it. Now I'm confused, since this is the opposite of what I learned about composites (long ago, apparently...). Seems the material used as honeycomb for these shells has evolved over the years.
    There is also no taper in the track mounting - center to center distance remains constant.
  3. Apr 4, 2024 at 10:05 AM
    #9863
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yeah... your not the only one that's confused. Seems half say honey comb/half say outside of it lol. Just got a reply back from Sherpa (mounting a Sherpa crows nest.) They say... "There is no "right" place to put the track; we just recommend putting it in the standard location, which is usually just past the honeycomb." Guess i'll go outside at 44" between tracks as long as i'm not too far into the curvature of the shell on top. Maybe that's why Yakima provides 1" fasteners instead of the 1 1/2" that you need to buy if going through the thicker honey comb portion? :notsure:
  4. Apr 4, 2024 at 4:24 PM
    #9864
    Scott B.
    Scott
    Georgia
    If I was doing mine myself, I would probably mount the tracks outside of the honeycomb - but it appears not to matter anymore. I've hauled my kayak around on the roof, and have not ever had an issue with the rack - so my honeycomb is non-compressible?
    You could try to ask Snug Top (or a really smart dealer) about the honeycomb. They might have some insight.
    Otherwise, mounting outside of the honeycomb should be issue-free.
    Before you mount the tracks to the roof, why don't you mount the bars to the tracks, with the tracks just sitting on the roof. That will give you an idea as how the bars will sit, and how your tent will mount to the bars.
  5. Apr 4, 2024 at 5:27 PM
    #9865
    OffroadToy
    For sure going to mount the bars to tracks to get everything squared up. After more measuring i might just mount on the honeycomb. Outside of it gets too much into the outboard curve of shell and outboard of the black molding on the cab. Used to work with composites and honeycomb building aircraft at Boeing... don't think the 1/2" of it on the shell is going to be an issue plus i'm not torquing the bolts... just snugging up good with a dab of blue lock tite. It's a waste of time dealing with Snugtop now... sounds like they went downhill after covid (built south of the border now and quality went to shit) and might be on their way out from what the local offroad shop that used to carry them here said.
  6. Apr 5, 2024 at 6:05 AM
    #9866
    Scott B.
    Scott
    Georgia
    SnugTop was purchased by Leer some years ago. Then, they moved all production south of the border.
    So, yeah, another great brand lost to corporate greed... :mad:
    Ngneer likes this.
  7. Apr 5, 2024 at 8:23 AM
    #9867
    azhiaziam
    The reef ca
    Yea I just found this out recently too. My dealer has been saying are are the best ones now. Which is why I went with the Mx even though I liked the look of snugtop and leer more. But I’m really starting to dig the Mx on my truck now
    Ngneer, Tacman19, TacoGeeloor and 9 others like this.
  8. Apr 12, 2024 at 2:59 PM
    #9868
    uhchxrlie
    uhchxrlie Well-Known Member
    2020 MGM Tacoma SR SX Package
    Ranch Skyline Midrise Camper Shell
  9. Apr 25, 2024 at 5:25 PM
    #9869
    taco_marty
    taco_marty Well-Known Member
    Kevin
    HI guys, quick question, when they install the campershell, do they remove the OEM plastic rails on the side of the Tacoma, or does the shell sit on top of it?
  10. Apr 25, 2024 at 5:34 PM
    #9870
    uhchxrlie
    Shell sits on top. Many people (myself included) try and waterproof the plastic rails. There are threads about it in some places.
  11. Apr 26, 2024 at 8:24 AM
    #9871
    scmedic85
    scmedic85 Well-Known Member
    Greig
    Charleston, SC
    2012 DCSB 4WD
    As mentioned it’s over the plastic. But if you run the shell for a long time or over rough terrain the plastic rails will be damaged when you remove the shell. And I’m missing all the paint under those rails.
  12. Jul 8, 2024 at 9:23 AM
    #9872
    mrh2727
    mrh2727 Well-Known Member
    Mathew
    DFW
    2023 TRD off road Barcelona Red
  13. Jul 14, 2024 at 9:24 PM
    #9873
    louie_g
    louie_g Member
    Southern California
    2023 TRD OR, 2002 SR5
    Has anyone tinted the side windows on a snugtop rebel? I imagine the only problem would be the mesh. Not sure if it’s easily removable or not.
  14. Jul 19, 2024 at 7:53 AM
    #9874
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    i'm in works to tint the driver's side. pretty sure that tinting one side in limo will significantly reduce the ability to see in, since it cuts the light out alot.
    the screen shiukd come out easy/ there is a rubber strip that holds it in. putting it back is the hard part/ you can get a window screen roller tool at any hardware store. but it may be a challenge to out the screen in "straight" and roll the rubber in.
    I tinted my leer sliding windows many years ago, but misplaced the screens so i never put them back in. found the screens like 10 years after i sold the truck and leer !!!! I just tinted the windows in place
    louie_g likes this.
  15. Jul 19, 2024 at 6:50 PM
    #9875
    louie_g
    louie_g Member
    Southern California
    Good to know. I’ll give replacing the screen a shot, if not then not the end of the world. Appreciate it
  16. Jul 25, 2024 at 6:32 PM
    #9876
    JimCali75
    JimCali75 Well-Known Member
    James
    2023 White Tacoma OR MT Premium
    IMG_7325.jpg Snugtop GB Sport
    four22, TRlPPlN, jon_elc and 2 others like this.
  17. Aug 1, 2024 at 5:44 PM
    #9877
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB Tacoma TRD Sport 4x4
    2017 DCSB 4WD
    four22, jon_elc, TacoLolz and 2 others like this.
  18. Aug 9, 2024 at 10:26 AM
    #9878
    davegoroun
    davegoroun Well-Known Member
    USA
    '19 DCLB TRD Offroad
    What's the tallest gen 3 camper shell for a long bed out these days?
  19. Aug 9, 2024 at 10:42 AM
    #9879
    azhiaziam
    The reef ca
    minus those albu style ones i want to say an are mx. i know out of leer, are and snugtop its the highest. its also what i have love the head room. i do think those metal ones may be higher though.
  20. Aug 9, 2024 at 10:48 AM
    #9880
    davegoroun
    USA
    Thanks! I'll look into that. looks like LEER 122 might also be tall.
    No chance anyone in Central Texas wants to sell one?!
