Show me your shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by Oscar 319, Aug 28, 2008.
  1. Apr 13, 2013 at 6:12 PM
    #1381
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Does look a bit far back at the rear
  2. Apr 13, 2013 at 6:18 PM
    #1382
    bzzr2
    bzzr2 Well-Known Member
    this is my leer 100r, i had a leer 180 for a couple months, i liked it but it was not meant for the reg cab model and was contacting the rear light and the rubber seal around the upper part of the rear window so i switched it out for this one. i liked the extra headroom inside the 180, planning a 20000km road trip throughout northern canada the headroom would have made the living space a little larger but the cap was really to tight and annoyingly noisy with the contacting. even with it sitting as far back as possible it just wasn't working.. i got a good price all in all so can't complain. if money was not an object i'd have gone with the a.r.e. with the full rear door that removes the tailgate, that is a sweet setup.
  3. Apr 13, 2013 at 7:41 PM
    #1383
    FirstTracks
    FirstTracks Well-Known Member
    Marc
    Salt Lake City, Utah
    07 Tacoma Access Cab 4.0L V6 SRS 6sp manual
    Leer cap, BedRug
    I tried, actually. .. couldn't get it any tighter up front than that.
  4. Apr 13, 2013 at 8:05 PM
    #1384
    OZ-T
    Peter North
    British Columbia
    Why ?
    Contact ?
  5. Apr 13, 2013 at 10:17 PM
    #1385
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    I paid about the same for my Leer 180. Had to add a wee bit of weatherstrip around the rear window frame to make it totally dustproof and waterproof. The Leer 180 is not a sophisticated rear window like some shells. Also, I believe the Taco with the composite bed is not as rigid as an all-steel bed, so it tends to bend outward at the tailgate.
    Had to take the Leer 180 back to the dealer to have one of the windoors replaced after 8 months (leaking water), but they were pretty good about it with a little "hands on" input from me telling them to spray it with a hose, not just look at it.
    Heh, I see dbcltmp went for the ARE MX. That's a topnotch shell.
  6. Apr 14, 2013 at 4:26 AM
    #1386
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Mine was like that at first. When you loosen the tie down points, go around the topper from the outside and lift it up off the bed. Mine was stuck to the rails. Then slide it on all the way. However I do wish mine sat about a 1/4" closer to the cab...:rolleyes:
  7. Apr 14, 2013 at 6:14 AM
    #1387
    FirstTracks
    Marc
    Leer cap, BedRug
    Thanks for the tip, I'll give it a shot.
  8. Apr 15, 2013 at 9:48 AM
    #1388
    kdewit
    kdewit Active Member
    I have ordered a SnugTop Supersport for my '13 DCSB TRD Sport. It has the tilt out rear windows, fold down front window, yakima rack tracks, and a remote operated prolock on the rear window. $2690 from my local dealer All American Truck in Portland, OR. My research, mostly here, showed Snugtop as being one of the best, although expensive. I'll post a pick of my rig once it is together.
  9. Apr 15, 2013 at 12:47 PM
    #1389
    Grieby54
    Grieby54 Horsebit
    Sam
    Castle Rock, CO
    '13 TRD Off Road 4x4 DCSB MGM JBL/Entune/Nav
    WeatherTech Digital Liners, ImMrYo rear view mirror bracket, color matched grille, Tacoma door sill protectors, OEM hood protector, clear bra, tint, OEM roof rack, trimmed front mud flaps to match rear clearance, debadged, color matched grille, Plasti Dipped front Toyota emblem, OME 884X coils with trim packer on driver's side, OME Nitro Sport 9000 shocks, Deaver/ToyTec AAL with OME N182 shocks, 265/75/16 Duratracs, ProComp 7032 16" wheels
    A quick question for you guys. I have a stock 2013 Off Road. If I put a shell on my truck will my ass end drag and ride really rough, or will it sit level?
  10. Apr 15, 2013 at 2:49 PM
    #1390
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Put 150 lbs of water, sand, cement or whatever in your truck bed and drive around for a day or two and you'll know for sure. :D
    My stock off-road model truck does just fine with shell and random 50 lbs of junk in the truck bed daily.
  11. Apr 15, 2013 at 7:11 PM
    #1391
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    The amount of drop also depends on which shell you get. Mine is a commercial-grade shell (Leer 100RCC) so is heavier than most. Between it and my gear box that stays in the bed, I'm hauling roughly 300 extra lbs at all times. With the TSB rear springs and 5100's all around (front at 1.75), I had a 1/4" rake. After a year, I've lost a little over 1/2" in the rear so now have a slight reverse rake. This is in an AC with the 6' bed and it still rides just fine.
  12. Apr 16, 2013 at 1:14 PM
    #1392
    Tacomated
    Tacomated Escape Artist
    Ted
    Socal
    13 Access SR5 2WD 4Cyl
    Without the shell, I get a little "truck bounce" from the rear suspension (part of the fun of driving a truck).
    My truck actually has a smoother ride (both on the street and on fire roads) with a Leer 180 plus Thule Roof Rack (about 180 lbs).
    At 300+ lbs (shell + kayak, bike and camping gear) it gets a little wobbly.
    I sagged about 1" when the shell went on and another 1/2" with each additional 100 lbs or so.
    I'm planning on doing some version of an AAL (probably Super Springs) so I get the "truck" ride with just the shell and the best ride with the full camping load. Should also get me about 1 1/2" of lift.
    If I had more money, I'd load my truck up, drive to Colorado and let Alcan build me a custom rear spring pack.
  13. Apr 16, 2013 at 1:22 PM
    #1393
    jadefa
    jadefa Member
    Jeff
    California
    13 Tacoma 4X4 Reg Cab, 13 Tacoma TRD Sport
    Not to get too far off the subject...but is your taco lifted? If so how high and what size tires are you running, I've got a 2013 Reg Cab 4x4 and I'm planning on getting bigger tires after the factory dunlops are toast.
  14. Apr 16, 2013 at 9:19 PM
    #1394
    Winnebagosmuggler
    Winnebagosmuggler Member
    Zach
    Northern California
    2010 TRD Sport
    Any shells that would support a tent on the top by any chance? Looking to buy the All Pro bed rack and a tent but I am becoming more and more interested in a shell.
  15. Apr 16, 2013 at 10:19 PM
    #1395
    OZ-T
    Peter North
    British Columbia
    Snugtops are rated at 500lbs IIRC , the Leer commercial series caps , the 100RCC ( which I have ) , and the 180RCC are rated at 400lbs
  16. Apr 16, 2013 at 10:49 PM
    #1396
    munkeeboi
    munkeeboi Well-Known Member
    Burbank
    Picture of my truck today - Leer 100XR
    22A6AE4B-9628-46F7-B81C-52FF6ED88364-121_75dc755935e97c067d8630a28a3efa4c00455e53.jpg
  17. Apr 17, 2013 at 11:10 AM
    #1397
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Leer 100RCC-
  18. Apr 17, 2013 at 7:28 PM
    #1398
    NCTacoma
    NCTacoma Rather be in the mtns
    Caleb
    CLT, NC
    Sold- Searching for 1st gen
    100 XQ being installed tomorrow!!
  19. Apr 17, 2013 at 9:30 PM
    #1399
    Big Taco
    Big Taco Well-Known Member
    Justin
    Hampton, VA
    2001 MR2 Spyder
    Stock
    Has anyone installed a factory roof rack to their caps? Not necessarily from a Tacoma but from another vehicle that may have the same contours as the cap.
  20. Apr 18, 2013 at 1:48 PM
    #1400
    NCTacoma
    Caleb
    CLT, NC
    Here's a pic. I will get better ones later but here's one for ya.
