Show me your water/meth setups on the 5vz-fe
Discussion in '1st Gen. Tacomas (1995-2004)' started by Empty_Lord, Mar 17, 2017.
  1. Jan 3, 2021 at 10:21 PM
    #141
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Do you use a solenoid? I had bleed issues running mine in the bed.
  2. Jan 3, 2021 at 10:22 PM
    #142
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I do not run the solenoid. Mine seems to be working all good, I made sure the pump was below the injection point in the engine. How do you know you had bleed issues?
  3. Jan 3, 2021 at 10:24 PM
    #143
    Shortman5
    Supercharged TRD
    Mimes below the tank as well. But I can activate it and watch it piss and bleed off when it’s supposed to be off. One of the injection companies warned you may need a solenoid for trunk mount because of the bleed off. Can’t remember which one.
  4. Jan 3, 2021 at 10:28 PM
    #144
    Shortman5
    Supercharged TRD
    Oh yeah and I had pooling water in the intake as well as some funky noise from what I assume was that water running into the charger and the rotors hitting it.
  5. Jan 3, 2021 at 10:29 PM
    #145
    BartMaster1234
    Tyler
    Flux Capacitor
    I’m not quite sure if I have that issue yet. I just finished setting up the methanol yesterday, and it’s in a temporary safe tune since I can’t monitor AFR for the time being. Waiting on a new o2.
  6. Jan 4, 2021 at 6:23 PM
    #146
    Running Board Man
    Running Board Man Well-Known Member
    I had a motor which i ran off propane that used gas 20 years prior which had good compression before propane
    The first startup and a minute after it was just billowing smoke till it died
    After a compression check it had none
    So I took the head off and the valves/head/piston were squeeky clean but the cylinder wall was gouged to shit
    I assume the propane was burning off carbon and chunks were floating around
    Is it possible meth may do that?
    I'm not boosted and have no intent on running meth but my brains just thinking
  7. Jan 4, 2021 at 8:28 PM
    #147
    1997tacomav6
    Denver
    NO, the methonal slowly cleans the carbon. It takes awhile for the methonal to clean the carbon off,
    If that was the case my motor would burn oil and have issues.
    My oil dip stick is Usually about 1/4” low after each oil change of 5000 miles
  8. Jan 4, 2021 at 11:02 PM
    #148
    1997tacomav6
    Denver
    Methonal kits are NOT for everyone.
    The other part of this equation is the cooling effect you can get.
    I can run different setups for different times of the year with my kit if I want.
    #1 nozzel for winter or a #6 for summer.
    I can mix a methonal mixture that is leaner in volume and run a #6 nozzle in the summer and
    a 50/50 for winter with a #1 nozzle.
    More water pretty much eliminates heat soaking.
    0ne pound of boost adds 10 degrees or so when compressed after the supercharger.
    I run at 11 pounds of boost let’s say and my input supercharger Temperatures only go up 10 degrees at WOT.
    A regulator TRD supercharger without methonal water will go up 50-75 degrees pushing 150-200 degrees input temperatures.
    Methonal water can drop 100 degrees which adds up to better timing numbers, cooler more dense air.
    7th injector does nothing for cooling to get rid of heat soaking.
    You need to install a heat sensor gauge for the compressed side to know your results tho.
    I have a dual before and after gauge for the supercharger
  9. Jan 5, 2021 at 6:46 AM
    #149
    worldwearyposer
    worldwearyposer Member
    1998 4runner
    supercharged, 7th injector kit, OME lift
    After all things considered, I think I just mis-stepped overall with the truck.
    I imagined a scenario where I could add the s/c, get the power I desire for high-altitude without having to deal with "race car issues", but it's a fever dream. Once you start down this path, it turns into the same shit of adding all these sub-systems, worrying about tuning, refilling meth, etc. I did this many times with my Nissan S13s, GTIs, RX7s etc. But it's just not what I wanted in this type of vehicle. I just wanted a bit more power, but keep the car close to stock in terms of maintenance/peace of mind.
    While it may cure all my problems, adding meth at this point is just not something I want to deal with. I want this car to be more like the rock in my stable, not another race car. Because this whole thing is just so disappointing, I honestly just may part out all my s/c and tuning stuff, bring the truck back to stock and regear so I can get some extra get up and not have to worry about shit. Anyone interested in a near-new supercharger/7th kit? lol
    1997tacomav6 likes this.
  10. Jan 5, 2021 at 7:01 AM
    #150
    Running Board Man
    Across a long enough timeline everything gets an ls
    chrslefty and Robmonster117 like this.
  11. Jan 5, 2021 at 7:07 AM
    #151
    1997tacomav6
    Denver
    It really all depends on what you want for added power. Pulley size.
    If your engine and fuel system are at 100 percent You can run the stock pulley and you will have no problems, no fuel mods needed in Denver.
    If you don’t have the fuel injectors cleaned, serviced and the filters replaced then you probably will have issues and fuel pump replaced.
    These items will be working but not at 100 percent because of wear,
    So with the supercharger needing every ounce of gas it will be an issue if these parts have a lot of miles on them.
    Too many people try running the supercharger without getting their fuel system up
    to 100 percent and them complain about ping issues, lean issues.
    I ran my supercharger for 500,000 plus miles with zero issues zero fuel mods
    in Denver stock setup with the larger pulley,
    Any one of these not done can cause issues
    1) fuel filter new
    2) fuel pump new
    3) fuel injectors cleaned, fuel injector filters replaced
    4) OEM MAF and cleaning
    Tons of fake OEM MAF sensors on eBay and Amazon and these with mess things up too
  12. Jan 5, 2021 at 8:33 AM
    #152
    worldwearyposer
    1998 4runner
    Yeah I may try to go back to stock pulley, but its only like 5-6psi at most up here and the lack of low-end response on stock pulley left me instantly wanting more, the 2.1 made huge improvements here. Overall with stock pulley though, I felt like the gains were not worth the cost, so it's still a disappointment.
    @1997tacomav6 Is there any chance you'd be willing to meet up and share notes, etc.? I'd love to see how your truck runs and vice versa...
    Thanks
  13. Jan 5, 2021 at 8:38 AM
    #153
    1997tacomav6
    Denver
    Sure, I’ve done this many times,
    Just PM me,
    I70 and Morrison going up I70 area to meet
  14. Jan 5, 2021 at 8:39 AM
    #154
    worldwearyposer
    1998 4runner
    Haha so true. I wish I had the time and money for that!
  15. Jan 5, 2021 at 12:57 PM
    #155
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Im looking for some other Ideas, Where are you fellers with the stock rubber intake pipe putting the primary nozzle?
    I was thinking of machining a plug to cap off the old plastic coupler connecting the driver valve cover vent hose (im venting to a catch/ breather) And drilling and tapping that plug. Ill try and get some photos after work of my Idea.
  16. Jan 6, 2021 at 8:03 PM
    #156
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    No MAP sensor, just wired in paralleled to one of the injector's harness. Easy because I am running Supra injectors and am using adapters.
  17. Jan 6, 2021 at 8:06 PM
    #157
    Shortman5
    Supercharged TRD
    What am I missing? How can it be boost referenced if you’re not running a MAP sensor? From what I see the Aquamist does not come with one in the brain box.
  18. Jan 6, 2021 at 8:07 PM
    #158
    1997tacomav6
    Denver
    You running an AFR Gauge and or a scanguage?
  19. Jan 6, 2021 at 8:14 PM
    #159
    elnip
    LC,NM
    You are correct, I mispoke/ thinking other things....it's all based on my tune and when in boost the duty cycle goes up and using the trim pots I got it
    where it would only come on line in boost.
  20. Jan 6, 2021 at 8:35 PM
    #160
    Shortman5
    Supercharged TRD
    mom that makes sense. Aqua mist is definitely the best system out there. Wish I would have gone that route
    elnip[QUOTED] likes this.
