Show off those 35's on 3rd gens
Discussion in 'Wheels & Tires' started by 90yota, Nov 16, 2016.
  1. May 4, 2019 at 10:16 AM
    #681
    alexplb
    alexplb Well-Known Member
    Maybe I’ve missed it. With a long travel suspension ?
  2. May 4, 2019 at 12:13 PM
    #682
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    Lots of trimming
  3. May 4, 2019 at 2:24 PM
    #683
    alexplb
    34” it is than lol
  4. May 5, 2019 at 1:07 AM
    #684
    erok81
    erok81 Well-Known Member
    Imposter
    Yep. I haven’t limited my travel with 35’s or 37’s.
    Granted I limited my turning radius with 37’s but that’s it. :rofl:
  5. May 13, 2019 at 6:11 PM
    #685
    Yotaaa91
    Yotaaa91 Well-Known Member
    CA
    2017 SR MT
    Goddamn, truly is perfect. What roof rack do you have up there by the way?
  6. May 13, 2019 at 6:31 PM
    #686
    alexplb
    I’m guessing you’re not set up as a long travel.
  7. May 13, 2019 at 6:43 PM
    #687
    KENNY
    KENNY Well-Known Member
    I'm guessing you havent been around long :rofl:
    His truck is a beast
  8. May 13, 2019 at 9:14 PM
    #688
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    erok81 likes this.
  9. May 13, 2019 at 9:18 PM
    #689
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    This is what I’m not looking forward to
  10. May 14, 2019 at 12:59 AM
    #690
    alexplb
  11. May 14, 2019 at 1:05 AM
    #691
    alexplb
    Yeah didn’t see his set up before. I’m mesmerized though. I’ve seen 35s with lt and they did rub with full compression. So not sure how this is possible unless it’s really chopped hard fenders aprons etc. not saying it’s not possible but several shops I spoke with all said you’d have to limit up travel with 35s. I’m sure there are different set ups I gues total chaos is different in this respect
    erok81 and BEAR_KNIFE_FIGHT like this.
  12. May 14, 2019 at 5:50 PM
    #692
    kennethalan
    kennethalan Well-Known Member
    Michigan
    Inferno TRD Off-Road 4x4
    King Total Chaos Dakar SCS Ray 10 315/75-16 STT Pro
    Damn. Thank you!
    It’s a Prinsu rack.
  13. May 15, 2019 at 2:47 PM
    #693
    erok81
    Imposter
    Haha thanks!
    Slightly. ;)
    35’s weren’t bad at all. Just a max cmc, hammer the pinch weld, and get it aligned. Mine might have rubbed sometimes in reverse full lock. But that’s it.
    I didn’t touch my uptravel and at full stuff they’d just barely touch the upper fenderwell. Wasn’t a big deal so I left it.
    Back when I had 35’s I didn’t cut a whole lot. Removed fender liners, cut fenders and flares, cmc, hammered pinch weld and that’s it. If I remember I had 35’s without long travel too.
  14. May 18, 2019 at 4:08 AM
    #694
    Unorgnl-V
    Unorgnl-V Well-Known Member
    2017 superwhite TRD OR
    Late to the club but glad I made the jump. 315s on a 2.5" lift.
  15. May 18, 2019 at 9:31 PM
    #695
    SDmtnbkr
    SDmtnbkr Active Member
    '02 4Runner
    Whose truck is that next to you?? ....and do you know if those are 16 or 17" F5's?? :eek: That thing is dead sexy!
  16. May 19, 2019 at 7:14 PM
    #696
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    Wheeled the 35’s today. Have a few spots i rub at. Overall. Pretty pleased with how it worked out.
    TS7xTaco, YEMTaco, Dogg23 and 2 others like this.
  17. May 20, 2019 at 5:26 AM
    #697
    TS7xTaco
    TS7xTaco Warlock
    Charles
    New Mexico
    16 Super White TRD-OR DCSB
    ARB Locked, Nitro 5.29's, Cooper 315's, 16x8 Methods, Cab mount hacked, Firewall Hammered, OME Suspension, Camburg UCA's, ARB OBA, RCI skids and sliders, WarFab Front Bumper, Home Brew Rear Bumper, Orange Virus Tuned, Dobinson Snorkel, Cobra Comms...
    Looks good, now you need lockers... I watched the video.
  18. May 20, 2019 at 2:14 PM
    #698
    Catfish21
    Stockton, Ca.
    I sure do!
    TS7xTaco[QUOTED] likes this.
  19. May 27, 2019 at 7:47 PM
    #699
    PDX_Cray
    PDX_Cray Well-Known Member
    2016 Tacoma Blue
    After months I finished the driver side fender trim and Fendx liner install today. This job was a pain in the ass and took way too long but I like the results. The pass side will be much faster. I have room to trim more of the plastic guard if I want/have too. I made new liner tabs when I cut the sheet metal and used Riv-Nuts as a base for the screws holding in the liner. I also drilled thru the plastic fender guards and mounted them to the sheet metal because I hate those plastic tabs with a passion. I just used ny-locks for the screws thru the fender guards.
    I trimmed/shaved the foam insert behind the fender and used a heat gun to melt it back to a smooth surface. I also used the heat gun to heat form the fendx liners in a few spots.
    The arch on the upper right hand corner is a little fat so i may trim that back some in a few weeks when I start on the Pass side. Still on the fence if I am going to do the backs so it all matches but going with the screws thru the guards may have cemented that decision...
    I messed up on two linner tabs. I should have cut one more out one the very end of both sides. I will do so on the pass side.
  20. May 27, 2019 at 7:54 PM
    #700
    Catfish21
    Stockton, Ca.
    very clean work,:thumbsup: love it. #fendxliners
    JIMMEISTER and PDX_Cray[QUOTED] like this.
