Show off those aftermarket stereo systems!
Discussion in 'Audio & Video' started by ToyotaKTMracing, Mar 10, 2012.
Which stereo do you have?
  1. Alpine
    193 vote(s)
    14.5%
  2. JVC
    90 vote(s)
    6.8%
  3. Eclipse
    17 vote(s)
    1.3%
  4. Kenwood
    289 vote(s)
    21.8%
  5. Sony
    66 vote(s)
    5.0%
  6. Pioneer
    566 vote(s)
    42.6%
  7. Jensen
    7 vote(s)
    0.5%
  8. Other. Specify in thread
    100 vote(s)
    7.5%
  1. Sep 18, 2013 at 12:27 PM
    #781
    killianeric
    killianeric Well-Known Member
    High Desert
    2007 Bass Model Tacoma
    People are into different things
  2. Sep 18, 2013 at 5:56 PM
    #782
    killianeric
    High Desert
    My brother wrote this,
    Actually I was wrong on the amperage of the system. That was at 12 volts. The alternator charges at 15.1 volts so the system running at RMS not max power would pull 278 amps.
    The 270 amp alternator is the biggest one mechman makes in the stock housing.
    The batteries are a reserve of energy for the system because the mojo x's put a lot of strain on the power system. ( so when the subs hit the batteries allow the amps to receive a constant voltage and keeps them running cooler.)
    The RMS is 4200 watts between the three amps
    4480/15.1 = 296.68 amps including the trucks draw while runnung (lights, ac, computer)
    So if anything it would require a larger alternator but under normally daily driving conditions it charges perfectly . Because its only turned up all the way for demos in the shop and stuff like that
    And too large of an alternator isn't overkill it will just help keep the voltage stable under high loads
  3. Sep 18, 2013 at 6:05 PM
    #783
    CelsisTaco
    CelsisTaco Well-Known Member
    Anthony
    Des Monies, IA
    2011 DCSB
    2 inch lift. LED fog lights (Cali fab) Alpine head unit. Kicker door speakers. Skar subwoofer.
    I have a Kenwood head peace, kickers and a JL sub!! :) So pleased with the sound.
  4. Sep 18, 2013 at 6:37 PM
    #784
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Lmao, you put 4480 watts in a single cab. You're a committed SOB. And yes I get what you mean by going to big isn overkill but looking in terms of life expectancy of tighter spun alts vs needed amperage needs to be considered. In your case you need an A/C port to tie into land power.
  5. Sep 18, 2013 at 6:51 PM
    #785
    killianeric
    High Desert
    Life expectancy isn't an issue, he is sponsered and gets them for free
  6. Sep 18, 2013 at 7:18 PM
    #786
    Phil Dammit
    Your Mom
    Tempe, Arizona
    That's great logic. Lets put it this way, most of us are not sponsered
  7. Sep 18, 2013 at 7:47 PM
    #787
    killianeric
    High Desert
    I know.
  8. Sep 20, 2013 at 12:40 AM
    #788
    Tacoxoxo
    Tacoxoxo New Member
    Here's mine. I've read this thread countless times for ideas/pics so I thought I could give back a little bit :)
    JL XD700/5
    JL 6.5 C2-650 (Front speakers only. Running bridge, I think this is a tad too much power for these so I might upgrade)
    Pioneer 12" Shallow
    Pioneer 5500BHS HU
    Bought a cutting board for $2 at wally and melted into Tweeter's holder. Works well :) I'm a man without tools... haha
    Very novice so it took me over 40hrs total to rip everything apart, mat up the entire car. But well worth it since I drive quite a bit for work and the sound is 1000% better than stock!
    http://imgur.com/a/hsIy4
  9. Sep 20, 2013 at 6:52 AM
    #789
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Lol cutting boards pretty bad ass
  10. Sep 20, 2013 at 9:31 AM
    #790
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Pioneer AVH-p4400
    Alpine pdx-v9 900.5
    Alpine SPR-60c
    Alpine SPR-60
    Sundown Audio SD-2 10
    .5 sealed box
    8 gauge wiring
    Stinger RCAs
    Have never been a big stereo guy, well, never knew much about it, but have started learning, so this is the best setup I've had and im loving it. :)
  11. Sep 22, 2013 at 6:47 AM
    #791
    BLOODYMARY
    BLOODYMARY Well-Known Member
    Keith
    Tulsa, OK
    2012 Tacoma Double
    AFE Exhaust, AFE Panel Filter
    Pics?
  12. Sep 22, 2013 at 8:46 AM
    #792
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I dont have many.. need to take some detailed and up to date pics.
  13. Sep 24, 2013 at 7:07 PM
    #793
    killianeric
    High Desert
    Its getting there
  14. Sep 24, 2013 at 7:11 PM
    #794
    ToyotaKTMracing
    ToyotaKTMracing [OP] The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    :popcorn: :popcorn: :popcorn: You have some skills my friend.
  15. Sep 24, 2013 at 7:12 PM
    #795
    killianeric
    High Desert
    Its actually all my brother's and another employees work
  16. Sep 24, 2013 at 7:13 PM
    #796
    ToyotaKTMracing
    Shay
    West Virginia
    Well they have skills then. Lol. Looks sick so far
  17. Sep 25, 2013 at 11:08 PM
    #797
    killianeric
    High Desert
  18. Sep 26, 2013 at 9:00 AM
    #798
    ToyotaKTMracing
    Shay
    West Virginia
  19. Sep 27, 2013 at 3:18 PM
    #799
    killianeric
    High Desert
    Getting closer to being finished:D We're hoping for next month!
  20. Sep 28, 2013 at 9:12 PM
    #800
    MtnBiker831
    MtnBiker831 Well-Known Member
    Santa Cruz, CA
    17 Trd Pro
    Audio, lots of it
    Finished my front stage in the taco today. Focal 165 wrc with the utopia 3w2be 3" mid added into the mix. Tried the wrc 2 way in stock locations first, then broke down and decided to just fabricate some a pillar pods. I am running full active and will post some more pics of the amps/sub/processor once I finish up the back end. ede2unu2_7adf60a0fc2b00ad99a6e392bdcb7f160726babd.jpgemedazag_ff8bb681ddb2bc9edbff62cd39f44b70ed1a84f2.jpgy8e6e9e8_3fe0ce44d927bd3d8342803ca4870f41054bbc25.jpgugu6e8ej_d339823949ac14c1cab271a831ce39ddb09acc90.jpg
    B ill y likes this.
