Show off those aftermarket stereo systems!
Discussion in 'Audio & Video' started by ToyotaKTMracing, Mar 10, 2012.
Which stereo do you have?
  1. Alpine
    193 vote(s)
    14.5%
  2. JVC
    90 vote(s)
    6.8%
  3. Eclipse
    17 vote(s)
    1.3%
  4. Kenwood
    289 vote(s)
    21.8%
  5. Sony
    66 vote(s)
    5.0%
  6. Pioneer
    566 vote(s)
    42.6%
  7. Jensen
    7 vote(s)
    0.5%
  8. Other. Specify in thread
    100 vote(s)
    7.5%
  1. Oct 31, 2013 at 11:25 AM
    #841
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Found it, downloaded AppRadio and am currently downloading iGo North America maps for a navigation app.
  2. Oct 31, 2013 at 5:26 PM
    #842
    yote
    Mark
    Tacoma, WA
    Saw on TW Live that you are installing, me want pics for after, which head unit do you haz?
    What head unit is this? Looks just like your phone... good!
  3. Oct 31, 2013 at 10:05 PM
    #843
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    my truck has gone from having 2 15s with 6kw to 4 15s walled with 26kw to now a new set up that im currently putting together with 4 12s and 8kw with Acura TL type s Rear seats :) Front end will have a nexus7 gen 2 at the business end with an old school alpine deck and 4 8 inch mid range and 2 tweeters in the front doors :)
  4. Nov 1, 2013 at 5:20 PM
    #844
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    When did 8" woofers become mid-ranges... Sheesh. Do you provide sound reinforcement for Metallica concerts?
  5. Nov 1, 2013 at 7:00 PM
    #845
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I don't, I eliminated it but will regain some storage when I build the new set up with a rear console.
  6. Nov 3, 2013 at 5:55 PM
    #846
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    pics?
  7. Nov 4, 2013 at 5:47 AM
    #847
    ike3000
    ike3000 Well-Known Member
    IMO you may want to consider a midrange to bridge the gap between an 8 inch midbass and tweeters. very few 8 inchers or tweeters can cover a wide enough frequency range to sound good together. personally i'd swap out one pair for 8 inchers for something like a 4 or 5 inch midrange. you may need to get another processor or amp to properly set crossover frequencies, but you'll be glad you did.
  8. Nov 4, 2013 at 12:31 PM
    #848
    04Tacomabuild
    04Tacomabuild Well-Known Member
    Reese
    Kenora, ON, Canada
    04 Tacoma TRD SR5 3.4l V6
    Toytec/Billistein coilovers, allpro leafs, OME greasable shackles, allpro ubolt flip kit, Billistein 5100's in rear.
    Kenwood DDX-319, sundown SA10. I have clarion components in the doors with an alpine 500 watt running those, and a 1200 watt jackhammer running the sub
    6y4e4uru_b27ca5423200838d8ecc20c1a7b608e5798c94cc.jpgtyruvuse_e109d2a5cb255b60af11bc66867d1beced3fb245.jpg
  9. Nov 4, 2013 at 1:21 PM
    #849
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Don't worrie,
    It's not my first walk in the park. When I'm done I'll have a perfect or as close to perfect flat response curve w proper cut offs and x- over points;)
    The freq response of the drivers I selected will work just fine.
    I'm currently collecting gear for the bulk so no pictures at this pint but ican try did a few vids of the old set up at competitions and demos
  10. Nov 4, 2013 at 1:32 PM
    #850
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    When you have a sub stage that will drown out most 6 1/2s?
    With today's new drivers you can very easily get the response you desire
  11. Nov 4, 2013 at 1:42 PM
    #851
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    Palos Verdes
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    I'll play :)
    Sony MEX-GS600BT receiver mounted behind dash
    iPad 4 (32GB, WiFi-only) with Sony App Remote to control headunit
    Bad Elf Pro Bluetooth GPS
  12. Nov 4, 2013 at 1:49 PM
    #852
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    Kenwood DDX790
    infinity speakers all the way around
    Kicker 10" comp Rt 2013 model
    Kenwood 600 watt digital amp
    Clarion 4 channel power pack
  13. Nov 4, 2013 at 4:05 PM
    #853
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    I just added a Alpine type R to the ext cab.
    Not really as good as I expected it to be, especially in the lower range. I have it in a ported box.
    I have hertz component speakers and a 100w rms front and rear so the sub just sounds just like a good door speaker. I think it had to break in abit though, I was used to 2 12s in a ported box, so it's a little different than what I'm used to
  14. Nov 5, 2013 at 9:42 AM
    #854
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    How much power to the sub?
    Do yourself a fav, if that is a prefab box, but a sheet of birch ply and build a new box, tuned much lower. Prefab boxs are garbage
    Another thing you should check is if you have the coils wired correctly, you may have put d4 or d2 coils in series pumping the resistive load to high and the amp being unable to produce much power at that load
  15. Nov 7, 2013 at 3:25 PM
    #855
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    KenWood DDX370 headunit
    650W pioneer amp
    12 inch MTX Jackhammer
    Sorry for not running the wires under the carpet or something. I had to do it in the parking lot here on campus.
  16. Nov 7, 2013 at 5:55 PM
    #856
    killianeric
    killianeric Well-Known Member
    High Desert
    2007 Bass Model Tacoma
    The door panel is finally getting close to being done
  17. Nov 12, 2013 at 1:33 PM
    #857
    shaneckc
    Shane
    Thousand Oaks, CA
    Man, that's a lot of work. Are you guys rebuilding to fit more drivers in the doors or just for looks? I'd love to add another pair of Mille's to my doors but I just don't have the patience to rebuild my doors.
  18. Nov 12, 2013 at 2:23 PM
    #858
    killianeric
    High Desert
    Well the truck is basically used for demoing to people at the shop, just to show what they're capable of. The first time they redid the door panels, they wanted to maintain some sort of factory look. Plus to make room for the 3 way and to get it angled where they want it. Now since they threw LEDs into the mix, they wanted to incorporate the blue LEDs into the door panels, so they decided to just go all out.
    The first time they did it
  19. Nov 12, 2013 at 2:25 PM
    #859
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    Here is mine. Pioneer Appradio 2 w/ everything else stock but looking to upgrade if you have any suggestions.
  20. Nov 13, 2013 at 6:22 PM
    #860
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    How is the sound with an upgraded HU and factory speakers? I'm planning to order a Pioneer x5500bhs from crutchfield this Christmas and not upgrading speakers yet, just curious.
