Show off yer guns
Discussion in 'Guns & Hunting' started by bauermike, May 28, 2008.
  1. Mar 7, 2016 at 3:41 AM
    #8081
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I do, a few years ago there was a Marine over run of TA31R's and I bought a couple for $900 OTD [each] Came with cleaning kit, diffuser and pouch. Really like them but they aren't as fast as EOTech's close up. However, they dont have the EOTech shift problem when they are exposed to cold temps. [lots of info on that] That said, I've never had any issues with my EOTech but many others have.
  2. Mar 7, 2016 at 4:07 AM
    #8082
    Silveryota01
    Silveryota01 Well-Known Member
    Logan
    Conway SC
    2020 Silver Sky Metallic TRD 4x4 OR
    Built spikes tactical SBR with 7.62x39 upper suppressed with gem-tec can and 5.56 upper suppressed with AAC 7.62-SD and just a few I have laying around the house lol
    Yotabilly likes this.
  3. Mar 7, 2016 at 7:55 PM
    #8083
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I'm not sure if I want to keep my EoTech after hearing about their thermal drift issues and getting sued by the federal government for it. Although I haven't had problems with mine...if you have that set up could you take a pic of what it looks like through the magnifier? I used my buddys the other day and it was awful, very blurry.
  4. Mar 7, 2016 at 11:58 PM
    #8084
    JM77
    JM77 Active Member
    Josh
    Colorado
    2022 Tacoma SR5 Trail Edition
    I am not sure about any major issues with the EoTech, I used 553 when not using an ACOG in service. I chose to have it on my personal AR now. There is another option as well. I know Aimpoint offers a similar set up if you just want a magnified red dot, I am not sure of the model number though. I still would get the ACOG if you have the cash and want to spend it. As far as a pic of the G33, its not mine but... Hope this info helps
  5. Mar 8, 2016 at 12:03 AM
    #8085
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Wow that looks a lot better than the one I saw. Maybe it was set up in the wrong spot. Thanks for the pic. Did you have any issues with the eye relief on the ACOG?
  6. Mar 8, 2016 at 12:05 AM
    #8086
    JM77
    JM77 Active Member
    Josh
    Colorado
    No, eye relief was great as long as you had it just before the rear iron sight and your stock out at least one maybe two clicks. I will see if I have a pic of my rifle from back then
  7. Mar 9, 2016 at 8:39 PM
    #8087
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    I've wanted the Glock 26 for a long time. I've messed around a lot with my best friend's G26, and liked it a lot. Solid choice, and ammo isn't horribly expensive compared to others. This one came with 4 mags. Three are +1 with pinky extension, one is a +2 with pinky extension. I already did a "temporary" trade with Robert. Gave him a +1 to try out, and he gave me one of the regular ones to try. Just wanna look at all options, and this way we didn't spend any more just yet. It also came with a 3.5 lb trigger installed and a stainless steel guide rod. Left me the originals in the plastic containers that the upgraded parts came in. Also gave me a speed loader. I will be changing the trigger out for the Siderlock (formerly known as the G-Lock, if I recall correctly) one and will probably put night sights on it. Also looking into other holsters. Plan on buying at least one box of ammo per paycheck as well.
  8. Mar 10, 2016 at 4:06 AM
    #8088
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Any particular reason for installing that trigger?
  9. Mar 10, 2016 at 9:40 AM
    #8089
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    I'm not overly fond of easy triggers like the one the previous owner had installed on this one. In the event that my gun ever found itself in a child's hands (I have many other measures that would prevent that from happening, such as common sense, and locking firearms up when not being carried) but I would feel better with that little extra piece of precaution. I would never expect or intend for one of my firearms to end up in the hands of a child, but I would rather be safe than sorry. The little slide lock trigger dealie would be one more step the child would have to go through before firing the gun, and most kids would likely not even notice it.
    So pretty much, it just makes me feel a little better, even though I would never leave my firearms within a child's reach. Just want to be as reasonably safe as possible.
  10. Mar 10, 2016 at 9:50 AM
    #8090
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    As with all 6 of my Glocks two 19's/23/26/27/30 I have found that if you pull out the trigger bar,connector,firing pin safety and polish them on a high speed buffing wheel and change the springs to the Wolf Lone Wolf 3.5# connector,Lone Wolf mid-weight striker spring and Glock factory trigger spring. You can achieve a trigger pull of around 4.25/4.5 lbs and have one of the smoothest pulls and resets going for little money.
    chiefcrunchy and Fenwick1993 like this.
  11. Mar 11, 2016 at 5:33 PM
    #8091
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
  12. Mar 12, 2016 at 2:59 AM
    #8092
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    I do the same (polishing). Just be careful with the very back edge of the cruciform. You don't want to round off/dull that angle that releases the striker.
  13. Mar 12, 2016 at 6:45 PM
    #8093
    BladeRunner76
    BladeRunner76 Member
    The Bluegrass
    2006 DCSB TRD OffRoad
  14. Mar 14, 2016 at 2:16 PM
    #8094
    austin21
    austin21 Well-Known Member
    Austin
    Bend, Oregon
    2014 Super White Tacoma SR
    Cut springs
    Any recommendations for a good synthetic stock and forend for a Remington 870. Not a huge fan of the wood finish.
  15. Mar 14, 2016 at 2:24 PM
    #8095
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Magpul makes one for the 870 that gets good reviews on midway
    austin21[QUOTED] likes this.
  16. Mar 14, 2016 at 3:57 PM
    #8096
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I've used the Speedfeed with the pistol grip, the Hogue youth and the Mesa Urbino. The Urbino is on there right now, but I don't know if it's for sure the best. It's definitely the most expensive, lol.
  17. Mar 14, 2016 at 5:04 PM
    #8097
    austin21
    Austin
    Bend, Oregon
    Cut springs
    Im deffinitley interested in a pistol grip. But i am on a budget haha. Thanks for the reply!
  18. Mar 14, 2016 at 5:29 PM
    #8098
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I've got the Speedfeed pistol grip, but I ant find them anymore.
    Only these now: https://www.ebay.com/ulk/itm/281413880689
    Speedfeed
    I have a buttstocked pistol grip Houge to go with the rifled barrel.
  19. Mar 14, 2016 at 6:27 PM
    #8099
    BrokenMech
    BrokenMech Well-Known Member
    Upstate, NY
    2019 4Runner TRD Pro
  20. Mar 14, 2016 at 10:14 PM
    #8100
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Still waiting on my form 1 (1 month, 3 weeks, 1 day since Efiled) but I added the magpul K2 grip yesterday and it's a lot more comfortable with the short LOP, and I got my silencerco #fightthenoise sticker in today so I had to get a picture.
