Show off your 3D printed parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reddy, Dec 10, 2019.
  1. Dec 30, 2020 at 8:50 PM
    #441
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    05 V6 4x4 TRD Off-Road
    First of I painted my truck Satin flat black,.... well faded satin flat black lol, it has 5100s up front and J66's as well as billy 5150s in the rear, 285/ 75/16 Falcon wild peak A/T, Axis regulators painted satin black, with a tan rings! brush bar with 30 in led light bar , Custom rear Bumper, Straight Pipe. Led Hi/Low, and led fog lights, Flat Black Interior!
    Subbed
  2. Dec 31, 2020 at 5:11 AM
    #442
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Yeah the Prusa is very good for the money, and is well thought out. I also use the IKEA lack table cover with plexiglass sides to keep a uniform temp, but PETG is fairly well behaved anyway.
    I have had luck with threads if they are not carrying much load and model as class 1A/B if both are printed, or 2A in the previous part worked interfacing with a machined thread, usually run PETG with 200um layers. If it needs to carry load I steal the trick I saw Prusa using and design in a cavity or slot to slide in a nut.
    F360 is very different than Creo. The subtlety of part features vs assembly all wrapped in one model is the hardest thing to sort out for me. Although I recently discovered how stupid simple the rib and web tools are to use which is very handy, so it has some perks.
    It also helps to remember design for manufacturing.. any thin walls that are vertically orientated on the build plate work best if you can make them a multiple of the nozzle diameter.
    2008taco and Pyrotech like this.
  3. Jan 2, 2021 at 6:49 PM
    #443
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I just printed up a couple racks to keep these tools off my desk. I designed them in tinkercad because it's fast and easy.
    Afilao, gkomo, 3 Blade Rage and 2 others like this.
  4. Jan 2, 2021 at 7:00 PM
    #444
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    If you are new to CAD I would suggest starting out with tinkercad. It is the same company as Fusion 360 (in fact you use the same account to login) but is way easier to begin designing on. Once you get the hang of it then move onto fusion 360. If you don't know you can get a free 360 account as long as you don't make over a certain amount per year from using it.
    I just made a roof rack for my 10th scale 4Runner using only tinkercad.
    rednext[QUOTED] likes this.
  5. Jan 2, 2021 at 7:03 PM
    #445
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    If you make any more let me know
    3 Blade Rage likes this.
  6. Jan 4, 2021 at 7:54 PM
    #446
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Swapped out my shifter knob for the TRD one and was left with the ugly chrome cap at the top of the boot. Half a beer, a minute with calipers, two minutes on Tinkercad, and 9 minutes of printing later:
    https://www.thingiverse.com/thing:4710590
    Stupid simple cap, it press fits on, doesn't snap in or anything. We'll see how it holds up!
    NmapFE, TK-422 and 907rx7 like this.
  7. Jan 8, 2021 at 1:12 PM
    #447
    jordi992
    jordi992 Skidplates reduce clearance
    Jordan
    Burlington, ON
    Red truck
    Light bars, no lockers
    Thanks going to print one for mine.
    spencermarkd[QUOTED] likes this.
  8. Jan 9, 2021 at 3:30 AM
    #448
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    Sorry, I just had to redo the top rack. I didn't leave enough space for the drivers and although I measured the width of the bottom of the handle it did not print correctly. It caused the drivers to keep falling out of their spots. Now it is fixed. Stuff happens. Luckily it is easy to fix and re-print.
  9. Jan 9, 2021 at 6:15 PM
    #449
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    There is a printer at work - I'd like to get a wrench holder like the one here - do you have something you could share so I could get it made ?? Thanks for any reply.
  10. Jan 9, 2021 at 6:40 PM
    #450
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Got a heater in my enclosure. And in typical fashion that turned into a huge project that ended in me rewiring my whole printer. But the new electronics drawer looks great. And I have enough room to add more stuff20210109_131638_HDR.jpg
    spencermarkd likes this.
  11. Jan 24, 2021 at 4:11 PM
    #451
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Edit: Added .stl file
    also, just snapped one (it's minus 5 C out) so thinking PETG might not be the best material - I had to use the heat gun to bend it in the first place. Might try TPU if my local shop has some.
  12. Jan 27, 2021 at 1:19 PM
    #452
    joshj808
    joshj808 Active Member
    2010 Silver Tacoma TRD Sport
    None
    Dang! I am glad I found this thread. I am really wanting a new front badge made up for my 2010 Taco. I loved that SW one that someone's son-in-law made for him. I want something similar but I want the emblem from The Mandalorian that the Armorer made for Din
  13. Jan 27, 2021 at 1:21 PM
    #453
    2008taco
    chris
    san diego
    Made this for an astrovan, and a matching keychain too.
    907rx7 likes this.
  14. Jan 27, 2021 at 1:42 PM
    #454
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Haha that's cool, I thought it said BADASS TRD
    Pyrotech and theolee like this.
  15. Feb 4, 2021 at 8:12 AM
    #455
    2008taco
    chris
    san diego
    Hemeras are FINALLY in stock!!!
  16. Feb 19, 2021 at 8:26 AM
    #456
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Pretty stoked to have found this thread. I’m new to 3D printing, currently looking at the prusa mini. Any suggestions?
    HappyGilmore likes this.
  17. Mar 16, 2021 at 4:58 AM
    #457
    Pyrotech
    Pyrotech Well-Known Member
    Holy layer shift Batman...
    Fired up the printer for the first time in awhile, reworked a model that is on the backburner list, started it and head off to bed. and this is what I woke up to. It should have been this...
    907rx7, supralee and 2008taco like this.
  18. Mar 16, 2021 at 7:38 AM
    #458
    sicki
    sicki Well-Known Member
    had some of those mornings ....when ya wake up and say fack another one
    907rx7 and 2008taco like this.
  19. Mar 19, 2021 at 9:15 PM
    #459
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    Still need these?
  20. Mar 22, 2021 at 8:48 AM
    #460
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    Nope, I've got some. Thank you for asking. Now just have to get time to do some modifying!
    I'll have to post some pictures when I do go ahead install them even though I didn't make them.
    C41n[QUOTED] likes this.
