Show off your 3D printed parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reddy, Dec 10, 2019.
  1. Sep 11, 2022 at 7:25 AM
    #661
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    It's absolutely worth it! Everything else done to your stereo is incrementally better, but sealing the doors makes the most difference in making the sound more full. Especially the lower mid notes. It optimizes the speakers ability, plus reduces outside noise and vibrations to a certain extent. Even doing this with entry level car audio speakers or even stock makes them sound like much higher end speakers in an unsealed door. It's crazy how much it helps.
    With deadening, it's absolutely true that there is little benefit to completely cover the panel compared to doing 50%. Don't get hung up on the specifics of that though. Mainly do the edges of a panel, large flat parts and anywhere there is another piece of metal attaches to the panel you are deadening. Like the outer door skin you want to make sure you deaden where the crash support attaches to the skin and the surrounding edges. Since you aren't doing thin strips out of ease, you're going to be covering at least 75% of the outer door skin anyways. But there's no point in stressing about full coverage. Now if you do sound absorption, you want maximum coverage with minimal gaps/pieces.
    dpele[QUOTED] likes this.
  2. Sep 12, 2022 at 8:12 AM
    #662
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Do you have pictures of the crash supports you are talking about?
    I think I will try to cover as much as I can in the doors. I also have 2x 10" JL subs in the back seat. I will take those out and cover the back wall.
    I plan on doing 50 or 80 mil sound deadening and then adding 150 mil Noico Red insulation.
  3. Sep 12, 2022 at 8:47 AM
    #663
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    They make a steel threaded insert that works really well for this purpose. I think I grabbed a bag of 10 or so a long time ago. I used them for my RTT rack and also for attaching my traction boards and hi-lift jack. I don't think plastic is going to do very well in this sort of orientation. Props to innovation though!
  4. Oct 2, 2022 at 9:23 AM
    #664
    RauthBjorn
    RauthBjorn Well-Known Member
    Designed, modelled, and printed a custom mount for a 350amp MEGA fuse and the Badlands 12k winch switch. Mounts right up in the engine bay on drivers side using the two empty threaded holes. Currently selling the 3d files, but will consider selling the entire printed part and hardware as a kit if there is enough interest.
    3d files:
    https://cults3d.com/en/3d-model/too...ds-12k-winch-mega-fuse-block-and-switch-mount
  5. Oct 2, 2022 at 7:45 PM
    #665
    CNC860
    CNC860 New Member
    My attempt at printing the rock lite hood brackets. Tried different draft settings to lower print times, 0.3 on the left and 0.2 on the right.Both printed in ABS, removed the supports and gave it a quick sand.
    dpele and Fargo Taco like this.
  6. Oct 13, 2022 at 9:38 PM
    #666
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    Any one have a 3d model of the factory style push button switch receptacles? Would like to have both small and large if you have them. If you don't mind sharing
  7. Oct 14, 2022 at 8:39 AM
    #667
    Duceswilder 22
    Duceswilder 22 Active Member
    2016 inferno trd sport
    Icon Lift all the way along with wheels
  8. Oct 14, 2022 at 9:19 AM
    #668
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Two things.
    1) I have no idea what part(s) are 3D printed.
    2) Isn't the decal on the bed supposed to be on the other side?
  9. Oct 14, 2022 at 11:17 AM
    #669
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Yep decals appear to be reversed lol
    mic_sierra, Gunshot-6A and Fargo Taco like this.
  10. Oct 16, 2022 at 1:07 PM
    #670
    Duceswilder 22
    @2015WhiteOR shes a bad ma’am a jammerjust as foxy as she can be.
    4ast4orward likes this.
  11. Oct 18, 2022 at 3:35 PM
    #671
    dpele
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    :sandwich:
  12. Dec 21, 2022 at 6:16 AM
    #672
    Dean62
    Dean62 Well-Known Member
    Jacob
    Florida Panhandle
    2020 TRD Sport 4x4 BR Access Cab Manual
    How is this holding up?
  13. Dec 23, 2022 at 3:26 PM
    #673
    dntnosht
    dntnosht Well-Known Member
    SoCal
    2009 TRD Sport DCLB
    stocko
    I don't have a 3d printer nor do I know anything about 3d printing but I do have a request for not Tacoma related thing'
    I currently have 6 Samsung SSD's hooked up to my PC. Right now they are laying flat on a laptop cooler. What I would like is some type of holder that I could put them on their side that would hold all 6 ( pic only shows 5 but I added another one. ) I am willing to pay for your time and materials as long as it; not to pricy. I can send measurements as they are in external SSD holders.
  14. Dec 23, 2022 at 4:25 PM
    #674
    Fixxxer
    Fixxxer Well-Known Member
    Port Angeles
    '13 TRD Sport DCLB Super White
    ARB Front/Rear Air Lockers, Nitro Gear 4:88's, Hutchinson Rock Monsters, SOS Concepts Front Aluminium Bumper, UpTop Overland Alpha XL Roof Rack, ARB Snorkel, AVS Rainguards, Redline Hood Struts, Weathertech Mats, Flyzeye led's, MESO Molle Rack, Meso LED Dome Light, K&N Air Filter, UNI Filter Mod, Bosch Wiper Blades, Snugtop Sportster Reinforced Canopy, Viper 2-Way Remote Start, ARB Twin Compressor,
    I could print you something to hold them individually but with time modeling and filament would likely cost more than the part is worth. Have you considered a section of some industrial Velcro?
    Squirt likes this.
  15. Dec 23, 2022 at 4:35 PM
    #675
    dntnosht
    SoCal
    2009 TRD Sport DCLB
    stocko
    Thanks and no I haven't. This just kind of just popped into my head. Might bump around Lowes or Home Depot to see if I could put something together.
    Squirt likes this.
  16. Dec 23, 2022 at 4:41 PM
    #676
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Or something like this, adjustable to whatever width: Perfect project for something who has a printer, but like others said, not really worth time or shipping for someone else to make it for you y'know.
    dntnosht[QUOTED] and 907rx7 like this.
  17. Dec 23, 2022 at 5:28 PM
    #677
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    I would look for a pliers rack.
    dntnosht[QUOTED] likes this.
  18. Dec 23, 2022 at 5:29 PM
    #678
    907rx7
    James
    Same idea, should have read replies first
  19. Dec 23, 2022 at 6:12 PM
    #679
    dntnosht
    SoCal
    2009 TRD Sport DCLB
    stocko
    damn bingo that would work great. Thanks much. Going to order one now.
    spencermarkd likes this.
  20. Dec 27, 2022 at 6:15 PM
    #680
    dntnosht
    SoCal
    2009 TRD Sport DCLB
    stocko
    Thanks to
    907rx7 and
    spencermarkd for you suggestions it worked out great. Cut it in half and I put the other half on top to keep them straightish.20221227_180441.jpg
    Raylo, spencermarkd and 907rx7 like this.
