Show off your 3D printed parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reddy, Dec 10, 2019.
  1. Jan 20, 2020 at 7:51 AM
    #81
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    But you can also add auto bed leveling to a lot of printers for like $60
    hazard2600 and Zac of all trades like this.
  2. Jan 20, 2020 at 7:58 AM
    #82
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would pick these up for my 2nd gen so fast if someone made them.
    That is excellent work! Installed into a Chevy I take it?
  3. Jan 20, 2020 at 8:33 AM
    #83
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I use a Robo R1. I think it was like $500 back when I bought it a couple years ago. I've printed personal stuff but am also working on a mount for bed rails that transfers the weight off the rail itself and onto the side of the bed. Should have a production unit shortly. Goal was so you can mount heavy things to your bed rails and not worry about bending them downwards with the heavy stuff mounted to them.
    I also sell a "universal" GoPro mount here: www.komosport.com
  4. Jan 27, 2020 at 5:34 PM
    #84
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Check your local library, university or find a makerspace to get the usebof a 3D printer. I have a Monoprice Ultimate($800.00) that works great when I can get it set up properly. Try different ones and research, research, research.
  5. Jan 27, 2020 at 5:42 PM
    #85
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
    Have a Prusa MK3S (started out life as a MK3) with some mods and a mosquito hot end. Got tired of that stupid E3D hot end when I wanted to change nozzles. I do most of my 3D files through blender because I started off model design more focused on figurines and game avatars, I really need to get into Fusion 360 or something better for more mechanical part design. I’ve churned out a few simple remixes of things I have found on thingiverse and here for my truck. Probably will make myself one of those cup holder buckets at some point, I like that idea.
  6. Jan 28, 2020 at 6:57 AM
    #86
    DG92071
    DG92071 Well-Known Member
    I know damn near nothing about 3D printers.
    I have an idea. I'd like to use my experience in audio systems to improve the sound in Tacomas using the stock speaker front door location. Basically a box for the 6x9 to drastically improve bass response. I'd want to offer it to the public in a sealed version and a ported version. I briefly looked at the door when I changed my front speakers and there is definitely enough room for a box without any cutting. I'd tune the port of the ported version for a specific brand and model of speaker. I'd want it to be of a plug and play design with no cutting of the door required. A speaker box like this will make a subwoofer a non-necessary item for most listeners. I have built many sealed and ported speaker boxes out of fiberglass for the inside of doors and other difficult locations. I could determine all of the exact measurements required.
    I did a quick drawing of what I'm thinking of just for a reference.
    This is my lame drawing of a port (lol)
    Like I wrote before, I know damn near nothing about 3D printers...
    1. So how easy of a project is this for a 3D printer?
    2. I would like someone with a 3D printer to guess how much the material would cost and I would like a guess as to how much time the printer would take to print the part. I'm guessing I'd want it to be about 3/8" thick everywhere but the surface that the speaker mounts to would be thicker.
    3. Are 3D parts weaker than say a plastic part that was made in a mold? The sealed box version can not flex at all from the speaker moving in and out, the ported version wouldn't have that problem as there is very limited amount of pressure created within a ported box.
    4. Is anyone with a decent 3D printer interested in assisting me in this project?
    5. Is there some sort of scanning ability of a 3D printer so that if I make one in fiberglass it could be duplicated with a 3D printer or are all of the measurements manually entered into the printer? If the answer is yes it does scan parts: can the scan be changed to be have more even dimensions? The fiberglass box wouldn't be perfectly symmetrical and it's thickness wouldn't be perfectly uniform.
    I really wouldn't care if the file for the boxes were shared between 3D printer owners as I don't think someone would "steal" the file and go out and buy a $1,000+ 3D printer just to make speaker boxes for their truck. I would want my part of the profit to be very minimal to discourage theft of the design. If the file is available to the public then it couldn't be stolen (LOL!).
    I'm definitely open to suggestions/comments on this topic. Thank you!
  7. Jan 28, 2020 at 7:13 AM
    #87
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    1. If you got all the measurements it would be pretty easy to draw something like that up most likely. Size of it on a lot printer beds might be too large though.
    2. Material cost probably wouldn't be terrible, it's around $20 for a kg of filament.
    3. Molded are better in my experience than what most of us are using for filament. Doesn't mean a 3D part can't do the job here.
    4. Probably not since I have limited personal time and I don't have a lot of interest in this project, sorry.
    5. Good 3D scanning is expensive and home photogrammetry is hit or miss.
    As for leaving it open source, just upload it to Thingiverse with a non commercial license, then people can use/share it, but you can shut them down if they try to sell here or on etsy/ebay type places.
    #87
    DG92071 likes this.
  8. Jan 29, 2020 at 4:33 PM
    #88
    DG92071
    Very informative, thank you!
    #88
  9. Jan 30, 2020 at 11:35 AM
    #89
    jtaco11
    jtaco11 Well-Known Member
    Cool idea thinking of this option also. My gas light broke could mount in the bed but thieves will take it.
    Manfred likes this.
  10. Jan 30, 2020 at 11:44 AM
    #90
    realsystem
    realsystem Well-Known Member
    Stanislav
    SF Bay Area, CA
    2017 MGM Tacoma TRD OR DCSB | 2021 Cement Tundra SR5
    LT,37s,5.29,Kings,Camper,Deavers,snorkel,winch,CVCtune
    I'm using ender 3 and it's very good for my purposes(biggest project was snowshoes for kid), not much printed parts for Tacoma, but something is here: https://youtu.be/EFNW3SID-zA?t=407 (the full video is about fridge experiments)
  11. Feb 15, 2020 at 4:35 PM
    #91
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    Interested in a set, check your PM.
  12. Feb 15, 2020 at 5:13 PM
    #92
    jowybyo
    Joe
    Baltimore, MD
    Just curious how you afford that printer?
  13. Feb 15, 2020 at 5:19 PM
    #93
    Yann
    Mick
    South Carolina
    :spy:I hope it's a work printer he can use for personal printing :spy:
  14. Feb 15, 2020 at 5:20 PM
    #94
    jowybyo
    Joe
    Baltimore, MD
    Im guessing but I’m still jealous :anonymous:
    Yann[QUOTED] likes this.
  15. Feb 15, 2020 at 8:33 PM
    #95
    creddington
    creddington Active Member
    Connor
    Fort Collins
    2019 TRD OR DCLB
    Yup! I work at Avid Product Development (avidpd.com). We're a engineering contractor, with 3 MJF printers in house. 2x 4200 and 1x 5200 (with the BASF Ultrasint TPU). No 580 color, but we do quite a bit of cerakoting in house if that interests you.
    If you have printing projects (prototyping or small production runs), send me a PM and we can chat!
  16. Feb 15, 2020 at 8:39 PM
    #96
    Pyrotech
    Pyrotech Well-Known Member
    I picked up an ender 3 pro, and added a direct drive conversion
    RoNeil likes this.
  17. Jun 17, 2020 at 2:33 PM
    #97
    PyroTaco
    PyroTaco Well-Known Member
    2013 Reg Cab Tacoma
    Fat Bob's lift kit, 30's on stock steelies, lunchbox locker in the rear, and a ton of other general mods and additions to help the utility of the truck for my particular uses.
    Bringing this back to life hopefully. Got my wife a Ender 3 for her birthday. We immediately printed some upgrades for it and purchased a BLTouch ABL system. Once you get it dialed in, you can make all sorts of fun stuff. Printed items from a replacement wheelie bar for my RC truck to parts for my Tacoma and everything in between. Designed, printed, and currently using switch blanks for the center console, 120mm fan brackets made of ABS for the snugtop (ventilation baby!), and a multitude of other things. Check out my stuff on Thingiverse.
    https://www.thingiverse.com/castmem/designs
    -PyroTaco
    TRDSport10, RoNeil, Pyrotech and 4 others like this.
  18. Jun 17, 2020 at 2:43 PM
    #98
    jowybyo
    Joe
    Baltimore, MD
    No. According to this thread you shouldn't share your 3D print files and anyone who asks is apparently an asshole:
    https://www.tacomaworld.com/threads...arger-for-2nd-gen.668187/page-5#post-23488721
    Also, are you using an enclosure to print ABS on your Ender3?
    Jojee117 and spencermarkd like this.
  19. Jun 17, 2020 at 3:03 PM
    #99
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Those fan brackets are sweet. Well done. There's another 3d print thread in here somewhere, too, btw, with some other taco things to print.
  20. Jun 17, 2020 at 3:04 PM
    #100
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    I see both sides of it, I do some stuff and post it for free use (usually with a no commercial license) and when I am unhappy with something or want to do something else with it I may not share. People are free to profit off their works if they want to go that route without sharing with fellow makers.
    This gets to be a much bigger issue when it isn't little cheap car parts. The war between free use and paid models gets really heated in higher end design like video games. There is a certain VR social platform where people like to rip and use a lot of people's work without license or fee.
