Show off your Access Cab (Photos)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRICOMA, Feb 25, 2009.
  1. Jun 21, 2016 at 2:52 PM
    #2241
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    my 2011aclb with 3 inch toytec suspension lift 33x12.50 Atturo trial blade xt tires 18x9 gear alloy big block wheels and most recently a B.A.M.F. cmc chop to clear them 33's
    Soul Surfer, Casper66 and bubagump74 like this.
  2. Jun 21, 2016 at 5:08 PM
    #2242
    jc11taco89
    jon
    Naugatuck CT
    Another one of my pride and joy but a side angle with pop's 06 dclb sr5 making a slight appearance
    Casper66 and Soul Surfer like this.
  3. Jun 21, 2016 at 5:20 PM
    #2243
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    good looking truck man i like the light bar
  4. Jun 21, 2016 at 5:40 PM
    #2244
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    lol they don't get our trucks i'm glad some ladies do
    svocobra likes this.
  5. Jun 22, 2016 at 1:23 PM
    #2245
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
  6. Jul 20, 2016 at 6:51 AM
    #2246
    soupisg00df00d
    soupisg00df00d Well-Known Member
    Mark
    Eastern North Carolina
    2012 White Tacoma V6 4x4 6 speed manual
    Bilstein 5100s 884s Toytec prog. AAL SPC UCAs ProComp 5001s 16x8 Copper discoverer RTX 265/75r16 Black rear bumper Color matched grill surround
    5001s with 265/75r16s - Prelift (should be lifted in a week or two)
    Then I just need to colormatch the grill and black out the badges. I'll either buy a nice rear bumper or paint the stock one, haven't decided yet.
    Casper66 likes this.
  7. Jul 20, 2016 at 7:21 AM
    #2247
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    you might like to try dipping them first. it's easy and you can run that color for a while then peel it off and try a different color. my truck is basically identicle to yours so i tried black on the grill and rear bumper and emblems first. if you use black on the grill don't use the glossifier over it. then i peeled off the black and dipped the grill and rear bumper white which lucky enough is almost a direct color match. use the glossifier on the white it helps to prevent staining. it's a durable finish that's cheap and fun to apply. just remember multiple coats the thicker it is the easier it is to peel off if and or when you'd like to redo ar change colors
    i also ended up debadging the entire truck i found that after i dipped the emblems black which looks really good it is also hard to get all the dirt out of the emblems and keep clean
  8. Jul 20, 2016 at 7:31 AM
    #2248
    soupisg00df00d
    Mark
    I like that white bumper. I hadn't thought about it before. It looks damn good.
    Do you have any advice for removing those ugly plastic stickers on the rear flares? I was going to trying pulling them off and using some Goo Gone, but I don't want to ruin the paint.
    Casper66[QUOTED] likes this.
  9. Jul 20, 2016 at 8:04 AM
    #2249
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    What length Rossis?
  10. Jul 20, 2016 at 8:08 AM
    #2250
    jpmorrisvb
    Jimmy
    Virginia Beach
    In the sun ... pick at a corner ... peel it back almost right back onto itself ... 3M makes a great cleaner/remover ... I've used it for about 10 years ... not oily.
    http://www.uline.com/Product/Detail...gclid=CJXMmu-ogs4CFQxZhgoda_QFGw&gclsrc=aw.ds
  11. Jul 20, 2016 at 8:40 AM
    #2251
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    if you are reffering to the chip protectors you could use some heat i.e. a hair dryer to see if it'll loosen them up. then when you get them off a mild reducer/thinner to remove the glue i used that when removing the glue from the badges. then used a cleaner wax on the entire area after. don't over heat though you'll soften the paint. personally i'd leave the chip protecting films on to protect the paint as long as they don't get to looking too bad. if you decide to try your hand at plasti dipping there are also plenty of videos on you tube. i didn't remove the rear bumper either time i dipped it. i did remove the license plate and the tag light housings then taped the rest. it can be a little tricky removing the tape on the ends of the bumper where the curves are so save a little dip in case you need to touch it up
  12. Jul 20, 2016 at 8:47 AM
    #2252
    soupisg00df00d
    Mark
    Yea mine are pretty bad, they are outlined with about 2mm of brown from water getting under them. On the white truck it is very noticeable.
  13. Jul 20, 2016 at 8:48 AM
    #2253
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    maybe try what the other person said first and put it in the sun and see if that'll loosen it up enough to remove it that's a good idea then whatever you can to get the glue off
  14. Jul 20, 2016 at 9:20 AM
    #2254
    MattLikesTacos
    MattLikesTacos Well-Known Member
    Matthew
    2015 Tacoma sr5 Access cab
    when painting your rear bumper with plastidip did you have to rough up the chrome at all or did it stick well??
  15. Jul 20, 2016 at 9:31 AM
    #2255
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    noooo don't scuff the chrome that's 1 of the really neat things about it you just clean it good and then before paintng i wiped it down quickly with some mild solvent. when you peel it off your chrome looks like brand new or at least as good as it did before you dipped it
  16. Jul 20, 2016 at 9:31 AM
    #2256
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    if I may ask, what size is the trailer?
  17. Jul 20, 2016 at 9:33 AM
    #2257
    MattLikesTacos
    Matthew
    SAWEEEEEEETTTTTT! Gonna have to tackle mine here in the next few days.
  18. Jul 20, 2016 at 9:52 AM
    #2258
    BeasleyNC
    BeasleyNC Well-Known Member
    Brad
    06 Tacoma Access Cab 4x4
    5100's on 884's , Wheelers Progressive AAL, GTA Carkit Bluetooth Adapter, WeatherTechs, Extang Solid Fold 2.0
    They aint 20's but I keep em clean tho!
    [​IMG][​IMG]
  19. Jul 20, 2016 at 10:20 AM
    #2259
    bubagump74
    bubagump74 SkiFreak
    Fred
    Montreal,Quebec
    2013 Trd OR
    NSA Pnl,US OFF ROAD winch mount bumper,Sirrius pods,Clazzio covers,Wheathertech mats, Pro Comp wheels,Image dynamics audio,leer cover,lights,bed mat,anti dark light...
    186
    I got these beauty for next season
    And this set up couple of years ago for light back country touring.
    they all have a function depending on conditions.
    cheers !
    jpmorrisvb[QUOTED] likes this.
  20. Jul 20, 2016 at 12:16 PM
    #2260
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    bluezzy my toy hauler is 19 ft 4" inches long coupler to rear door not counting spare tire. The box is only 16 ft 4" inches floor space inside is 14 ft.
    its a 2017 kz sportsman classic 19FKTH we love it! Its basic but suits are needs
    bluezzy likes this.
