Show off your Access Cab (Photos)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRICOMA, Feb 25, 2009.
  1. Nov 24, 2017 at 4:45 PM
    #3161
    SuazoYota
    SuazoYota Well-Known Member
    Spencer
    Southbay SD
    11 AC TRDOR 4X4 6SPD
    Not enough
    Badass Taco man!
    I'll choose yer truck over a boring Ford any day of the week.
    Key-Rei[QUOTED] likes this.
  2. Nov 24, 2017 at 6:08 PM
    #3162
    Rmkpower1
    Rmkpower1 Member
  3. Dec 1, 2017 at 9:54 AM
    #3163
    trdsport6
    trdsport6 Well-Known Member
    West NC
    2015 Super White access cab TRD
    bilstein 5100 @2.5 front and rear Method NV BFG KO2 275/70/17
    Anybody looking to get a prinsu rack?? Want to either sell mine or trade. Some things im interested in trading in are, aftermarket rear bumper, winch mount lower valence bumper and if anything else catches my attention I would be down. Heres some pics. IMG_4744.jpg IMG_4745.jpg IMG_4746.jpg
  4. Dec 1, 2017 at 9:57 AM
    #3164
    MIGYVER
    MIGYVER Member
    Carlsbad, CA
    2005 Toyota Tacoma
    3” front Lift, Softtopper, Power inverter, K&N, LED’s on front bumper, Ditch lights, 7” LCD Stereo, Alarm System, Job box and AirBoss air compressor, partial carbon fiber body wrap, carbon fiber mirror/ door handles/gas door overlays. Much more.
    What are you asking? I’ve been looking for one to go on my 05’ taco
    bluezzy and trdsport6[QUOTED] like this.
  5. Dec 1, 2017 at 9:59 AM
    #3165
    trdsport6
    West NC
    Pmd
  6. Dec 1, 2017 at 12:42 PM
    #3166
    amRRussel
    amRRussel A guy with a truck
    Andrew
    2011 Access 4banger 4x4
    Driver Mod
    So a little while back I notice I had a broken driver side leaf. The truck had the orginal 3leaf pack on, it did not have the TSB 4leaf pack. I thought about going to Toyota, but I decided instead of replacing, upgrade. I was planning on eventually getting a full suspension, most likely the beginning of next year after I got a few other things, but with the broken leaf I took the leap now. After installation I went behind the shop and 'tested' it to see how everything lined up and to make sure nothing was overly taut.
    I acquired EL095 package and b110's from Marie @Headstong off-road. Great customer service! Thanks again!
    I accompanied this setup with +4" brake lines from @OCTaco. Great lines, easy instillation, working great and looking good. Thanks again for the easy transaction!
    I acquired used 6112's from @LostHusker, good seller, easy transaction. Thanks again!
    I have a 2011 Tacoma 4cyl 4x4 with an ARE cap.T he 6112's are set on notch 3; driver side came with a 1/4" spacer, I left it on. The EL095 have OME poly bushings, 3* shims and wheeler's bump stops. This instillation was done 11/18/17, 13 days ago.
    Front Measurements:
    Before: Driver: 19 3/4" Pass: 19 3/4"
    After: Driver: 22 3/8" Pass: 22 1/2"
    Rear Measurements:
    Before: Driver: 19 3/4"" Pass: 20 1/4"
    After: Driver: 24" Pass: 24 1/2"
    *Please note: these measurements were taken with a full fuel tank.
    No vibrations to this point through all rpm and speed ranges.
    SuazoYota, robssol, Kmalloy and 3 others like this.
  7. Dec 1, 2017 at 1:10 PM
    #3167
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Is the only added weight out back your camper shell?
  8. Dec 1, 2017 at 1:54 PM
    #3168
    amRRussel
    Andrew
    Driver Mod
    I have a small tote of recovery and a few hand tools, 50lbs if I had to guess. I'm hoping the weight of the cap and the tote will help the springs settle in more. That being said, everyone else I have seen with this setup is sitting around 24' hub to fender as well.
    BassAckwards[QUOTED] likes this.
  9. Dec 1, 2017 at 2:10 PM
    #3169
    BassAckwards
    Interesting, thanks for the info. Ive been considering this setup for my truck as well. Ive got about 600lbs constant load though and i want to end up with 1.5 inches of lift..
  10. Dec 1, 2017 at 2:23 PM
    #3170
    Kmalloy
    Kmalloy Well-Known Member
    Orange County, California & Flagstaff, Arizona
    2014 4x4 TRDORACLB
    Diff. Breather Skids Rigid D2 Ditches Bed Lights Full Interior LED Husky Floor Liner Bed Stiffeners
    How much did all that cost you?
  11. Dec 1, 2017 at 2:51 PM
    #3171
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I'll be damned if I get any door dings:
  12. Dec 1, 2017 at 5:11 PM
    #3172
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    TOYOTA would (may still) reimburse at least partial cost of after market springs. If you can provide proof that the spring was broken they would most likely cut you a check since they are on recall. Got mine installed about a month ago.
  13. Dec 2, 2017 at 12:26 PM
    #3173
    amRRussel
    Andrew
    Driver Mod
    I was not aware of this. I will look in to it. Thank you for the info.
  14. Dec 2, 2017 at 12:29 PM
    #3174
    amRRussel
    Andrew
    Driver Mod
    I saved a lot getting the 6112's used. Just shy of $1,200 plus a case of beer and pizza for my two buddies who helped with the install.
  15. Dec 2, 2017 at 12:32 PM
    #3175
    amRRussel
    Andrew
    Driver Mod
    Dakar has the EL096 that is rated for that amount of constant load, however, they will raise the truck more than 1.5". You may want to contact deaver or alcan about a custom pack, but that will cost more than an off the shelf leaf pack.
  16. Dec 3, 2017 at 4:58 PM
    #3176
    Spintly
    Spintly Well-Known Member
    Greg
    Home of the Groundhog
    85 Single Cab Pickup & 2000 911
    Haven't posted in a while...
  17. Dec 3, 2017 at 5:12 PM
    #3177
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Nice truck
    BassAckwards likes this.
  18. Dec 3, 2017 at 5:13 PM
    #3178
    Spintly
    Greg
    Thanks. I bought it with 16K and now have 198K on it. It has been great.
  19. Dec 4, 2017 at 12:17 AM
    #3179
    gingertaco03
    gingertaco03 Well-Known Member
    Gabriel
    Quebec,Canada
    06 radiant red tacoma access cab sr5
    Will hit 250 000 km this week so i gave her a good clean. Build is still on going and will keep driving this truck till the wheels fall off.
    SpokoTaco, Bambino, NWMalGal and 8 others like this.
  20. Dec 4, 2017 at 7:53 AM
    #3180
    TacomaCody
    TacomaCody STOAA VIP Platinum Member
    Cody
    Iowa City, Iowa
    2012 Tacoma silver SR5 Off Road 4x4
    Body Armor 4x4 front bumper, running boards, cherry bomb vortex, 2" supreme suspension wheel spacers, Pro comp rock crawler wheels, 2017 off road full suspension, leer camper shell
    Which roof rack is that?! I'm in the middle of trying to build my own or buy one for my bed cap
