Show off your Cooper ST Maxx
Discussion in 'Wheels & Tires' started by Chux, Oct 4, 2014.
Do your Maxxs pull ?
  1. To the right
    236 vote(s)
    32.3%
  2. To the left
    20 vote(s)
    2.7%
  3. Neither, drives straight down the road
    474 vote(s)
    64.9%
  1. Jul 31, 2016 at 9:34 AM
    #2501
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I hear ya.. One day I'll make that jump. Its all planned out in my head. Lol
  2. Jul 31, 2016 at 10:50 AM
    #2502
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Looks like it... I understand they are for ice and snow but why put them in now? Will they even last until the snowy months?
  3. Jul 31, 2016 at 10:52 AM
    #2503
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Looks like I am going to wait til the 15th to order my tires. Just don't want to be broke lol.
  4. Jul 31, 2016 at 11:21 AM
    #2504
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Affirmative.
    Discount Tire told me that they, and most other shops, won't put them in unless they're brand new tires. Since the truck isn't my daily, I had them go ahead.
    One of my good friends runs the ST Maxx on his heavy-ass F-250 and commutes in to work daily from the mountains. He's had his since they were brand new, and his studs are still going strong after 20k miles.
    Comes down to individual choice, I suppose.
  5. Jul 31, 2016 at 11:30 AM
    #2505
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    265/75/16
    Chux[OP] and GreyFox Ind like this.
  6. Jul 31, 2016 at 11:38 AM
    #2506
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Gotcha. I just figured that the studs would be flat even after just a few thousand on dry pavement
  7. Aug 1, 2016 at 6:57 PM
    #2507
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    I started at 38psi and with a load range E tire it's way too much pressure. I dropped to 32psi and they feel tons better. I hear a chirp every once in a while on corners but nothing to complain about.
    Holy shit. How are you in the firewall that bad with 315's?
  8. Aug 1, 2016 at 8:48 PM
    #2508
    jubei
    NoCo
    Stuff. Also things.
    Haha! Well... I probably could have gotten by with less, but apparently this is on par with what Tim and Monte ended up cutting.
    I took so much because I borrowed some bumps from Tim that were cut to about half their normal height. That bought me plenty of margin with brand new tires, since I really don't want to EVER have to do this again.
    With the full stock bumps in, I have a good inch of clearance everywhere at full stuff and full lock. With the cut bumps I still have at least a quarter inch.
    Watt maker and MatthewMay1 like this.
  9. Aug 2, 2016 at 4:08 AM
    #2509
    Gramps
    Gramps
    07 TRD DC 4x4
    What bumps? The wheelers replacements? It just took cutting back the pinch weld and some hammer beating plus a CMC to fit my 315's. Without seeing it I can only assume but it sounds like your alignment is set up with your ture back in the firewall instead of away.
  10. Aug 2, 2016 at 4:25 AM
    #2510
    jubei
    NoCo
    Stuff. Also things.
    Stock bumps. The ones I borrowed from @TimF for the tubbing were stock that were cut to about half of their height.
    I'm a 1st Gen, FWIW.
  11. Aug 2, 2016 at 4:55 AM
    #2511
    cynicalrider
    cynicalrider #NFG
    Jersey
    First gen's need to tub.
    @jubei777 were you in the body mount at all? I had to cut mine back quite a bit too.
  12. Aug 2, 2016 at 5:12 AM
    #2512
    Gramps
    Gramps
    07 TRD DC 4x4
    Ah shit. Sorry. 1st gen.
  13. Aug 2, 2016 at 5:43 AM
    #2513
    jubei
    NoCo
    Stuff. Also things.
    Yep. Driver and passenger side, and both the frame and body sides of the mounts. Not a whole lot, but about as much as what's in your picture.
    1st Gen problems.
  14. Aug 3, 2016 at 12:47 PM
    #2514
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    ST-Maxx review:
    The ride is a little harsher/stiffer than my previous Michelins, but those were street tires. I kept the 255-85/R16 ST-Maxx's at 35 PSI during the long highway trip to and from the Toyota Takeover (183 highway miles) for slightly better fuel mileage (not much better.)
    The truck came off of overdrive into 4th gear frequently on long uphills on the highway. I decided to just lock out OD completely when I came across these uphill sections. I don't think its a function of weight or load range E. Likely because they are taller tires. This is not enough of an issue to me to make me want to re-gear, because I felt that the truck had plenty of power to navigate through some of most crazy ass off-road terrain that I've ever encountered. Steep, high angle, off-camber, rocks, boulders, ditches, deep water, mud. You name it, the tires did fantastic. The tread traction was very good on slippery, rain covered rocks/boulders. Handled and cleared mud extremely well.
    For day-to-day driving, 30-32 PSI seems to be a much more comfortable ride.
    On the extreme off road trails of Rausch Creek Off Road Park, I initially started at 18 PSI, then looked at all the crazy shit we were going to do. So I dropped down to 15 PSI when I saw @cynicalrider attempting to crawl up a rocky cliff. The aired down tires were INCREDIBLE at molding around rocks, stumps and holes. The sidewalls were nice and flexible but appeared to support the tire carcass well. Traction was FANTASTIC. The sidewalls did encounter some major battles with rocks and tree stumps. But the sidewalls with the aggressive side tread pattern didn't bat an eyelash.
    I carried two extra spares, thinking I might blow a sidewall or blow a bead off. None of that happened.
    I'd buy them again, if I ever get to wear it down. That's gonna be a long while, because it's on a six tire rotation and I still have a good set of Michelins that I can and will switch into the rotation for DD use.
    Home:
    Water: Photo Credit @cynicalrider
    Rocks: Photo Credit @HolyHandGrenade
    Rain:
  15. Aug 3, 2016 at 1:50 PM
    #2515
    cynicalrider
    cynicalrider #NFG
    Jersey
    Nice write up Lloyd!
    Subway4X4 likes this.
  16. Aug 3, 2016 at 9:04 PM
    #2516
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Lloyd you can also do the chalk test on your tires to find the PERFECT PSI to run them at. Draw a line roll about 10 feet get out and see how the lines wore off... @chris4x4 has a good write up about it I think in his signature
    Subway4X4[QUOTED] and chris4x4 like this.
  17. Aug 5, 2016 at 2:13 PM
    #2517
    TBuzz
    TBuzz Well-Known Member
    Colorado
    00' 4runner, No Longer Stock
    Bumpers, Sliders, 33's, ADS f&r, budbuilt, home built belly and bumper, s/c, urd,4.88, arb's
    This little guy and my certificates just got me a set of replacement 285's for $345.03 OTD.
  18. Aug 5, 2016 at 2:57 PM
    #2518
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    daaaaaaamn.. did they just prorate the tires and buy them back?
  19. Aug 5, 2016 at 3:46 PM
    #2519
    TBuzz
    Colorado
    One was full replacement with a certificate...one was my spare which is/was still new....the front two they prorated for $111 each. I had to buy two certificates in the transaction. So I'm running new tread in 4 corners and kept my best old tire with 10/32 for a spare all with certs. I'll probably cough up money for a new spare soon so I can do that again if it happens.
  20. Aug 5, 2016 at 4:42 PM
    #2520
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    nice. I used one Cert for my previous tires (ATII's).. and got them again with the Maxx's.. hoping I can work a deal with them for new tires down the road, same as you.
