Show off your Cooper ST Maxx
Discussion in 'Wheels & Tires' started by Chux, Oct 4, 2014.
Do your Maxxs pull ?
  1. To the right
    236 vote(s)
    32.3%
  2. To the left
    20 vote(s)
    2.7%
  3. Neither, drives straight down the road
    474 vote(s)
    64.9%
  1. Jan 31, 2018 at 2:33 PM
    #4701
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Beautiful. Can’t read the size but the f5’s look like the new 3.5 back spacing?
    fatfurious2[QUOTED] likes this.
  2. Jan 31, 2018 at 2:34 PM
    #4702
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Half installs don’t count :p
  3. Jan 31, 2018 at 2:39 PM
    #4703
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    This was a test fit. As you can see, I only have 3 lug nuts holding it on. But yes, 16x8, 3.5BS, and 315/75/16 ST Maxx
  4. Feb 1, 2018 at 3:40 PM
    #4704
    atxboug
    atxboug Well-Known Member
    Tim
    Austin, TX
    2017 Tacoma DCSB TRD OR
    OME Nitrochargers/HD Dakars/Cooper ST Maxx/Alu-Cab Canopy/James Baroud RTT
    50 and 40 are still way to high for a stock set-up... My rear-end is loaded down more (500lbs+ for RTT, Canopy, gear), so I can get by with a slightly higher PSI as the load 'flattens' the tire more. Cooper recommended 30PSI just as placarded on the inside of the door; for a stock Tacoma. I'm getting 16-17MPG at best; RTT, Prinsu rack, load-out and Lucas diff fluid don't help the fuel economy.
  5. Feb 1, 2018 at 4:07 PM
    #4705
    TACOMAGARCIA
    TACOMAGARCIA CHECKOUTTHAT4X4
    JOEL
    2009 DC TACOMA TRD SPORT 4X4 DARK GRAY
    LEVELING KIT; TOYO TIRES A/T
    Just fueled up and i got 16.3 mpg but with new 255/85/16 st maxx on for 100 of the 200 miles
  6. Feb 2, 2018 at 1:40 PM
    #4706
    dnpbakon
    Kevin
    285/75/16 Cooper ST Maxx
    SCS f5’s 4.5 BS
    King 2.5 with Resi all around
    Total chaos uppers
    Wheelers 3 leaf progressive AAL
  7. Feb 2, 2018 at 1:42 PM
    #4707
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    How's that Wheelers 3 leaf progressive AAL working out for you?
    dnpbakon[QUOTED] likes this.
  8. Feb 2, 2018 at 1:44 PM
    #4708
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Sounds about right. Where in the country are you?
  9. Feb 2, 2018 at 1:51 PM
    #4709
    dnpbakon
    Kevin
    Great so far. With the topper which is about 200lbs, I’ve had no issues. I’ll upgrade to a Deaver down the road but for now it’s great. I left the overload in aswell
    jackn7[QUOTED] likes this.
  10. Feb 2, 2018 at 2:06 PM
    #4710
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    @dnpbakon, how much trimming to get those to fit? Any rubbing on the cab mount?
    I have the same spec F5s and I'm trying to decide on a tire size...
    dnpbakon likes this.
  11. Feb 2, 2018 at 2:08 PM
    #4711
    dnpbakon
    Kevin
    As of right now, no trimming at all. Street driveable for sure. I will be trimming the rear of the fender, and a CMC because I will be wheeling often. But also depends on your allighbment
  12. Feb 2, 2018 at 2:40 PM
    #4712
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    255/80r17s on 4Runner 17x7 +15 wheels. Not sure I like them yet.
  13. Feb 2, 2018 at 4:06 PM
    #4713
    dnpbakon
    Kevin
  14. Feb 2, 2018 at 5:27 PM
    #4714
    wingspar
    wingspar Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    I finally replaced my 265/70/16 AT3's with some 265/75/16 ST Maxx’s. Not much of a comment on them yet. They put 40 psi in them. That’s probably too much. Real harsh ride on pavement but nice on gravel logging roads where they will spend most of their time. Thinking of doing the chalk test.
  15. Feb 3, 2018 at 8:50 PM
    #4715
    dnpbakon
    Kevin
  16. Feb 4, 2018 at 1:19 PM
    #4716
    Triggerhappy
    Triggerhappy Well-Known Member
    Jake
    Denver
    2019 T4Runner ORP
    It never ends
    Can’t decide on 285/70/17 or 255/80/17. Currently running 255/70/17 BFG MT’s. Awful cupping with frequent rotation and balancing.
  17. Feb 4, 2018 at 1:24 PM
    #4717
    replica9000
    2019 T4R ORP
    Where have you seen 255/85r17?
    TACOMAGARCIA likes this.
  18. Feb 4, 2018 at 1:27 PM
    #4718
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    After running these two sizes, the 255 wins in every category except looks. While the 255 still look great, the 285s poking out look even better. With that being said I'd pick 255s over 285s all day.
    Probably just a typo.
  19. Feb 4, 2018 at 2:07 PM
    #4719
    replica9000
    2019 T4R ORP
    Too bad, they'd be 34's, and I'd try them.
    The 255's definitely feel better on-road. Waiting to see how they are in snow and off-road.
    EatSleepTacos[QUOTED] likes this.
  20. Feb 4, 2018 at 2:10 PM
    #4720
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Agreed. I'd love a tall and skinny 34, or even a 35. They make KO2s in 34x10.5 which is a size I'd love to see more tires in.
    mikestaco17 and TACOMAGARCIA like this.
