Show off your Cooper ST Maxx
Discussion in 'Wheels & Tires' started by Chux, Oct 4, 2014.
Do your Maxxs pull ?
  1. To the right
    236 vote(s)
    32.3%
  2. To the left
    20 vote(s)
    2.7%
  3. Neither, drives straight down the road
    474 vote(s)
    64.9%
  1. Nov 19, 2018 at 1:14 PM
    #5361
    medjah
    medjah Volleyballing
    Blake
    Austin, TX
    09 Barcelona Red DCSB SR5 TRD OR
    OME 887 Springs OME 90000 Shocks OME Dakar Light Duty Leafs Wheelers SuperBump Bumpstops w/ u-bolt flip Sway Bar relocate Red Brake Lines Ultimate Headlight Upgrade Airflow Snorkel Rear diff breather mod CMC AtTheHelm Bed Stiffeners AtTheHelm Front Rail Chock System Hood Struts
    2009 doesn't have a readout so I do pretty simple math every now and then at fill up. :D:p
  2. Nov 19, 2018 at 1:20 PM
    #5362
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    With no tune yes but depends on the size - the bigger/wider the tire the more dramatic the drop. It will drop and the drop is more dramatic if you sit in a ton of stop and go traffic as it takes more to get these taller heavier tires moving. You will notice it around town and on the highway at least at altitude since your 2 over drive gears just got even taller. But these tires have been great for me so far in Colorado, Utah.
    medjah and InfernoChalupa like this.
  3. Nov 19, 2018 at 1:26 PM
    #5363
    medjah
    Blake
    Austin, TX
    I believe my biggest reason for the MPG drop is the weight of my much larger tire. It is a lot of unsprung weight.
    From 42lbs per tire to 58 lbs
    PreTaco170 likes this.
  4. Nov 20, 2018 at 4:12 AM
    #5364
    Wild Crow
    Wild Crow Well-Known Member
    James
    Anywhere is home
    2014 Baja
    Best price ive seen so far for the 255/85/16. These were $238 just two days ago. Walmart dot com. Free shipping to the store of your choice....Screenshot_20181120-070751.jpg
    boostedka and medjah like this.
  5. Nov 20, 2018 at 5:25 AM
    #5365
    medjah
    Blake
    Austin, TX
    That is a great price. I was able to talk Discount to $203 per tire when I bought my set of 5.
  6. Nov 20, 2018 at 5:58 AM
    #5366
    jon.e.b3030
    jon.e.b3030 Well-Known Member
    john
    If you have a mavis near you go talk to them. They must have a lot of wiggle room on price, depending on who wants to. I was told 230 each at first then he said let me see what i can do , ended up 680 ish out the door, dismounted(had set of tires n rims off the truck)mounted, balanced, stems, taxes,enviromental fees(used tires) they were 255/85 16.
  7. Nov 20, 2018 at 6:01 AM
    #5367
    medjah
    Blake
    Austin, TX
    :eek::eek::eek::eek::eek:
    That is a steal for 4 tires!
  8. Nov 20, 2018 at 6:07 AM
    #5368
    jon.e.b3030
    john
    ... couldnt pull cash out fast enough! Like i said, go talk to them, they wont advertise that price but if you get a cool mgr u may get lucky
    medjah likes this.
  9. Nov 20, 2018 at 6:31 AM
    #5369
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    InfernoChalupa likes this.
  10. Nov 20, 2018 at 6:36 AM
    #5370
    amRRussel
    amRRussel A guy with a truck
    Andrew
    2011 Access 4banger 4x4
    Driver Mod
  11. Nov 20, 2018 at 7:58 AM
    #5371
    boostedka
    James
    NM
    amRRussel[QUOTED] likes this.
  12. Nov 20, 2018 at 9:19 PM
    #5372
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
  13. Nov 27, 2018 at 6:48 AM
    #5373
    Wild Crow
    James
    Anywhere is home
    2014 Baja
  14. Nov 27, 2018 at 7:48 AM
    #5374
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    got mine coming this week.........thx DTD Black Friday sale !
    :bananadance:
    medjah likes this.
  15. Nov 27, 2018 at 6:56 PM
    #5375
    Wild Crow
    James
    Anywhere is home
    2014 Baja
    Done! 255/85r16s! $1300 dollars for 7 (yes, 7 - I had to get a matching pair for my teardrop!) mounted and balanced. Rolls quiet and smooth!
  16. Nov 27, 2018 at 8:41 PM
    #5376
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    I found mine were quiet until about the 2,000-3,000 mile mark. They hum pretty good but nothing like a true mud tire though.
  17. Nov 28, 2018 at 3:03 AM
    #5377
    Wild Crow
    James
    Anywhere is home
    2014 Baja
    Quiet is relative of course. These are much better than the worn out BFG ATs that they replace. I'm not new to the ST Maxx experience, this is just the first set for this Tacoma
    saundern[QUOTED] and Casper66 like this.
  18. Nov 28, 2018 at 3:25 AM
    #5378
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    God knows never change the direction of rotation on these tires. The dealer did in my 2 fronts when they did an alignment and the wore funny. I changed them back with this last rotation and they are finally starting to quiet down a little. I may go get those 2 balanced and see if tgat helps at all
  19. Nov 28, 2018 at 6:47 AM
    #5379
    Wild Crow
    James
    Anywhere is home
    2014 Baja
    Never had that problem. Ive always crossed the fronts to the back on rotations. The two sets on the tundra wore flat and even. Hopefully these will do the same
  20. Nov 28, 2018 at 6:52 AM
    #5380
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Left front to left rear.
    Left rear to right front
    Right front to right rear
    Right rear to left front
    Armed in Utah and Casper66 like this.
