Show off your Cooper ST Maxx
Discussion in 'Wheels & Tires' started by Chux, Oct 4, 2014.
Do your Maxxs pull ?
  1. To the right
    236 vote(s)
    32.3%
  2. To the left
    20 vote(s)
    2.7%
  3. Neither, drives straight down the road
    474 vote(s)
    64.9%
  1. Sep 10, 2020 at 6:19 AM
    #5901
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Ahh, well, I could be wrong but I believe these are non-directional.
  2. Sep 10, 2020 at 7:49 AM
    #5902
    EchoDeltaSierra
    EchoDeltaSierra Well-Known Member
    Georgetown, TX
    2020 TRD Off-Road
    Nitro 4.88 gears OME suspension ST/Maxx 255/85R16s
    They are non-directional.
    RobP62[QUOTED] likes this.
  3. Sep 10, 2020 at 8:26 AM
    #5903
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Well there ya go, Bob's your uncle.
    Hey, in case I haven't said it yet, Thanks for your service! :oldglory:
  4. Sep 10, 2020 at 8:46 AM
    #5904
    Swizz
    Swizz Well-Known Member
    19 TRD OR DC
    Awesome, thanks for the feedback. Stoked to throw some new shoes on but don’t think I rep hard enough to show the white lettering....lol.
    RobP62 likes this.
  5. Sep 10, 2020 at 8:49 AM
    #5905
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Honestly, I've had white letters out in the past and it requires some work to keep them looking good.
  6. Sep 11, 2020 at 7:18 AM
    #5906
    Rory0802
    Rory0802 New Member
    Rory
    2020 Tacoma TRD OR
    Soft topper, ST Maxx
    Got some 265/75r16s put on. I tried searching but couldn't find much. What pressure do you all run yours at? Mine is at 43/44 psi and is a wee bit stiff. Don't really want to wear the center tread too fast either.
    ready6delta, Swizz and RobP62 like this.
  7. Sep 11, 2020 at 8:11 AM
    #5907
    pdxtrdtaco1874
    pdxtrdtaco1874 Well-Known Member
    Bob
    Portland, OR
    2019 MGM TRD Off Road DCSB M/T
    I run the same size at 35 psi all the way around. Heats up to about 40 psi. Put about 3000 miles on mine and haven't noticed any wear issues. Time will tell.
    Swizz, RobP62 and Rory0802[QUOTED] like this.
  8. Sep 11, 2020 at 8:49 AM
    #5908
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Welcome to the best damn Tacoma forum on the interwebs Rory! :hattip: Thank you for your service :oldglory:
    I would try like @pdxtrdtaco1874 said and drop them down to 35psi. That's about where I run mine, because they heat up to 38psi quick.
  9. Sep 11, 2020 at 9:02 AM
    #5909
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I chalk tested my tires, they like 33psi cold even with all my added weight to the truck.
    The also like 19psi dirty.
    :mudding:
    285-75-17 flavor and you need to chop a lot, even more than with 33's had to re-chop my chopped cab mount chops and cut my fenders.
    Also had to put 3/16" spacer on my front bump stops to keep them from topping out in the engine bay metal inner fender. (Not the fender liner that's been long gone.)
    I have about +2° of forward caster, and I need more, currently at full lock-bump-compression they hit the cab even with the pinch weld flattened.
    I still get stuck but they ride and climb so much better than the KO2's I had, and surprisingly they're quieter and better in the rain.
    Kinda mad at BFG for dropping the ball on the KO2's.
    First time going with something other than BFG/Michelin on anything I own, glad I did!
    :thumbsup:
    Pictures are from the first time I really got to "play" with them and I have to say I was very impressed.
    IMG_20200902_142155.jpg IMG_20200902_114709.jpg IMG_20200902_130340.jpg IMG_20200902_194229.jpg IMG_20200902_194005.jpg
    ready6delta, RobP62 and Minny Taco like this.
  10. Sep 11, 2020 at 9:38 AM
    #5910
    Swizz
    19 TRD OR DC
    Seeing as how we are trending black Tacoma's at the moment might as well add to the mix. Sadly I just had the truck detailed 3 days ago. It looked really clean for about three hours and then the skies opened up for three days, the struggle is real...
    265 75 16's. Looks better in person and drives well. Seems to be tracking straight but I only have 10 miles on them. Plenty of room in the wells to clear the mudflaps and no rubbing.
    Have some 17 inch Ray 10s that I decided not to mount. I did rethink for a moment but Im happy with the stock appearance.
    ready6delta and doublethebass like this.
  11. Sep 11, 2020 at 11:23 AM
    #5911
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    There is a black vinyl kit out there for stock wheels that make them look really good. Also if you pull the mud flaps off it really cleans up the truck
  12. Sep 13, 2020 at 9:55 AM
    #5912
    Swizz
    19 TRD OR DC
    So after driving around more I do have some rubbing on my mudflaps but I am rocking Rexgen aftermarkets and they don’t really contour to the wheel well. Probably wouldn't happen on the stock ones.
    I'll have to trim the inside but I don't see it being an issue.
  13. Sep 13, 2020 at 9:58 AM
    #5913
    Swizz
    19 TRD OR DC
    Hear that. I do like the look without mudflap but prefer the paint protection the flaps provide.
  14. Sep 14, 2020 at 4:10 PM
    #5914
    sdheda
    sdheda Well-Known Member
    Sergio
    HB, Ca
    '10 TRD OR 4x4 DC
    In progress :/
    I have Cooper ST Maxx's on my truck. I see cracking around the treads and bead. Is it time I replace them? They still have a lot of tread left. The date code on them appears to be 1512.
    20200914_145939.jpg 20200914_160100.jpg 20200914_160216.jpg 20200914_145810.jpg
  15. Sep 14, 2020 at 4:47 PM
    #5915
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    That tire is 8 and a half years old. I’m sure NHTSA has recommendations on the matter if you’re worried.
  16. Sep 15, 2020 at 6:37 AM
    #5916
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    It’s becoming a tradition to run the ORV route in Cape Cod each September. Last year I had KO2s, this year STT Maxx. Despite the KO2’s being “Baja Champions”, the Coopers dig significantly better. Point the front wheels and add throttle got the truck over any dune or out of any rut. The KO2s really struggled getting out of tracks and really wanted to tramline, STTs are point and throttle. The high head dune pictured was a little bit of a challenge on the KO2s last year. I had to make two passes at it. This year I came over the top with disappointingly little struggle.
    634596DE-7C8E-412B-B198-3137E026A77D.jpg DC26EE7B-D72F-4E5C-81C1-6C64437EDC4D.jpg
  17. Sep 15, 2020 at 6:46 AM
    #5917
    Swizz
    19 TRD OR DC
    what do you run the PSI at on da’ beach?
    ready6delta likes this.
  18. Sep 15, 2020 at 6:46 AM
    #5918
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    15lbs
  19. Sep 17, 2020 at 5:36 AM
    #5919
    Swizz
    19 TRD OR DC
    What the heck is the chalk test?
    RobP62 likes this.
  20. Sep 17, 2020 at 7:28 AM
    #5920
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    It’s a method to determine the most appropriate air pressure for your specific vehicle.
    This is one of hundreds of examples:
    https://m.youtube.com/watch?v=MIvbFgrH0IQ
    TopQuark, Hutch72, RobP62 and 2 others like this.
