Show off your Cooper ST Maxx
Discussion in 'Wheels & Tires' started by Chux, Oct 4, 2014.
Do your Maxxs pull ?
  1. To the right
    236 vote(s)
    32.3%
  2. To the left
    20 vote(s)
    2.7%
  3. Neither, drives straight down the road
    474 vote(s)
    64.9%
  1. Sep 27, 2022 at 2:22 PM
    #6041
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    I spoke with Cooper this morning, both the Cooper STT Maxx and the STT pro (at least for the few sizes I checked) are still showing as in production and a few sizes have plenty available. Unfortunately I cannot speak for every size but I am happy to check availability if someone is looking, feel free to shoot us a pm and im happy to look.
    @Hilborn If we may ask, which sizes were you seeing on our site as discontinued?
    JoeT4R[QUOTED] and doublethebass like this.
  2. Sep 27, 2022 at 2:35 PM
    #6042
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Two sizes show here. Downsized for other reasons :anonymous:
    Road Bull and JoeT4R like this.
  3. Sep 27, 2022 at 4:16 PM
    #6043
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    I know it said they were Discontinued this morning when I looked them up. Now it shows they are stocked like normal. Stop playing with my emotions.
  4. Sep 27, 2022 at 5:11 PM
    #6044
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I almost panic bought a set of each to stick in the shop for when its time. Don't do that to me.
  5. Sep 28, 2022 at 9:44 AM
    #6045
    Discount Tire
    Arizona, USA
    It's possible something got miss labeled and then corrected. For now I think we are safe and we should be able to get both of these tires for a while.
    If you would like us to double check a specific size feel free to shoot us a PM we can confirm they are still available and in production.
  6. Oct 11, 2022 at 7:30 AM
    #6046
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I'm selling my 33's if anyone is in the market.
    doublethebass likes this.
  7. Oct 28, 2022 at 7:46 AM
    #6047
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    Got these mounted on the truck yesterday :D
    265/75/R16 on OEM rims
  8. Nov 8, 2022 at 1:10 PM
    #6048
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Im getting ready to order these tires (255/85/r16) and I need to know, how good is the deep snow, ice traction? I will be driving on lakes alot this winter for ice fishing and getting up and down the boat ramps can be hard when they are iced over or covered in snow.
  9. Nov 8, 2022 at 1:39 PM
    #6049
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I’ve got that size on my truck - and I just put on my Blizzaks for the year if that tells you anything. Great tire, just not for MN winters.
    Deep snow out in the woods they’ll do great. Winters on the road out here they’re not the tire you want on the truck. A couple years I was a little late getting the Blizzaks on and I’ve since made a point to never let that happen again.
    Have you looked at other ATs that are 3PMS rated if you just want a one-and-done tire? After these Coopers wear out I’m going to try the Mickey Thompson Baja Boss AT. They don’t come in 255/85/16 but they do run 255/80/17 and 285/75/16 to get the full 33”….and they have 3PMS unlike the ST Maxx. Cooper makes Mickey Thompson, so there’s a confidence factor there too. I’ll still run winters though (gonna try Hakkas).
    my 2c
    :cheers:
  10. Nov 8, 2022 at 1:59 PM
    #6050
    5nahalf
    Erik
    Minnesota
    The vast majority of my driving is either clear roads with no snow, or on a lake/deep snow trail for fishing. I was going to go with snows, but I just dont do enough onroad snow driving to deal with the wear. My wifes truck has snows (but thats because she is a bad driver). I had snows on my rav4, snows on my awd BMW, and they were all great considering good traction tires were very limited for those cars.
    My other options were the geolander mt g003 tires. I liked that they are 8lbs lighter then the coopers, and they have a slightly better snow rating. But the tread being more aggressive im not sure if my on road driving is going to suffer
    doublethebass[QUOTED] likes this.
  11. Nov 8, 2022 at 4:15 PM
    #6051
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Could you get away with a different light Cooper? Like the AT3 4S? Don’t remember what 33 sizes those come in. If not, I’d pick anything with a better snow rating than the ST Maxx. They harden up quick below freezing.
    5nahalf[QUOTED] likes this.
  12. Nov 8, 2022 at 4:24 PM
    #6052
    5nahalf
    Erik
    Minnesota
    Thats what I need to know. I think I might just go with the geolanders.
  13. Nov 8, 2022 at 4:32 PM
    #6053
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I think that’s a safer bet
  14. Nov 9, 2022 at 5:08 PM
    #6054
    TacomaGuy7878
    TacomaGuy7878 Mmmm....Tacos
    CO Mountains
    2020 AG Pro
    I've ran these tires in this size for the past few years, year around and live at 9600 ft in the mountains, we have snow on the ground probably 6 months a year. They do great in deep snow and fresh snow but are terrible on ice and OK on hard packed snow. I just drive a little extra careful when stopping on ice, that's the only time I ever wish I had dedicated snow tires. You didn't ask about summer but they kill it in mud and 4 wheeling. I'd like to say I've never had a flat on em which I hadn't but got a nail in one literally yesterday! They are pretty quite the first 10-15000 miles but continue to get louder as they age if that stuff bothers you, I don't mind the noise:notsure: my lady is from Minnesota and I've driven them up there a couple times during winter and didn't have any problems FWIW:thumbsup: I agree with @doublethebass, not the best tires for MN winters, I make them work but hardly get above 50 mph where I live/work
  15. Aug 22, 2023 at 8:05 AM
    #6055
    Hilborn
    Michael
    Utah
    I have used a ST Maxx 285/70-17 on my Tacoma since July 2018. In that amount of time I have driven cross country several times, overlanded in Capitol Reef, ran Black Bear, Imogene, Ophir, Engineer in Ouray/Telluride and even completed Top of The World in Moab this last April after all the Jeeps beat the hell out of it during Easter Jeep Safari. I have taken hits to the side walls without experiencing a flat. I have gotten even wear due to that I have them rebalanced yearly, rotate every 5k and keep the pressures in their sweet spot when on highway. I have looked at other tires that manufacturers like Falken and Toyo have released under the Rugged destination. After doing my research, I can honestly say those tires are not as good as the ST Maxx. The 285/70-17 weight 60 lbs. Toyo's weight 56 lbs. Falken's weight 65 lbs. Neither have 3 ply side walls. I have even been tempted to go to the STT Pros and I can say that move would be pointless. I would be giving up a lot of my on road comfort for a small increase in mud traction. The mud traction on the ST Maxx isn't as good as the STT Pros but for what I do and what I have done. I believe they are as good as we are going to get to a perfect overland tire on today's market. Just my 2 cents.
  16. Aug 27, 2023 at 6:18 AM
    #6056
    NorthCountryTRD
    NorthCountryTRD Well-Known Member
    Patrick
    New Hampshire
    2015 Tacoma TRD Off Road V6 Manual
    Current Mods: - Locking Lug Nuts - Weather Tech floor Liners - N-Fab light bar - 32” Led Light bar - TRD skid plate - Leer Cap (Pyrite Mica) - Rigid TSM-22 Tow Strap Shackle Mount - Rigid Orange Shackle - @ACEkraut License plate bracket - Flashwolves LED reverse bulbs - TRD Stainless Cat Back - AFE Pro Dry S drop in filter - Glove box organizer - Center Console organizer - Bed Stiffeners - Color match grille - Custom Car Grills Perf SS Mesh flat black - Thule Cap roof rails - TRD PRO Suspension - Wheelers 2" Add a Leaf - HS 1/4 inch strut spacers - SCS Ray 10's in Brushed Copper - Cooper Maxx St's 275's - Under hood Led Light Kit Future Mods (as of right now): - 20inch LED Bar (Caliraised,Rigid, Baja) - 32inch LED Bar (Caliraised,Rigid,Baja) - LED Pods Side Projecting (Caliraised, Rigid) - Toyota Bed Matt - Quick fist Axe and Shovel mounts in Truck Bed - Cap mounted Awning - 100% No Drill Bolt on sliders - Wet Oak Seat covers (All black with TRD in them) - VooDoo Bed Bars/Basket that works under a cap
    I Could not agree more! I have been nothing but happy with mine. I'm running 275's. I did a bunch of research ahead of time and everything lead me to the ST Maxx's. I rotate mine around every 5k miles as well and they have held up very well.
  17. Oct 3, 2023 at 3:03 PM
    #6057
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Hey all. I’m looking for some input from those of you who have run the St Maxx’s for a while. My Grabber ATXs are getting towards the end of their life and after a ton of research the ST Maxx’s are at the top of my list.
    My question…My use case is a lot of highway miles (like 30K a year) with a pretty good amount of dirt and gravel trails mixed in…Would you all recommend the ST Maxx for that type of driving?
    I know they’re fantastic off road. I’m a little concerned based on the mixed on-road reviews. I’d say my split is 70% on road, 30% off road. I do need an E rated tire based on the type of trails I do. My grabbers are E rated and have saved my bacon more than once.
  18. Oct 4, 2023 at 12:45 PM
    #6058
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    And your name is ROAD Warrior?? If you really drive 30% off-road then you are in the 0.1% of members here and are asking in the wrong place. Most of us here should just be on road tires lmao!
    Now with that stated, I have the ST Maxx and like them, but I’m not gonna pretend I am truly off-road 30% of the time :)
    Road_Warrior[QUOTED] likes this.
  19. Oct 4, 2023 at 2:30 PM
    #6059
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    lol it’s just an estimate! I drive all over the US and Canada and do a bunch of trails in the middle of all those trips so it changes from month to month. I live in Maryland but I’m actually in Canada at the moment. The truck and I also went to Montana earlier in the year. Just a couple examples.
    I appreciate the input!
    Discount Tire likes this.
  20. Oct 11, 2023 at 7:00 PM
    #6060
    Hilborn
    Michael
    Utah
    Get the Coops.
    Road_Warrior likes this.
