Show off your custom exhaust work
Discussion in 'Performance and Tuning' started by ONALL4, Aug 21, 2013.
  1. Aug 21, 2013 at 7:41 PM
    ONALL4
    ONALL4 [OP] Well-Known Member
    Frank
    Toronto Canada
    2004 V6 4X4
    I replaced the old rusted oem muffler with Solo performance exhaust single in dual out. I chose the stealth series which is the most quiet but still louder than oem plus the tips so I can hear abit of deep growl and the noise disappear in the highways. The muffler is made by solo performance which is a Canadian company in Mississauga Ontario. Nice and tucked in up there better for off-roading.
    http://solo-performance.com/stealth-muffler-series
  2. Aug 21, 2013 at 7:45 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Subbed... I gotta little sum sum up my sleeve so I should have a nice contribution here if all goes to plan
  3. Aug 21, 2013 at 8:44 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I like this thread. :thumbsup:
  4. Aug 22, 2013 at 6:48 AM
    ONALL4
    Frank
    Toronto Canada
    2004 V6 4X4
    Any hint on your plan? I saw a black chrome tip on motorcycle that would be awesome on taco
  5. Aug 22, 2013 at 8:26 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The N/A setup
  6. Aug 22, 2013 at 8:56 PM
    memario1214
    Colton
    Missoula, MT
    ^^^ Something very similar to this
  7. Aug 23, 2013 at 7:42 AM
    ONALL4
    Frank
    Toronto Canada
    2004 V6 4X4
    I am still new to this exhaust mod, what's an N/A setup? no cats and muffler? I've seen a RX 7 with only silencer and fake muffler... I can definitely smell gas fume
    Are there alot of cops doing inspection for modified exhaust in your state?
  8. Aug 23, 2013 at 8:40 AM
    memario1214
    Colton
    Missoula, MT
    N/A = Naturally Aspirated aka not a boosted (supeecharger or turbo) application
  9. Sep 5, 2013 at 12:22 PM
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
    Stay Tuned...........
  10. Sep 6, 2013 at 10:46 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    This is the only kind of custom exhaust work I'm capable of doing... ;)
    http://www.youtube.com/watch?v=aI1jzAfEphM
    You can hardly hear it unless your head is right under the truck. The stock muffler also provides enough backpressure to retain the low end torque.
  11. Sep 12, 2013 at 8:09 AM
    SpaceBalls
    SpaceBalls Active Member
    Vancouver Canada
    08 Taco trd
    3" block lift 33" BFG's AT
    zeburu7y_18b72d1e314696d99ee4e4405ba1ca39ece9245e.jpge4uqe3yp_e8fbd6b3881da20ac860fcc98397a302fc31b4d9.jpgpurehugy_3008f5b7da04ffddedb4548dfa4a8cdeb4c65f25.jpgqegasata_aeea3584a6bf1a868eefa007913b23da100fd145.jpg
    Long tube headers DT
    Y pipe DT
    Had a flow master cat back and cut out the new muffler cause it was too loud and tig welded in a master flow. Got the biggest one i could and its still loud!!
  12. Sep 12, 2013 at 8:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Magnaflow has a 32" long bad boy. That would tone it done. ;)
  13. Sep 12, 2013 at 9:51 AM
    memario1214
    Colton
    Missoula, MT
    Trying to buy a house.. this is on the back burner for a bit
  14. Sep 12, 2013 at 10:06 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I hope StillWill stops in here!
  15. Sep 12, 2013 at 10:15 AM
    TACO FOR LIFE
    TACO FOR LIFE Well-Known Member
    Seth
    texas
    07 PreRunner
    So has any one done a cut off exhaust set up. i was just told about this from a friend and im wondering if it would work.:confused: basically a Y pipe but with different exaust on each side that you can switch back and forth. i was hoping to do one side with straight pipe and one side stock?
  16. Sep 12, 2013 at 10:29 AM
    memario1214
    Colton
    Missoula, MT
    Toon had an electric cutout I remember. I can't remember the scenarios in which it was open/closed though
  17. Sep 12, 2013 at 10:51 AM
    SpaceBalls
    Vancouver Canada
    08 Taco trd
    That sounds really weird! Why would you want an unbalanced exhaust?
  18. Sep 12, 2013 at 11:03 AM
    imsikotic
    Randy
    Temecula, Ca
    Got mine done last weekend. My buddy builds his from Stainless Steel. Gotta admit he did an awesome job. Sounds awesome and I got a little boost when I tap the gas. My friends name is Keith and owns BAmufflers He's located in SoCal (Escondido,Ca)
    http://youtu.be/GSkCGRXIqww
  19. Sep 12, 2013 at 11:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pretty certain he is referring to an exhaust cut-out.
    Edit*** Imsikotic -is that ceramic coated, powder coated, or high temp paint? Either way it looks good.
  20. Sep 12, 2013 at 12:02 PM
    imsikotic
    Randy
    Temecula, Ca
    High Temp Paint
