Show off your diode dynamics!
Discussion in 'Lighting' started by Lightingsearcher, Jul 27, 2021.
  1. Jul 28, 2022 at 11:05 PM
    #321
    6mtTRD
    6mtTRD Well-Known Member
    2022 Celestial Silver Metallic TRD Off-Road
    Cilajet ceramic coating
    Finished up installing my CaliRaised premium roof rack along with the CaliRaised side LED pods. But obviously this post is for DD goodness! I installed the SS42 lightbar in white with the combo pattern. I’ll get output shots sometime this weekend hopefully. But for now:
    cc-rider and Fortune Taco like this.
  2. Jul 28, 2022 at 11:19 PM
    #322
    republic_of_texas
    republic_of_texas Well-Known Member
    Josh
    Austin TX
    Black 2016 Tacoma TRD Sport 4x4
    3/10/22 •icon stand 9 suspension with billet UCA’s, running medium duty Dakar leafs •method NV on 32” BFKO2 •Prinsu RR with Cali raised dual function LB •DIY BHLM •BANTAMMAX8 and SPOD •arb single comp •KC FLEX ditchlights •Wescot designs rock sliders •Relentless Fab HC rear bumper with spod •BA slimline front bumper with 20” lb, 11K lbs Superwinch •full RCI skids •MobTown fab BR, with rotopax and traction board mounts •softopper •OVTUNE dump tubes •AFE COI •URD spec u y pipe and full exhaust •KDMAX pro Tune •Smitty bolt RTT, and canopy •TBC
    Little DD diy mod of the day.
    Got a new tube bumper so my DD pro fogs with the curve no longer worked. I was planning on buying new covers to replace the curved ones. I ended up cutting them down, hit it with a flap disc, then finished it off with a 1k enamel spray paint. Saved around 60 bucks, looks exactly the same as the other covers.
  3. Jul 31, 2022 at 4:56 PM
    #323
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    as somebody whos cuts a lot of alu on table saws, that would still make my butt pucker cutting that lol
    jackn7 and republic_of_texas like this.
  4. Jul 31, 2022 at 5:02 PM
    #324
    republic_of_texas
    Josh
    Austin TX
    Lol yeah it was a bit sketchy but I used 2 push sticks and took it suuuuuuuuper slow. Went through like butt hair
  5. Oct 11, 2022 at 11:25 AM
    #325
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Finally got around to hooking up the SS30 bar. :D
  6. Oct 11, 2022 at 11:29 AM
    #326
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    YESSIR!
    Ozzylara805 and TegoTaco[QUOTED] like this.
  7. Oct 12, 2022 at 3:36 AM
    #327
    TegoTaco
    Ontario, Canada
    feel free to use it on your site btw. :D
  8. Oct 29, 2022 at 11:52 PM
    #328
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    32" bar behind the grille with 4 driving/1 flood lens, set of pro driving yellows, and sport fogs. Doing a new bumper so will probably ditch the ss3 pods, and maybe just tuck one set of c1s somewhere.
  9. Nov 11, 2022 at 4:15 AM
    #329
    Fooburger
    Fooburger Well-Known Member
    Jim
    Southampton, PA
    2011 Tacoma sr5 access cab
    3” w/jba’s. LCE header w/intake spacer & hps cai tube
    Wish this was true for me.
    My aftermarket headlights light output is horrible, so I use to leave my fogs on at night and never got flashed once.
    I have my SS3 amber pro pointed down as low as possible and I get flashed constantly.
    Every car I pass I see their bright yellow face looking at me pissed.
    I must be doing something wrong because seems like I’m the only one with this problem.
    Really like the output but I’m at the point where I won’t use them so contemplating putting my old fogs back in.
    Id appreciate any help on what I might be doing wrong or any tips on pointing them lower.
    Wondering if adding the white lense would reduce the glare on oncoming traffic ?
  10. Nov 11, 2022 at 7:09 AM
    #330
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    The Pro uses an LED with a much larger die than either the sport or Max model, and as a result the optic has much poorer focus, resulting in a significantly "softer" cutoff line. The yellow lens has to filter out a decent % of the total light output, meaning lower intensity than the clear optic over the same pod, and less glare as a result. Additionally, yellow light is less "glaring" at the same intensities as white/full spectrum light, so going to the clear lens would not help. Your best bet is to recheck the aim of your fogs, with a heavier than typical load in the vehicle, as correctly adjusting them with a light load can cause them to be aimed significantly higher with an increase in vehicle weight/suspension loading.
    And finally, as long as theyre within the legal height/width mounting requirements, wired appropriately, aimed correctly, and *used* appropriately, then theres nothing you can further do to minimize glare. Except not use them.
  11. Nov 11, 2022 at 7:17 AM
    #331
    TegoTaco
    Ontario, Canada
    Your truck stock height?
  12. Nov 11, 2022 at 7:26 AM
    #332
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    In case it wasn't clear in the other replies, your root cause problem is that the Pro is a poor choice for constant on road use due to the beam pattern. You'd actually be better off with the Sport. I had the same problem with my Pros, then went to the Max for the same reason. But I only use them in poor weather too.
  13. Nov 11, 2022 at 7:45 AM
    #333
    Fooburger
    Jim
    Southampton, PA
    [/QUOTE]
    Thx man. I did the whole measuring with tape in a parking lot and absolutely loved them. Now I have them pushed down as far as the brackets would allow hoping I'd get flashed less.
    So weight wouldn't matter, right?
  14. Nov 11, 2022 at 7:46 AM
    #334
    Fooburger
    Jim
    Southampton, PA
    No have 3" toytec lift, with 33
    TegoTaco[QUOTED] likes this.
  15. Nov 11, 2022 at 7:49 AM
    #335
    Fooburger
    Jim
    Southampton, PA
    Thx,
    And great, wish I new then, would've same money also
  16. Nov 11, 2022 at 7:56 AM
    #336
    Fooburger
    Jim
    Southampton, PA
    Also was wondering, when a car coming towards you, is their interior all lit up as they pass you? I'm guessing more so, just on the sports?
  17. Nov 11, 2022 at 8:01 AM
    #337
    Too Stroked
    Tom
    Pro fogs with a lift. That explains it all. There just isn't enough downward aim possible with the SS3's to both give you a proper beam pattern and not bother oncoming drivers when you're mounted that high up.
    On road forward lighting with any lifted vehicle is problematic. The best thing you can do is lower the mounting point(s) of your fog lights. That's not always possible. And no, the entire interior of oncoming vehicles should not be lit up as you go by or pull up behind them.
    TacoFergie and TegoTaco like this.
  18. Nov 11, 2022 at 8:10 AM
    #338
    TegoTaco
    Ontario, Canada
    That’s the problem. :)
  19. Nov 11, 2022 at 12:25 PM
    #339
    DuffyBank
    DuffyBank Well-Known Member
    Fogs are to only be used when weather conditions necessitate their use.
    Stuck in VT likes this.
  20. Nov 11, 2022 at 12:30 PM
    #340
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Diode Dynamics Elite fogs with backlighting (that is unable to seen unless you're in dim lighting). Fantastic output otherwise though.
