Show off your diode dynamics!
Discussion in 'Lighting' started by Lightingsearcher, Jul 27, 2021.
  1. Nov 11, 2022 at 7:02 PM
    #341
    B3NDR
    B3NDR Well-Known Member
    Justin
    North Georgia
    2020 Toyota Tacoma TRD Off Road 4x4 DCSB
    Here is my contribution. SS3 Max Fogs and SSC2 combos in the ARB with Paranoid Fab brackets.
  2. Nov 15, 2022 at 8:35 PM
    #342
    Fooburger
    Fooburger Well-Known Member
    Jim
    Southampton, PA
    2011 Tacoma sr5 access cab
    3” w/jba’s. LCE header w/intake spacer & hps cai tube
    No, I have 3” Toytec lift with 33s
    I know, hated the harsh ride from day 1. Added jba’s, rides better, have rxt leak packs coming this week. Was thinking replacing 5100s with 5125s
  3. Nov 15, 2022 at 8:44 PM
    #343
    Fooburger
    Jim
    Southampton, PA
    Wish I knew this then.
    And why am I like the only one.
    Feels same as when when I lifted it. All I read was how awesome the 5100 coil overs where,
    Think I shattered 3 teeth and herniated 2 disc's in the 1st week!
  4. Nov 16, 2022 at 11:53 AM
    #344
    DuffyBank
    DuffyBank Well-Known Member
    I have pro ssc3 fogs mounted in an aftermarket bumper with 2.5" of lift. Yes the upper cutoff is diffuse but I had no issue getting them pointed low enough not to bother oncoming traffic.
    Also ssc3 pro 4k driving lens behind the grill.
    TegoTaco and memario1214 like this.
  5. Nov 30, 2022 at 7:18 PM
    #345
    DuffyBank
    With the debate in the other thread, some new pictures. 25 feet from the wall.
    I have H9 low beams, SSC3 Pro Fogs (selective yellow 4K), Aux highbeam SSC3 Pro mounted behind the grill (4K driving lens). Truck is lifted 2.5" front (OME886), 3" rear (DakarHD + airbags). Aftermarket bumpers and skid plates.
    Low Beam
    Low Beam with Fogs
    High Beam with Aux High Beam
    What does that look like on the road? Stop sign is 250 metres away.
    Low Beam
    Low Beam with Fogs
    High Beam
    And because I can, Low beam, fogs and Aux high beams - for off road use where long range vision is hampered by twisty tree lined roads.
  6. Dec 1, 2022 at 9:18 AM
    #346
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Were your camera settings locked for all these pics? Very good comparison shots.
  7. Dec 1, 2022 at 9:24 AM
    #347
    DuffyBank
    Unfortunately not, but it does give a real world idea of what you can and can't see, though the low beam and fogs against the wall is much more yellow in person.
    Toy_Runner[QUOTED] likes this.
  8. Dec 11, 2022 at 4:08 PM
    #348
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
  9. Dec 13, 2022 at 5:58 AM
    #349
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    I might have to borrow that idea of yours with those ditch lights. I never thought of using the side mounting bolt. Great idea!
  10. Dec 13, 2022 at 3:15 PM
    #350
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    I did have some trouble with the factory bolt on the SS3 not being long enough to bite, so I had to go find a new one just 2-3mm longer but it's solid!
    Keep in mind having it sideways like this only really works with the flood lens, everything else needs to be horizontal if I'm not mistaken or you'll end up with a vertical beam haha!
    jackn7[QUOTED] likes this.
  11. Dec 13, 2022 at 5:29 PM
    #351
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    I didn't think about that, but yeah, that makes sense. Thanks for the heads up! Does it fill in nice?
  12. Dec 13, 2022 at 5:41 PM
    #352
    toledoupsguy
    toledoupsguy Well-Known Member
    Haskins OH
    2020 Ford F-150 platinum
    You can turn the spots sideways too.
    jackn7 and Too Stroked like this.
  13. Dec 14, 2022 at 6:55 AM
    #353
    Diode Dynamics
    Diode Dynamics Automotive Lighting Experts Vendor
    St. Louis, Missouri
    We're loving this setup! It's definitely created some movement online and inspiration.
    Most users rock our SSC1 Ditch Light Hack but this SSC2 setup is one of a kind!
    If users haven't seen our SSC1 Ditch Light Hack, I've provided some images below.
    Additionally, the user @silvertundraor on Instagram has an excellent video showcasing his DD ditch light setup.
    - SSC1 Pro Flood
    - SS3 Sport Combo
    Thank you all for the support on this thread!
  14. Dec 14, 2022 at 6:32 PM
    #354
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    That's true, but not ideal for this side lighting scenario I don't think.
    Too Stroked likes this.
  15. Dec 30, 2022 at 10:29 PM
    #355
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Rocking some ss5's on the new bumper.
    TegoTaco, Aws123, jackn7 and 4 others like this.
  16. Dec 31, 2022 at 12:56 AM
    #356
    TacoTuesday1
    SD CA
    @Diode Dynamics
    So if I may ask you guys some questions,
    I have the 1" backup lights, probably brighter version (at least from what was available at the time)
    Looks like at some point recently, a new model came out. C1R, better than the old ones I have, which are red backlight / white ON
    With C1R able to act as a brake (high output) and even strobe
    I installed the regular 1" with supplied harness in the kit.
    What would be involved in converting to the new C1R with brake functionality, so the whole back of the truck is even (anything red lights more red during braking)? vs. mismatched
    Is it a matter of just slapping in new C1R's?
    What I have is the 2/pair in corner pockets of WarFab Phantom HC rear
    In fact, this thing looks even cooler to put a 3rd in the hitch hole that I don't use often
    to light up more area.
    Unless that is overkill...
    I am guessing they might not be reverse-compatible to swap, as the old ones are 3-wire
    Also, is the 3-way switch supposed to be able to toggle on, independently? I would think so. Did I install incorrectly or something?
    I believe for mine, 1 point of the switch is full function (red backlit, white in reverse) but the rest generally turn it off
    Was hoping there would be a click that could turn it on, to have white light on it's own; without having to place truck in reverse. Such as at a campsite
  17. Dec 31, 2022 at 1:21 AM
    #357
    toledoupsguy
    Haskins OH
    Which beam pattern is that? Very impressive.
    TegoTaco likes this.
  18. Dec 31, 2022 at 5:31 AM
    #358
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I can answer one of your questions. I recently installed a set of backlit SSC1's on my cousin's Austin-Healey 3000 replica as backup lights to replace the (pathetic) original equipment incandescent units. (And of course, they came from Hotshot Offroad!) The primary goal was to improve his reverse lighting. Since we had the option of a backlight, we selected red and hooked that feature up to the brake lights.
    The flood pattern white backup lights are absolutely awesome. There's no way a light this small should put out that much light. The red backlights are exactly what they're advertised as - cosmetic. Said another way, they're cute, but not truly effective enough for real brake lights.
  19. Dec 31, 2022 at 8:22 PM
    #359
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Driving, definitely my favorite pattern.
    toledoupsguy[QUOTED] likes this.
  20. Dec 31, 2022 at 8:24 PM
    #360
    TacoTuesday1
    SD CA
    I mean. They could be brake lights. If it was the C1R, which did not exist at the time.
    Though cosmetic is not horrible; some other vehicles have a lower cosmetic red lit, such as I believe Ford Raptor, Ranger, etc.
    and hey, the more lights the better, for people to look and hopefully not crash into it
    Might still look good to have regular pods at the corners, and C1R at the tow port
