Show off your diode dynamics!
Discussion in 'Lighting' started by Lightingsearcher, Jul 27, 2021.
  1. Jan 9, 2023 at 11:53 AM
    #381
    Fuse
    Fuse Geologist
    Calgary
    2015 TRD Sport 6MT
    Greatly appreciated! Would be an instant buy for me.
  2. Jan 9, 2023 at 11:54 AM
    #382
    Diode Dynamics
    Diode Dynamics Automotive Lighting Experts Vendor
    St. Louis, Missouri
    Please refer to the 3:11 mark on this installation video if you have LED headlights from the factory.
    Overall, you can tap our backlight wire lead to any 12v fused source to signal the backlight to illuminate.
    https://www.youtube.com/watch?v=e2Z8q7GPThY
    TRDPRO68 and Coldpunk[QUOTED] like this.
  3. Jan 9, 2023 at 11:59 AM
    #383
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    That's probably because you have so many options there. Some tie into the running lights like I did. Some tie them into the DRL circuit. I even wired the (red) backlight on a set of SS1's in clear (used as backup lights) into the brake light circuit on one car.
    Coldpunk[QUOTED] likes this.
  4. Jan 9, 2023 at 12:29 PM
    #384
    Coldpunk
    Coldpunk Well-Known Member
    Karl
    Missouri
    2022 Lunar Rock TRD Off Road Long Bed
    TRD lift w/ OME HD rear pack, Diode Dynamics ss3 fogs and 18” light bar, front/rear steel bumpers, Badlands winch, Method 701’s, at4W pizza cutters, RSI Smartcap, RCI sliders, RCI bed stiffeners, Front Runner load bars, Fitcamx, anytime front/rear camera,
    I love the fast response!!
    I do have LED headlights and that video is helpful if I was using the tap method, but I bought the 20$ plug and play adapter though so I could avoid using a tap. Do you guys have any videos showing where the plug and play harness is meant to attach? Or is my only option to tap if have factory LED headlights?
  5. Jan 9, 2023 at 12:33 PM
    #385
    illnevertell10
    illnevertell10 Member
    I made another post in the 3rd gen form. The plug and play harness only works with the pre 2020 halogen headlights. If you have the new 2020+ full LED with one plug in the back the harness won’t work. The description on the website is a bit misleading, I think splicing is the easiest method for now.
    https://www.tacomaworld.com/threads/diode-dynamics-backlight-harness.789145/
    Buggin112 and Coldpunk like this.
  6. Jan 9, 2023 at 12:45 PM
    #386
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    lol joined just to make this post and thread. Last post Dec 2021, all 6 posts just in this thread.
    DD Social Engineering for the win. :rofl:
  7. Jan 9, 2023 at 12:45 PM
    #387
    Coldpunk
    Karl
    Missouri
    I feel way way better about the last half hour I spent scouring the internet and looking for the correct connector under the hood. I was going to feel real dumb if I had overlooked it
  8. Jan 9, 2023 at 12:49 PM
    #388
    illnevertell10
    Me too! I felt silly asking but glad I did.
    Coldpunk likes this.
  9. Jan 9, 2023 at 1:16 PM
    #389
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
  10. Jan 9, 2023 at 4:46 PM
    #390
    Mix 99.3
    Mix 99.3 Well-Known Member
    That is truly astounding! And for being "spots" I'm shocked at how nice the spread is.
    toledoupsguy likes this.
  11. Jan 9, 2023 at 4:50 PM
    #391
    toledoupsguy
    toledoupsguy Well-Known Member
    Haskins OH
    2020 Ford F-150 platinum
    If you look at the specs ss5 spot has wider spread than ss3 driving.
    DuffyBank likes this.
  12. Jan 9, 2023 at 9:40 PM
    #392
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    That 4k color is awesome, probably should've done the same but got white/run yellow covers here and there
  13. Jan 10, 2023 at 12:18 PM
    #393
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I can't remember what the rest of your lighting situation looks like off the top of my head now... In general, if you ONLY have A-pillar lights then the combo is the best option. That said, DD's combo pattern is less of a combo than I would like. It has the tight driving beam with a very splashy flood. Where you want the driving beam is generally straight ahead or hardly canted off to the sides whereas you'd like the flood most when you can really pitch the lights off to the sides and use as a true ditch light.
    Here's what I tell people - Tell me what your current lighting situation is, what your goal is for your A-Pillar mounted light(s), and which power level of SS3 that you are going with and I will let you know which pattern to pick up! Since the pro has the larger LED chip than sport/max it has a different output profile even when the lens selection is the same.
    Aws123 likes this.
  14. Jan 10, 2023 at 12:32 PM
    #394
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    I have
    LED Retrofit headlights
    DD Max Fogs
    DD SSC1 Pro Ditch lights (forget the pattern - you can tell me I'm sure :D)
    BD 20" Combo Bar
    I'm going to be hanging the SSC1's off the side of the SSC3's. They are fine by themselves off road at night as a true ditch light, but to really be good I need to angle them out and down a little more than the typical ditch light brackets allow. Hanging off the side of the SSC3's will give me that ability. I don't really need any more forward lighting, but not opposed.
    My thinking was SSC3 Pro's in Combo, angled out about 10 degrees. Combo will give me a little more forward lighting, along with a little ditch light action. The SSC1 off the side will fill in everything I need it to.
  15. Jan 11, 2023 at 1:22 PM
    #395
    memario1214
    Colton
    Missoula, MT
    Okay so here's what I'm thinking. Since you're going to go pro power level on the SS3s I say that you do the driving pattern. The patterns for the pro power level are softer in general so you'll get more light bleed to the sides than if you went sport/max. Aim them out about 15deg (or where the "spot" portion of your light bar falls off). You can aim them a little more forward if you want as well once you get them in hand, and I'm suspecting that's just what you'll do. It'll reduce your hood splash since you won't have a flood pattern pouring light directly down onto the hood, and you'll get to leverage the angle of approach to the road to maximize down-range visibility. You'll get more light off to the sides than you think.
    As for the C1s, if you're going to hang them off of the SS3s we're going to need to get you some new lenses. The C1 lenses are oblong so they cannot be rotated 90 degrees. That wide pattern that you currently have making a "--" pattern will end up as a "|" pattern which is not ideal for the intended application. We'll need to get you into some flood lenses for those guys.
  16. Jan 11, 2023 at 1:31 PM
    #396
    aturk
    Tony
    Charlotte, NC
    This is why I buy my lights from you. :D Going to get some red rock lights for my camper shell for "nightlights" too. I'll be in touch brother.
  17. Jan 11, 2023 at 1:36 PM
    #397
    memario1214
    Colton
    Missoula, MT
    :cheers: You know I've always got you.
  18. Jan 11, 2023 at 2:18 PM
    #398
    Mix 99.3
    I would like to make a purchase too. PM Sent :)
  19. Jan 11, 2023 at 2:22 PM
    #399
    memario1214
    Colton
    Missoula, MT
    We've been up to our eyes the past few days. I saw you lurking in there! I'll probably get to your PM bright and early in the AM. Sorry about the delay!
    Mix 99.3[QUOTED] likes this.
  20. Jan 20, 2023 at 3:04 PM
    #400
    aturk
    Tony
    Charlotte, NC
    Joined the cool kids club the other day…
    Went from a SSC1 Pro in wide pattern on each side to a SS3 Pro Driving plus a SSC1 Pro Flood on each side. Not the easiest things to line up and hulk torque down if you’re OCD like me.
    No night shots til I’m out of my cast unfortunately.
    patdeezy, japjoe7, jackn7 and 4 others like this.
