Show off your diode dynamics!
Discussion in 'Lighting' started by Lightingsearcher, Jul 27, 2021.
  1. Jan 6, 2024 at 8:06 AM
    #481
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    Well that’s annoying what’s the point of buying a plug and play harness then.
  2. Jan 6, 2024 at 8:47 AM
    #482
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    How would you propose making a plug and play harness for an infinite variety of options? Having wired up more automotive accessories than I can count, I'd say DD did it the best way that could be expected.
  3. Jan 6, 2024 at 9:08 AM
    #483
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  4. Jan 6, 2024 at 9:30 AM
    #484
    azhiaziam
    The reef ca
    Tlaloc1916 likes this.
  5. Jan 6, 2024 at 10:48 AM
    #485
    memario1214
    Colton
    Missoula, MT
    Okay - and do you have OEM halogen headlights?
    The purple blade style connectors attach to one another. You’ll unplug the big connector that goes into the back of the headlight, and the black connector (far left) just snaps inline.
    Hopefully that all made sense.
  6. Jan 6, 2024 at 12:00 PM
    #486
    azhiaziam
    The reef ca
    I do yes. Ya so it’s only on when your headlights are on from understanding then. Which would be the exact same time I’d run my fogs
  7. Jan 6, 2024 at 3:36 PM
    #487
    azhiaziam
    The reef ca
    The far left one I don’t get.
  8. Feb 10, 2024 at 8:03 AM
    #488
    Dirtyleg
    Dirtyleg "Don't wanna Taco bout it!"
    Aaron
    Chesapeake, VA
    2018 SR5 4x4; CAB-4 Full Doors, BED-Standard 6' 3.5"
    El Taco Blanco
    I’m also having a difficult time finding where the PNP connects in?!?
  9. Feb 19, 2024 at 3:22 PM
    #489
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
  10. Mar 11, 2024 at 12:38 PM
    #490
    Dtax
    Dtax Well-Known Member
    Massachusetts
    2017 Black Tacoma Sport
    Mods = N+1
    next time perhaps spin the front passenger tire so the TRD is right side up...... come on man!!!
    just kidding around, truck looks amazing!
    jackn7 likes this.
  11. Mar 12, 2024 at 4:18 PM
    #491
    TegoTaco
    Ontario, Canada
    Didn’t think anyone would notice lol! It was bugging me when I seen it after. lol
    Dtax[QUOTED] likes this.
  12. Mar 12, 2024 at 4:29 PM
    #492
    Tenmile Tacoma
    Tenmile Tacoma IG: tenmile_tacoma
    Nate
    Colorado
    2016 DCLB TRD Sport 4x4
    F&R locked on 33s
    Beautiful build man! White DCLB TRD Sport gang over here too :cool:
  13. Mar 26, 2024 at 3:57 PM
    #493
    Tlaloc1916
    Tlaloc1916 Well-Known Member
    Magnolia Tejas
    2021 SRish 4x4
    Can’t wait to see them at night. :rofl:
  14. Mar 27, 2024 at 3:21 AM
    #494
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    daYUmn…..that is awesome!
  15. Mar 29, 2024 at 11:03 PM
    #495
    TacoTuesday1
    SD CA
    are: reverse aux lights, is there an amp limit?
    I have aux lights and want to add a lamp bar
    Similar to this
    For example, I have DD SSC1 aux lights
    Three
    One is hitch pod with brake flash reverse
    Others are just red parking or white reverse
    Ram TRX lamp bar draws 0.3A
    VLEDS LPX is that, but with added brake glow and white reverse 2000lumen
    saw someone do something similar. Seemed to work.
    don’t want to overload with too many amps
    I’m guessing that’s a simple math calculation based on wire gauges and whatever fuse is in the circuit, that may match wire gauge.
    hardest part would probably be figuring out what is powering what from where. As the C1 hitchpod plugs into the tow.
    the C1 aux reverse pair may not be a factor because they came with a harness to run to the battery. Their adapter plug into the tail light I assume is for low voltage signal, not power.
    Haven’t decided between VLED LPX 3amp or Ram TRX 0.3A bar. TRX bar is cheaper but less function + big and ugly with tiny mount holes. Could entail coarse screws into inserts, or rivet nuts and spacers for either one.
    Truck could be around the point of too many lights. Only way to find out will be have someone drive while I follow for a performance check at night to see how it looks. Thing is turning into a fire truck
    could just run things then wait and see if any fuses pop.
  16. Mar 30, 2024 at 8:47 AM
    #496
    Dtax
    Massachusetts
    Mods = N+1
    jackn7 likes this.
  17. Mar 30, 2024 at 2:04 PM
    #497
    Too Stroked
    Tom
    It would be one thing if you purchased a set of lights specifically designed and advertised as DRL's and complained if you had a problem with them. But the Diode Dynamics SS3 Sports - regardless of the beam pattern - are not designed or advertised as replacement DRL's. The backlight feature is strictly a cosmetic item. If you had a problem with them, you should have reached out directly to DD and I'm sure they would have cheerfully refunded your money.
    I don't understand why you continually bash a top tier supplier and site supporter with comments like this.
    jackn7 likes this.
  18. Mar 30, 2024 at 7:15 PM
    #498
    DuffyBank
    DuffyBank Well-Known Member
    Back light is no more than a glow, never intended as anything else. Similar to a marker light.
  19. Apr 1, 2024 at 3:18 PM
    #499
    azhiaziam
    The reef ca
    Anyone have ss2s in a good spot for backup or camp lights. I’m getting bigger ones for my ditch lights and will have 2 white ssc2 extra
    PilotBoy352 likes this.
  20. Apr 1, 2024 at 4:11 PM
    #500
    PilotBoy352
    PilotBoy352 Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    I used to have two SS2 knockoffs mounted in pre-existing bolt holes by my hitch for a while before I upgraded to flush mounted SS3s in my bumper. IDK if your 3rd gen has similar holes for the bolts to go through. Linked post from my build thread below:
    azhiaziam[QUOTED] and jackn7 like this.
