Show off your diode dynamics!
Discussion in 'Lighting' started by Lightingsearcher, Jul 27, 2021.
  1. Apr 1, 2024 at 8:35 PM
    #501
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    Interesting. I’ll have to check. I was thinking about just buying the flush mount brackets for the ss2 and putting them in my bumper
    PilotBoy352[QUOTED] likes this.
  2. Apr 2, 2024 at 3:13 PM
    #502
    DuffyBank
    DuffyBank Well-Known Member
    I have m SSc2's in my rear bumper. The scatter across the ground gives a nice ground cover for setting up a camp if arriving late. Unfortunately no late night shots of the area they cover. I bought them to illuminate a work area when I need to do a late night check on a drill rig in the bush.
    Tlaloc1916, jackn7 and Canadian Caber like this.
  3. Apr 2, 2024 at 3:40 PM
    #503
    azhiaziam
    The reef ca
    Did you tilt them up at all?
  4. Apr 2, 2024 at 4:48 PM
    #504
    DuffyBank
    No. never found a need to.
    azhiaziam[QUOTED] likes this.
  5. Apr 15, 2024 at 10:06 AM
    #505
    TacoTuesday1
    SD CA
    back when it had x2 DD 1”
    now +DD hitchpod +VLED bar
    turkeyslayer66 likes this.
  6. Apr 15, 2024 at 8:11 PM
    #506
    HockeyTRD
    HockeyTRD Well-Known Member
    2022 Tacoma TRD OR DCSB
    This weeks projects. Not sure ill get the SS3s up yet. Picked them up at the DD open house.
    turkeyslayer66 and paranoid56 like this.
  7. Apr 16, 2024 at 4:36 PM
    #507
    HockeyTRD
    Sitting a little higher than I would like
  8. Apr 17, 2024 at 8:14 AM
    #508
    turkeyslayer66
    turkeyslayer66 Well-Known Member
    mike
    22 AG Trd Sport
    Been doing a ton of reading up on here. Planning on upgrading my factory fog lights to the
    DD s3 pro ones, and getting the Diode Dynamics reverse light setup. Eventually will do a set of driving lights too,
    either a bar or pods, to work with the high beams. I do most of my driving in the dark, and I have a 20 mile drive to work that takes me through hilly winding back roads with lots of deer. Can't wait!
  9. Apr 17, 2024 at 8:22 AM
    #509
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Would this be enough light for you? All Diode Dynamics (SS5 Pro Spot pattern) with my 4Runner high beams.
  10. Apr 17, 2024 at 9:53 AM
    #510
    king.cong.1119
    king.cong.1119 Well-Known Member
    Installed Diode Dynamics C1R pod in the back next to license plate, I wanted a red color rear fog light that can also be served as a chase light.
    I like how DD's C1R has three modes, bright white for reverse, dim red for running light, and bright red I will be wiring into the switch panel for rear fog/chase.
  11. Apr 17, 2024 at 10:10 AM
    #511
    king.cong.1119
    I have a little comparison video of the DD SS3 pro vs the Baja Designs squadron wide cornering pattern here
    https://www.youtube.com/watch?v=jypJRYTk0hU
    Hopefully it gives you an idea of the DD's SS3 pro look like in a real world setting.
    Cheers!
  12. Apr 17, 2024 at 10:16 AM
    #512
    turkeyslayer66
    mike
    22 AG Trd Sport
    Yes!
  13. Apr 17, 2024 at 10:16 AM
    #513
    Too Stroked
    Tom
    Additional point: The Diode Dynamics model shown here is street legal. The Baja Designs model shown here is not - for obvious reasons.
  14. Apr 17, 2024 at 10:17 AM
    #514
    turkeyslayer66
    mike
    22 AG Trd Sport
    Thank you for posting this, I will certainly check it out!
  15. Apr 17, 2024 at 10:18 AM
    #515
    king.cong.1119
    correct, BD has since come out with the SAE fog version of the squadron, but based on the comparison testing DD has done, I personally still prefer the DD as a street legal fog due to a wider beam and warmer temperature. Off the road, I prefer BD's non-SAE wide cornering for more light spill/spread.
  16. Apr 17, 2024 at 10:27 AM
    #516
    DuffyBank
    For what it is worth, I grabbed a shot of my DD SSc2 Pro reverse lights. Someone asked the about the illumination from them.
  17. Apr 17, 2024 at 10:29 AM
    #517
    turkeyslayer66
    mike
    22 AG Trd Sport
    Great info, thank you all for the advice and pics!
  18. Apr 17, 2024 at 10:31 AM
    #518
    DuffyBank
    I have my doubts those are DD SSC3 Pro. The cut off on the Pro is not that sharp.
  19. Apr 17, 2024 at 10:31 AM
    #519
    king.cong.1119
    but they are
  20. Apr 17, 2024 at 10:37 AM
    #520
    turkeyslayer66
    mike
    22 AG Trd Sport
    Have you used a trailer with them? I wondered if they would spill enough light to the sides when backing? I need some additional lighting for reverse, I often am launching a small boat in some sketchy unimproved ramps (being generous with that term!) in the dark. I might need to go with higher mounted aux reverse lights though, not sure if bumper ones might be too low/obscured to see off to sides? I might be over thinking this also lol.
