Show off your DIY armor!
Discussion in 'Armor' started by Thelgord, Dec 15, 2016.
  1. Mar 11, 2018 at 7:20 PM
    #281
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    That turned out awesome. Nice work.
    Fuergrissa[QUOTED] likes this.
  2. Mar 11, 2018 at 7:22 PM
    #282
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    Thanks!
  3. Mar 12, 2018 at 3:41 AM
    #283
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    Is the tailgate shaking / rattling / generally making noise while you're driving around? Im guessing you have some kind of bushing in the tube that is the hinge and latch.
  4. Mar 12, 2018 at 6:39 AM
    #284
    tostada
    tostada We are, killing ourselves over ancient literature.
    doug
    remote desert garage AZ
    2016 TRD offroad DCLB
    tires, custom rock sliders using MOBTOWN bolt on plates,
    ditto?
  5. Mar 12, 2018 at 10:00 AM
    #285
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    No, shaking. Used poly bushings with an inner sleeve for my pivot points. 98FFAE0C-A3D9-4A7E-9B88-5ADA8F7CF798.jpg
    After the initial test fit with the tire, everything worked perfect. I decided to add gussets to the tire mount plate and the tube holding the tire. The heat pulled the mount plate just enough to have the tire interfere just a little during the last inch while closing. This puts a little tension on all the pins so they don’t rattle at all.
    Also added an addintial mounting point for the frame utilizing the bolt location for the stock tail gates pivot point. But you cant see it ahha I cut a slot in the outside base of the posts, inserted both bolts screwed in half way, and slid the frame over them so the bolt heads are inside the tubing the the only way to tighten them is to take off the rear bumper. So that was fun.
  6. Mar 20, 2018 at 5:21 PM
    #286
    tostada
    doug
    20180319_133825.jpg sliders Done!
    Rear bumper tire carrier next.
    Thanks again MOBTOWN:hattip:
  7. Mar 20, 2018 at 5:41 PM
    #287
    tostada
    doug
  8. Mar 20, 2018 at 6:56 PM
    #288
    jjsul
    James
    New Hampshire
    95.5 OME
    Made a quick mock-up to get some initial dimensions. This will take me some time, but I’ll keep this thread updated w progress pics
    SwampYota, Arcticelf, TomTwo and 9 others like this.
  9. Mar 20, 2018 at 7:52 PM
    #289
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I found some tyger sliders on craigslist but they seem pretty flimsy in the mounting department. Seem like 'slider-style' running boards, really. Might go pick them up and alter them with a more sturdy slider esque mounting and add a kick out. Lucky find for me since this area is pretty dry for taco parts other than stock bumper covers and 1st gen bed covers.
  10. Mar 20, 2018 at 11:17 PM
    #290
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    Digging the CAD work! How you guna mount it? Build a bracket, buy one or weld to frame?
    tostada likes this.
  11. Mar 21, 2018 at 3:28 AM
    #291
    jjsul
    James
    New Hampshire
    95.5 OME
    I'm gonna make it bolt on using the factory front mounts. Two on the front face of the frame horns, four under the front frame horns, and four outside the frame on the body mounts. Judging from pictures that I found online, Im pretty sure that is how Elite and Relentless mount theirs. Hopefully its up to the task :thumbsup:
    I took the front bumper off the other day and got some measurements... that helped a ton. Seeing what I had to work with allowed me to draft more realistic models with actual dimensions. Sketchup is a real time saver in design and amazingly helpful in pulling out dimensions. I only needed a few dimensions to start (mounting bolt locations, total width, height and depth(ish), then I can literally connect the dots in sketchup and have dimensions calculated for every piece to be cut. Pretty solid!
    I like some of my other designs that have an extra bevel on the front face, instead of just one flat face. However, I'm worried that more welding means more warping. You should see how my mock up skid plate bent itself into shape while I was laying beads :rofl: So I'm wondering about keeping it simple vs stylish and easier to fab vs more challenging to do well.
  12. Mar 21, 2018 at 8:33 AM
    #292
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    Nice, I’d say go for the challenging! Sounds like your prepared. Just balence you welds, may the heat be in your favor.
    jjsul[QUOTED] likes this.
  13. Mar 21, 2018 at 12:34 PM
    #293
    tostada
    doug
    20180321_120401.jpg chopped off frame mounting plates
  14. Mar 21, 2018 at 12:36 PM
    #294
    tostada
    doug
    4"x4" .250 wall
    Fuergrissa, jjsul and Darkgoatracer like this.
  15. Mar 27, 2018 at 1:14 PM
    #295
    jcott329
    jcott329 Well-Known Member
    Jordan
    Northern Mississippi
    2012 DCSB TRD OR
    DIY skidplates complete... used 3/16 steel
  16. Mar 27, 2018 at 2:12 PM
    #296
    Slashaar
    Josh
    Kansas City, MO
    You should put a hole in where your oil drain is, then install a fumoto valve in there, then you wont need to unbolt to change your oil. Use a piece of tube, and hit the valve, nice and easy.
    jjsul and jcott329[QUOTED] like this.
  17. Mar 28, 2018 at 12:30 PM
    #297
    tostada
    doug
    old hitch height in the foreground.
    Should I put the new receiver under the 4 inch main cross member?
    or cut a hole through the cross member and insert the receiver?
    If I put it under I still gain almost 6 inched of departure clearance.20180328_121647.jpg any thoughts?
    trabo and TomTwo like this.
  18. Mar 28, 2018 at 4:47 PM
    #298
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    It really depends on what you plan on doing with the truck imo... if you tow a trailer a lot i would leave it low. If you picked up 6" of clearance you should clear almost every obstacle would be on.
  19. Mar 28, 2018 at 6:50 PM
    #299
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    If your goal is clearance, I’d punch a hole and insert it. Sure, you’re gaining clearance either way, but there is a whole lot of truck behind the rear wheels on a Tacoma. We need all the departure angle we can get. I’ve managed to scrape my bumper several times and it’s about as high and tight as I could get it with the receiver inside the main channel. I use a 10” drop hitch to tow.
    But... as already stated above, if you tow heavy more than you wheel I’d leave it low. Shorter drop means less leverage on the hitch.
  20. Mar 29, 2018 at 2:57 AM
    #300
    tostada
    doug
    Thanks, Nick and Carter.
    probably going underneath.
    looking at the way the stock receiver is built, crazy overkill imo.
    I'll just put a couple pieces of 1/4" plate, one fore and one aft
    Darkgoatracer likes this.
