Show off your General Grabber X3s
Discussion in 'Wheels & Tires' started by DustStorm4x4, Nov 25, 2016.
  1. Feb 4, 2017 at 7:18 AM
    #61
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Looks like I'm going with the 265/75 16 C-loads. The relatively heavy weight (53lbs) is still a bit puzzling though...
    As per tirerack the red lettering is only on one side, and they are symmetrical. Can someone confirm the opposite side is regular black/plain lettering?
    DustStorm4x4[OP] likes this.
  2. Feb 4, 2017 at 11:18 AM
    #62
    MagGrey
    MagGrey Well-Known Member
    2017 TRD Offroad MagGrey
    It's the weight that has me wavering on these.
  3. Feb 5, 2017 at 8:32 PM
    #63
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    I've been looking at those as well. The added weight for that must just be the extra meat it wears. You can see it in the shoulders. :popcorn:
  4. Feb 7, 2017 at 2:39 PM
    #64
    Paul631
    Extra meat indeed, these will do nicely...
  5. Feb 7, 2017 at 8:07 PM
    #65
    HB Taco
    Curt
    Awesome! Red letters out? Cant wait to see them mounted
  6. Feb 7, 2017 at 8:27 PM
    #66
    DustStorm4x4
    DustStorm4x4 [OP] BBC 2020
    U S A
    04 Jeep LJ
    Finally!!! Can't wait to hear your opinion about em.
  7. Feb 10, 2017 at 11:41 AM
    #67
    Paul631
    265/75 r16, C-range, everything else is stock.
    - Road noise - Very similar to bfg km1's (e.g. jeep rubicon), very tolerable.
    - Balancing - Fine, used a regular amount of weights for a tire of this size.
    - Acceleration - A surprisingly slight decrease. All 159hp are still present & feisty as ever. :benchpress:
    - Ride - Very nice. The equivalent of putting 3-5 additional psi in the stock hankooks.
    - Beach/sand usage - Excellent!
    Klondike Kid, NINK, HB Taco and 2 others like this.
  8. Feb 10, 2017 at 4:00 PM
    #68
    MagGrey
    Looks good.
  9. Feb 10, 2017 at 5:23 PM
    #69
    Paul631
    Thanks! Seems like the X3's run fairly narrow, there's still a fair amount of room around the upper control arms even with the more inwards offset of the steelies.
    The tires are on the tall side of the spectrum though (which is great, I'd like all the ground clearance I can get at stock ride height), they just clear the air-dam as seen in that above pic.
    Tesco88 likes this.
  10. Feb 10, 2017 at 5:30 PM
    #70
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    Expedition overland runs them on their trip through Mackenzie part 2. Check em out on youtube. Be warned though, someone @Caboose117 , told me to check em out and now I have been binge watching the show for 2weeks now.
    Taco1999, Harperspop, umpi5 and 2 others like this.
  11. Feb 10, 2017 at 5:37 PM
    #71
    Paul631
  12. Feb 10, 2017 at 7:46 PM
    #72
    HB Taco
    Curt
    This photo is NA?
  13. Feb 10, 2017 at 7:58 PM
    #73
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Ronny Dahl's channel is great. Didn't get the x3's but
    How much clearance do you have with the 285's at the uca / spindle & backspacing of your wheels?
    NINK likes this.
  14. Feb 11, 2017 at 7:55 AM
    #74
    HB Taco
    Curt
    Okay now the pic is there. How are they doing in the snow? So no vibration at all at 60mph? That's what plaguing me now, can't seem to get the balance right. Rotated and balanced several times just getting worse. Take a few more close up pics of the tires when you can. Thanks
  15. Feb 11, 2017 at 8:15 AM
    #75
    Paul631
    Front profile
    Front
    Rear profile
    Rear
    They're excellent, the mechanical keying into the icy snow really is an advantage over an A/T tire with a smoother tread.
    Zero vibrations at any speed, just the typical mud tire hum. Looks like the shop used two clip-on weights for each tire/rim, as shown above.
    What size and load range did you end up with?
    HB Taco[QUOTED] likes this.
  16. Feb 11, 2017 at 8:30 AM
    #76
    HB Taco
    Curt
    Excellent. I'm still just looking at tires now. My Toyo AT's are the same size and load but only 45lbs I think. One disadvantage of the wheels I have they cant use the clip on weights on the outside and those are more effective than stick ons. Might be the reason for the balance issue? I may want to put red letters out? Anyway looks good.
  17. Feb 11, 2017 at 8:58 AM
    #77
    Paul631
    The red letters do look great, but some people have had durability issues with them, apparently they are a vulcanized patch:
    https://lh5.googleusercontent.com/-...g_bachU/s800/Red%20Letter%20Failures%2007.JPG
    I actually have a set of trd beadlock style rims sitting in my closet which I bought with the truck, but the new-tire bug got me and with all the salt/sand of northeast winters I just went ahead & installed the tires on the steelies.
  18. Feb 18, 2017 at 9:23 AM
    #78
    Paul631
    Finally got to go on some mild trails & beach driving, great performance on both, very happy!
    DustStorm4x4[OP] and Dalandser like this.
  19. Feb 27, 2017 at 8:28 AM
    #79
    cruiseroutfit
    cruiseroutfit Well-Known Member
    Kurt
    Sandy, Utah
    08-200 00-100 89-74 87-61 72-40 66-45 & 65-Stout
    Thanks for watching!
  20. Mar 7, 2017 at 9:14 PM
    #80
    DustStorm4x4
    U S A
    04 Jeep LJ
