Show off your KC HiLiTES!
Discussion in 'KC HiLiTES' started by Taylor@KC HiLiTES, Mar 23, 2017.
  1. Oct 2, 2017 at 7:04 PM
    #141
    Cudgel
    Cudgel Member
    2017 Tacoma Off-Road
    Stock with bolt ons.
    My Revtek has 4 tabs built in and my 5” Apollo’s just bolted right on using the supplied posts. Note the Revtek instructions had all these directions about pulling the grill and such...I was able to carefully slip the brackets in and bolt them tightly with box wrenches without removing anything. Helps to have someone hold it up. I covered all the wires with split tubing and wired it all back to a centralized box on top of the fuse box, because, well, I’m a nut job. ;-). There is a wiring cowel beside the steering column I passed through the firewall and I mounted my switches in the coin holder space on the left side of dash above the rear window switch. I tapped the high beam to run the relay for the drive lights.
    Light it up and post a pic!
  2. Oct 4, 2017 at 2:21 PM
    #142
    Taylor@KC HiLiTES
    Taylor@KC HiLiTES [OP] Well-Known Member Vendor
    Taylor
    Arizona
    2010 DCSB TRD OR 4x4
    See build thread
  3. Oct 4, 2017 at 4:29 PM
    #143
    TacoTuesday91
    TacoTuesday91 Well-Known Member
    2017 Taco SR5
    thanks i was worried id have to find some brackets as well, ill already have the grille apart since i just ordered a BAMF grille so thought it was a good time to goahead n do the lights as well
  4. Oct 5, 2017 at 7:59 AM
    #144
    jeff b
    jeff b Well-Known Member
    Saw this on Instagram- about as sweet a set up anywhere! Also just shot a video of my truck @jeffinkansas
  5. Oct 12, 2017 at 11:07 AM
    #145
    Cudgel
    Cudgel Member
    Finished the switch install for my 4 sets of KCs this morning:
    jeff b likes this.
  6. Oct 13, 2017 at 4:59 PM
    #146
    TacoTuesday91
    2017 Taco SR5
