Show off your Led light bars
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jazz1one, Oct 23, 2015.
  1. Oct 23, 2015 at 6:59 AM
    Jazz1one
    Jazz1one [OP] It is what it is
    Calgary AB
    2015 MGM DCLB sport premium
    SCS ray 10s. 315/75/16 Yokohama G003. Elka 2.5 dc w/remote resi. SPC uppers. Dobinson heavy leafs. Timbren bumps. Spindle gussets. Cab mount relocate. TRD catback. Toyota trifold tonneau. Full spare in bed. Hood deflector, side visors. Danger Customs Front/rear high clearance bumpers and full skids. 2 way remote start. Safari snorkel. Front 30% tint. Bed step. Anzo LED head lights. Weather tech mats. AllPro HD sliders linexed. 10k smitty x20 synthetic. Factor55 flatlink. Linexed bushwhackers. Rigid industries bumper pods. Ridged industries DSS ditch lights. Diode Dynamics amber pods. Prinsu roof rack. 42” Caliraised Amber single row. Switch Pros in sunglass holder. Custom Bed rail mounts for recovery gear.Northstar AGM battery. 4.88 nitro gears. Front and rear ARB lockers. ARB air compressor in bed cubby using expedition essentials mount.
    My next mod will be adding a light bar in the lower grille and I'm looking for ideas, tips and vendors.. I will be hunting in the winter and need something tough and bright. Want to keep the setup hidden and would prefer an oem switch to the left of the steering. I'm sure a lot of you have already done this.. Let's see em..
  2. Oct 23, 2015 at 7:02 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  3. Oct 23, 2015 at 6:52 PM
    CaptainReverso
    CaptainReverso Well-Known Member
    Cory
    Gardena
    2015 TRD off road 4x4 DBL cab Magnetic Grey
    Off Road Stuff
    Not in the grill I'm aware lol. But I am selling this ! IMG_20150923_081933773_HDR.jpg IMG_20150923_081900855_HDR.jpg IMG_20150923_081912452_HDR.jpg
  4. Oct 23, 2015 at 7:02 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    I have the opt 7 c2 32 inch led bar in my liwer valence. It comes complete with the harness relay and a generic button for 176. In retro spect id go with a 30 inch if it were available since it would fit with less cutting. Or a 32 would be fine if it wasnt being mounted flush like mine. I use it every morning driving to work at 3 am in BFE.20150726_190715.jpg20150726_190647.jpgi mounted it using a 36 inch angle iron with predrilled holes from lowes. It fits the crash bar perfect. And then some 1 inch wide metal stock and cut it to 5 ish inches long. And then attach it all to each other and your good. Ill try to find a pic of my mounting setup.downloadfile.jpghard to see but the bars feet attach to metal stock. Stock attaches to angle iron and angle iron attaches to crash bar. Enjoy.
    Jazz1one[OP] likes this.
  5. Oct 24, 2015 at 5:41 AM
    ManBeast
    Zach
    Orange Park FL
    Ive driven through many downpours here in florida with absolutely no humidty inside. So thats also a plus.
    And the button it comes with is connected with spade connectors, so you can change the button to whatever, whenever.
  6. Oct 24, 2015 at 5:47 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    any air flow issues with this? running a little hot, the motor that is.
  7. Oct 24, 2015 at 5:51 AM
    ManBeast
    Zach
    Orange Park FL
    Nope the important air comes through the grille really. Upper grille that is
  8. Oct 24, 2015 at 5:52 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    thanks i like the look of this in the lower opening
  9. Oct 24, 2015 at 5:53 AM
    ManBeast
    Zach
    Orange Park FL
    No problem. Instead of a dremel or other motorized tool. I found using a pair of dikes to cut out the plastic worked best.
  10. Oct 24, 2015 at 5:54 AM
    geekhouse23
    Haggard Garage?
  11. Oct 24, 2015 at 5:59 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    What tool is that???
  12. Oct 24, 2015 at 6:00 AM
    geekhouse23
    Scissors
  13. Oct 24, 2015 at 6:01 AM
    taczilla
    Marc
    2016 RAM Rebel
    K, thanks. Never heard that term before.
  14. Oct 24, 2015 at 6:08 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    diagonal cutters,ie. dikes.
  15. Oct 24, 2015 at 6:54 AM
    Jazz1one
    Calgary AB
    Looks good. How did you run the switch?
    Has anyone done an oe switch to the left of the steering wheel?
  16. Oct 24, 2015 at 7:26 AM
    sonofsam77
    sonofsam77 Well-Known Member
    Ben
    Lehigh Valley, Pa
    2021 TRD OR DCLB
    32" light bar in lower valance, 4 - 4" lights on an N-fab bed rack. I used Air On Board switches in both left and center blank locations. Very good quality and fit like OEM.
  17. Oct 24, 2015 at 7:48 AM
    ManBeast
    Zach
    Orange Park FL
    I put my switch in theough the rubber boot firewall thang. Then ran it on the under sode of lower dash. Then i removed center console to gain access to my center dash switchs. Popped out a blank and put the generic round switch in. I plan to get a legit switch later on. The opt 7 has a quick disconnect harness thing like 2 foot after the button. So i fed the wire in the hole and grabbed it and have the excess wire and quick disconnect directly below the center console.
  18. Oct 24, 2015 at 7:49 AM
    ManBeast
    Zach
    Orange Park FL
    I typed that in the florida sunlight so forgive my spelling errors. And dikes are wire cutters.
  19. Oct 24, 2015 at 10:55 AM
    Jazz1one
    Calgary AB
    Looks like you mounted it behind the grill without cutting the thin plastic fin? What's an air on board switch? Any pics of the switches? Thanks
  20. Oct 24, 2015 at 11:45 AM
    ManBeast
    Zach
    Orange Park FL
    Go to aironboard.com they have many backlit switch options.that fit tacoma blank holes. All you need to do is push the blank from the back side, or drill a screw into the front and yank it out via the screw.
    mollyg likes this.
