Show off your Method wheels!
Discussion in 'Wheels & Tires' started by Nimble9, Jun 6, 2020.
  1. Jan 1, 2023 at 9:28 PM
    #81
    TacoTuesday1
    FL
    curious to see how the new 707's look
  2. Jan 3, 2023 at 9:48 AM
    #82
    Crush Blue Taco
    Crush Blue Taco Member
    2023 Crush Blue TRD offroad
    none
    Yeah. Would love to see a picture of someone who has these installed.
    Just got a quote from Discount for just shy of $3k with KO2s.
  3. Jan 11, 2023 at 3:05 PM
    #83
    Rogue_12
    Rogue_12 Active Member
    See alot of people running 285/75/r16 tires on this thread. No rubbing with a 2-inch lift? (bilstein 5100 & icon 1.5 Add a leaf) I'm new to the tacoma scene and just want to get the right info for when I decide to start adding things to my truck.
  4. Jan 11, 2023 at 6:06 PM
    #84
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    It really depends on what gen Taco, wheel spacing, and offset. I have the rub at full squish and wheels turned on my 1st gen, but I’m also running 1.25” wheel spacers. I had to flatten the pinch welds, trim the fender liner, and massage the fender well with a 2lb. hammer.
    On my 3rd gen, from what I’ve read I’d have to do a body mount chop and some fender well massaging to fit 285/75R16’s. But I don’t plan to lift that truck anytime soon, it looks great with 265/75R16’s. Not sure what a 2nd gen takes because I’ve never owned one or done the research. YMMV
  5. Jan 11, 2023 at 6:09 PM
    #85
    Proper06
    Proper06 Member
    Tom
    Proper
    Methods up and coming. Scs hold ya breathe
  6. Jan 16, 2023 at 6:39 AM
    #86
    Nimble9
    Nimble9 [OP] visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    I replaced all the rusty bolts on all 5 wheels with new SS bolts to freshen up the look.
    Then this happened
    But this was the only damage. My local tire shop are into off roading (benefits of being close to Rausch and AOAA) so they de mounted the tire, smoothed out the damage and was able to get it to seal fairly easily, though they added some bead sealer for extra security.
    Gotta love how strong these Method wheels are!
  7. Jan 18, 2023 at 5:11 PM
    #87
    Dnolie
    Dnolie Member
    Tacoma TRD Offroad
  8. Jan 25, 2023 at 2:11 PM
    #88
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    WOOOOOOO, a thread I can be proud to join!
    Method MR705 Bead Grip 17" Wheels, 0 Offset with Cooper Rugged Treks in 285/70R17
  9. Jan 25, 2023 at 4:50 PM
    #89
    DJSpeed
    DJSpeed Well-Known Member
  10. Feb 13, 2023 at 9:36 AM
    #90
    Darkice
    Darkice Well-Known Member
    How did that happen? how low was your PSI?
  11. Feb 13, 2023 at 11:26 AM
    #91
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    zigged when I shoulda zagged.
    nah, was hung up on my belly skid and got yanked to the driverside and as the wheel went down the rock it turned the wheel while the yank was in progress
    lesson learned, stack rocks on the way down or i should buy a winch lol
    edit: I think I was at 15 psi
  12. Feb 13, 2023 at 7:52 PM
    #92
    DJSpeed
    does anyone know if you can remove the ring with no problems to lets say.... repaint it then put it back on without taking the tire off??
  13. Feb 13, 2023 at 8:23 PM
    #93
    DJSpeed
    its not a true beadlock. that i already knew for years. and yes the ring does come off cause you can buy replacement rings and even the bolts that hold it in place from method. one thing i am not sure is the ring coming off without the tire becoming. some of my rings are scratched up and wanted to sand it down. sand blast and paint it
  14. Aug 17, 2023 at 11:11 PM
    #94
    Truck_Norris
    Truck_Norris Well-Known Member
    Utah
    1st Love - 2002 Green Mica SR5 AC / New Boo - 2013 Super White Tacoma DCLB
    - Bilstein 6112/5160 Lift W/ OME Uppers and All Pro Expo Springs - URD Exhaust Cam gears - Magnaflow Custom Exhaust - Method 705 Beadgrip 17" Wheels - Falken Wildpeak AT3w 255/80/17 - ARE Camper with Rhino Rack Batwing Awning - Custom Bed/camper Build out - Baja Pods and Lightbar
    New Shoes!
    Method 705 Beadgrips 17x8.5 - 4.75 bs
    255/80/17 - Wildpeaks
    I havent seen many if anyone running these wheels, but i really dig how OEM they look, and the "Beadgrip" feature has been praised by a few different folks.
    I'm liking the Skinnies so far, and no rubbing that I've found. This will be my 3rd set of WPs, because they are just a damn good all around tire.
    Before:
    After:
  15. Aug 18, 2023 at 6:18 AM
    #95
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Shout-out to our Discount Tire Crew! :thumbsup:
    Method 305 Double Black 17x 8.5 4.75 bs/0 offset
    275/70r17 Toyo R/T Trail
    Icon Stage 8... 2" lift front/back (coilover's at factory height setting/RXT leaf pack at option 2)
    kong55, barch88, GHammer and 4 others like this.
  16. Aug 18, 2023 at 8:28 AM
    #96
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    @Truck_Norris what an amazing transformation! Great looking wheel and tire package. Nice job!:thumbsup:
  17. Aug 18, 2023 at 11:30 AM
    #97
    Truck_Norris
    Utah
    Thanks! I actually had the install done at Discount Tire in Holiday UT! They did a top notch job, and even price matched the lugs I found online. All around good service at that location.
    Discount Tire[QUOTED] likes this.
  18. Aug 31, 2023 at 4:48 PM
    #98
    TheFactor
    TheFactor Well-Known Member
    So Cal
    2023 Tacoma TRD Off road
    Fresh out of the oven some old school 301’s
    285/75/16’s Mickey Thompson Baja AT
  19. Sep 12, 2023 at 5:34 PM
    #99
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Got me some 705’s
    Big help from the Discount tire guys here on TW
    Before
    After
    upload_2023-9-12_17-30-42.jpgupload_2023-9-12_17-31-52.jpgupload_2023-9-12_17-32-25.jpgI went with Toyo ATIII 265/70R17’s. Methods are 17x8.5 0 offset. A little wider stance and shouldn’t alter the mpg that bad. Sorry for the dark pics. It’s been raining
    AZDre, TheFactor and Truck_Norris like this.
  20. Sep 13, 2023 at 9:58 AM
    #100
    Discount Tire
    Arizona, USA
    @Kbar the Taco looks absolutely fantastic! Army green and black is where it's at! Thank you for allowing us to be a part of your Taco's upgrade.:thumbsup:
    Kbar likes this.
