Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. Apr 18, 2012 at 6:25 PM
    #2221
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    yup, thats why I added that its good to hit up the local lbs to see what feels good :D
  2. Apr 18, 2012 at 7:52 PM
    #2222
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    Nice! I used to have a Riot...after my shoulder is back to serious riding and falling I'll build another DJ/Park bike.
    I swapped from 2x9 (24t/36t x 11-32t) to 1x9 (32t x 12-34t). I'd say you'd be surprised what you can climb when you don't mentally check out and drop to the granny. I really like it, was kind of a test before I spend money on 1x10.
    Switching to 10spd, with the 12-36t cassettes you get some pretty low gears. Play with a gain calculator and figure what similar gear's you could try on your next ride to simulate that lower gear. You might find that you could go 34t or maybe need a 30t to start out with up front.
  3. Apr 19, 2012 at 5:46 AM
    #2223
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    so exactly what do I need for the swap?
    remove front der. and shifters
    remove two front rings and install bashgaurd
    take out a few link on my chain
    would these two things work with the 1x9 or do I even need to replace the middle gear?
    chain guide
    http://www.pricepoint.com/detail.htm?stylepkey=15288
    chainring
    http://www.pricepoint.com/detail.htm?stylepkey=23476
  4. Apr 19, 2012 at 6:46 AM
    #2224
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    props to the first guy that rides this on trails
    saw this on campus locked next to mine bout 10 min ago
  5. Apr 19, 2012 at 6:49 AM
    #2225
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    :laugh:
    looks like the A hole knocked the bike next to him over
  6. Apr 19, 2012 at 7:06 AM
    #2226
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Just realized that has a front fork, seen a few dbls and a couple triple frames but never a hardtail version:eek:
  7. Apr 19, 2012 at 7:08 AM
    #2227
    crazyengineer
    patrick
    Bristol, TN
    I doubt it, the people with the cheap bikes (read very used walmart specials, etc..) don't care about thier bikes too much. probably just let it fall. I have seen it happen quite often
    you normally see a full suspension?
  8. Apr 19, 2012 at 7:11 AM
    #2228
    Burgman
    Stephen
    Ric VA
    Non suspension, usually old whatever is available frames welded together
  9. Apr 19, 2012 at 7:13 AM
    #2229
    crazyengineer
    patrick
    Bristol, TN
    ah, ok
    that makes more sense. My guess is that the guy got whatever bikes he could, there are a few shops near campus that sell used bikes and a lot of them are older mountain bike....for pretty cheap too.
  10. Apr 19, 2012 at 7:27 AM
    #2230
    Burgman
    Stephen
    Ric VA
    Help: trying to adjust my cateye odometer/spedometer. My tires are 700x54c but the instructions dont go that large. Need a circumference in mm, itll be over 2200 mm.
  11. Apr 19, 2012 at 7:58 AM
    #2231
    zoopla
    zoopla Well-Known Member
    Calgary,Canada
    2011 tacoma trd dbl cab
    K&N cold air intake FXR retrofit/Vleds Avid front bar/side steps 3" Eibach lift
    if you guys are interested in getting a good rack system for you bikes. i can get the rockymounts rack at cheaper price. they fit nicely in the tacoma bed rail system.they also have a locking feature for when you need to get away from the truck for a while :)
    i have the clutch SD (big model) and it fit's all axle's size 20mm , 15mm and standard quick release 9mm.
    here's the website to check it out; http://www.rockymounts.com/truck_bike_racks_s/118.htm
    prices are;
    -9mm clutch; 20$ reg 24.99
    -locking clutch; 35$ reg 49.99
    -clutch SD; 50$ reg 69.99
    -driveshaft HM; 60$ reg 74.99
    -driveshaft SD;70$ reg 89.99
    price don't include shipping, but if interested, PM me with your zip or postal code.
    thks
    pat
  12. Apr 19, 2012 at 8:04 AM
    #2232
    mentose457
    mentose457 Well-Known Member
  13. Apr 19, 2012 at 8:05 AM
    #2233
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I've seen a few of those at SJ Bike Party. Always thought they were a bit strange. Bike Party is a couple thousand lunatics riding bikes in the dark-many of those guys have to get stuck in the crowd once and a while. How do they get off the bike at a light? Do you need a buddy on a regular bike to perch on at the light? :eek:
  14. Apr 19, 2012 at 8:06 AM
    #2234
    Burgman
    Stephen
    Ric VA
    Buh buh but i just want answers... will do this today
  15. Apr 19, 2012 at 8:15 AM
    #2235
    mentose457
  16. Apr 19, 2012 at 8:24 AM
    #2236
    Burgman
    Stephen
    Ric VA
    Hmm fom my odo chart and charts ive looked at online, my tire should be around 2300mm
  17. Apr 19, 2012 at 8:35 AM
    #2237
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  18. Apr 19, 2012 at 8:39 AM
    #2238
    mentose457
  19. Apr 19, 2012 at 8:48 AM
    #2239
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
  20. Apr 19, 2012 at 9:20 AM
    #2240
    Burgman
    Stephen
    Ric VA
