Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. Sep 5, 2012 at 7:28 PM
    #3421
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2021 Tundra TRD Sport 4wd
    Yes, I sold my '13 Taco. :'(
    Thinking about doing this to my V10 so i can BRAAAAP at Pismo Dunes....
    :eek: SIKE.
  2. Sep 5, 2012 at 8:44 PM
    #3422
    JordanSmith127
    JordanSmith127 Jordemo805@yahoo.com
    JORDAN
    SAN LUIS OBISPO & MARIN
    2017 DCSB 4X4 TRD SPORT
    ICON / LSK
    please dont :confused:
  3. Sep 5, 2012 at 8:45 PM
    #3423
    STiLL WILL
    CA
    I'll never pinch flat though. :D
  4. Sep 5, 2012 at 8:52 PM
    #3424
    BurqueTaco
    BurqueTaco Well-Known Member
    Albuquerque New Mexico
    04 trd tacoma 4x4
    Custom pinstriping, pleasure hole, Fox 2.0 rear, Fox 2.0 coilovers.
    Slightly off-topic but you gotta love how Fox adopted the upside down shock idea for truck shocks but they know bikes are all about swag.
    ps-sb-eb-eb-main_3a5a41e7c4c456ecff83059157cecbc2b0018f93.jpg40-fit-rc2-b-main_ce8cd631a135d0833308c224965b26ce56cbf6da.jpg
  5. Sep 5, 2012 at 8:59 PM
    #3425
    JordanSmith127
    JORDAN
    ICON / LSK
  6. Sep 6, 2012 at 6:41 AM
    #3426
    mentose457
    mentose457 Well-Known Member
  7. Sep 6, 2012 at 7:24 AM
    #3427
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Weight is a bigger concern on a mtb and an inverted fork would likely have to be much heavier to provide the same rigidity that current fork design provides. Plus, impact forces aren't as high because of the weight of the bike and rider. I guess I'm saying it's a compromise between the heavier fork and the forces it needs to absorb-the current design reflects that pretty well. Some have argued damage to the lowers would also be a problem in the inverted design but that really isn't a big deal.
    For motorcycles, inverted makes sense. The fork is more rigid and is capable of absorbing much more of the force generated from landing a big jump. But, the design requires the uppers to be much larger in diameter and that's what makes them heavier.
  8. Sep 6, 2012 at 9:11 AM
    #3428
    STiLL WILL
    CA
    This ^^
    To add, one of the major benefit for an inverted strut(fork) design is less unsprung weight. On an inverted setup, the upper(heavier) tubes are attached to the frame instead of the wheel. As a result, the wheel, theoretically, will respond MUCH better to terrain changes---sometimes giving the bike a "lighter" feel.
    The other major benefit of inverted is strength. Again, in theory, an inverted fork will take on abuse much better. On a mountain bike/dirt bike, leverage forces that cause "fork flex" are the greatest near the crowns. On conventional non-inverted setups, the bare stanchions(the "inners") have to bear the leverage force. On an inverted setup, you move the bigger, stronger "outers" up to the crown area which pretty much eliminates any risk of fork flex---permitting rigidity for better handling performance.
    The main reason I believe MTB industry hasn't widely embraced this technology is simple...as stated above me, body weight of the riders and overall weight of the bikes combined are not enough to warrant such a design. Racecars & dirtbikes will always subject suspension to a greater set of forces than a human would on a bike.
    BUTTTTT, I honestly wouldn't mind ever entertaining a new DH build using a Manitou Dorado Pro dual crown inverted fork. I've only heard good things about it and it's pricing/weight fall right between Boxxers and 40's. :D
  9. Sep 6, 2012 at 9:21 PM
    #3429
    BurqueTaco
    04 trd tacoma 4x4
    Excellent points guys. I would have to say that I've seen the Manitou guys/gals go just as fast as anyone else down here at the Chile Challenge in AngelFire. Of course it's still usually a Yeti guy taking the top spot and the only reason for that is pure swag.
    As far as rigidity goes I don't believe there would be a noticeable difference just because having a dual crown fork with and a 20mm axle on a mountain bike is enough that whats between them won't be a game changer.
    Edit: You still won't see me giving up my 40's anytime soon. :jellydance:
  10. Sep 6, 2012 at 10:24 PM
    #3430
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Something else you notice between a motorcycle and bicycle is the width of the tire/rim combo. For a bicycle, you'd need to widen the triple clamp to enable the tire/rim to clear the upper. Again, for a motorcycle, this isn't such a big deal (weight wise and not the tire/rim sit below the uppers too.).
  11. Sep 7, 2012 at 7:41 AM
    #3431
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    OOOOOH man, I haven't ridden my bike in months!!!!!
  12. Sep 7, 2012 at 8:25 AM
    #3432
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  13. Sep 7, 2012 at 8:28 AM
    #3433
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    what do you mean by "swag"?
    normaly swag means "shit we all get".
  14. Sep 7, 2012 at 8:46 AM
    #3434
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Another benefit of inverted forks would be dust, dirt, water and mud being pushed away from the seals instead of into them...........if you don't run boots, which I see a lot of. Also being inverted generally moves the seal area down, away from where the faunky shit slinging tire is.
  15. Sep 7, 2012 at 1:59 PM
    #3435
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
  16. Sep 7, 2012 at 3:00 PM
    #3436
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    Hi guys!, I havn't posted in here before my old bike was a Giant revel rank 1:eek:. today I picked up a Giant XTC 29'er rank2 :cool:. here are some pic's of my new rig. When i ride i do the trails in the MT. Baldy area.
  17. Sep 7, 2012 at 3:21 PM
    #3437
    JordanSmith127
    JORDAN
    ICON / LSK
    welcome man!
  18. Sep 7, 2012 at 8:01 PM
    #3438
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Too soon to know.
  19. Sep 7, 2012 at 8:07 PM
    #3439
    Bosworth5
    Bosworth5 Well-Known Member
    Orange County
    10 PreRunner Offroad
    Colormatched Satoshi, HID Converted Hella 500 behind grille, Bilstein 5100 X4 at 1.75" in front, extra drings.
    Went off a rut/jump yesterday flying down a trail, landed on the slanted left side of the trail and my front wheel washed out, broke the fall with my head/face and broke my sunglasses. Also landed directly on my pedal with my thigh. I am so proud of my bruises.
  20. Sep 7, 2012 at 10:34 PM
    #3440
    STiLL WILL
    CA
    I've hopped on one for half a trail ride....liked it. You get slightly less "rolling ease" over obstacles than a full 29er, BUT as a plus you get better steering response on tighter trails than a niner.
    In my opinion it's a great "big wheel" mountain bike for those who fall under 6 feet in height. I'm well under 6 ft tall and I find 29er bikes(I've tried 5 so far--2 on the same trail back to back) are just too big for my liking on the technical(turning) stuff. Someone taller(6ft+) with longer limbs could probably flick around and turn a 29er much more easily.
    I believe there will be a great following for these INBETWEENer bikes.
