Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. Sep 27, 2012 at 1:54 PM
    #3541
    Bosworth5
    Bosworth5 Well-Known Member
    Orange County
    10 PreRunner Offroad
    Colormatched Satoshi, HID Converted Hella 500 behind grille, Bilstein 5100 X4 at 1.75" in front, extra drings.
    Both my rides got new rubber today. Tacoma got 285-75-16 BFG AT
    And the bike finally got converted to tubeless (with Gorilla tape) with some Hans Dampf! Stoked!
  2. Sep 27, 2012 at 1:56 PM
    #3542
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    Both look good. Is tubeless really a good mod, what are the pros and cons? Thanks, just wondering.....
  3. Sep 27, 2012 at 2:02 PM
    #3543
    Bosworth5
    Orange County
    Well I was getting pinch flats about once a week running tubes so I was forced to run a higher air pressure. With tubeless there are no tubes to pinch flat so you can run a lower air pressure(better traction). Also without tubes your tire settup is lighter. Downside is if you do lose air with tubeless on the trail (doesnt happen alot I have heard), you need a CO2 cartridge to seat the bead again. Also putting the tires on you need a compressor to seat the bead unless you are skilled.
    If I am missing anything please feel free to chime in.
  4. Sep 27, 2012 at 2:06 PM
    #3544
    toughtaco
    I would never be able to keep them seated then!!!
  5. Sep 27, 2012 at 2:33 PM
    #3545
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I run both of my bikes tubeless now and have been able to drop the pressure from 40 psi tubed down to 30 front and 32 rear. Much better traction, and I have yet to burp them on the trail.
    I used the DT Swiss kit and fluid on my first set (they are DT Swiss rims so I had to buy the kit), and the fluid is great but WAY too expensive (~$45 PER TIRE!), so I switched to Stans now. So far I have had no puncture flats, but I did cut the sidewall on a brand-new tire. That would have flatted a tubed tire as well, though.
    I still carry a spare tube or two on rides just in case. Need to remember to carry some tire boots as well.
  6. Sep 27, 2012 at 5:56 PM
    #3546
    partsdude
    partsdude Well-Known Member
    Utah
    05 Tacoma 4x4 trd
    Level kit, BFG tires, Bed Gear gate
    Its what snobord552 said.
  7. Sep 27, 2012 at 9:17 PM
    #3547
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2021 Tundra TRD Sport 4wd
    Yes, I sold my '13 Taco. :'(
    All that.
    And worse case scenario, if you puncture in the middle of a ride, just carry a spare tube and a pump to get you to the end of the ride and deal with redoing the sealant later.
    Tubeless is much lighter and the fact that you'll never pinch weld is worth the effort in conversion. Lighter rolling wheel weight = more responsive bike on climbs, turning, and let's your suspension do it's job better.
  8. Sep 27, 2012 at 9:18 PM
    #3548
    STiLL WILL
    CA
    Pinch FLAT lol. Damn phone retardocorrect.
  9. Sep 28, 2012 at 5:59 AM
    #3549
    nhmtns
    nhmtns Member
    Mt. Washington Valley, NH
    Sold my Tacoma
    Singlespeeds are a blast to ride. No shifting, no noises, just pure riding.
    Here's my old Surly KM with lots of Chris King goodness
  10. Sep 28, 2012 at 6:49 AM
    #3550
    partsdude
    Utah
    05 Tacoma 4x4 trd
    Nice bike nhmtns. S.S is the only way to go. Im thinking about building a 29er.
  11. Sep 28, 2012 at 7:56 AM
    #3551
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Tubeless and loving it! Will never go back. I've had one flat over the last year and that was my fault for not refreshing the goop.
    Edit: on Porc Rim in the rain nonetheless.
  12. Sep 28, 2012 at 8:21 AM
    #3552
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I converted my 26er to tubeless first and was so happy with it I converted my 29er before the old tires were even worn out. I love it, no problems at all.
  13. Sep 28, 2012 at 8:26 AM
    #3553
    JordanSmith127
    JordanSmith127 Jordemo805@yahoo.com
    JORDAN
    SAN LUIS OBISPO & MARIN
    2017 DCSB 4X4 TRD SPORT
    ICON / LSK
    Tubeless is great if u use it correctly iv used it for 4 years becuz i got sick of flats whith tubes i have only had one tubless fail in thoes 4 years and that was that video i posted where i blew up my wheel, i personaly run it front and back alot of people will only run it in front becuz of burping air in the back, if ur running either a tubless rim or tire it will almost always work good but a tubless tire and rim helps alot. Make sure to never use a tire to big for the wheel i was running a 2.5 tire that wasnt a tubless tire on a tiny ass 21mm wheel. By far best DH hoop for tubless are the mavic 823 and there the strongest too there not drilled all the way thru eiter so u dont need to tape the wheel. Tubless fluid isnt a big deal stans is the best deal alot of people tho dont even use fluid when doing theres its just kinda a safty proceedure against burping air so not woth spending tons on it
  14. Sep 28, 2012 at 1:21 PM
    #3554
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
    Have done a couple tubeless conversions (both ghetto tubeless) and I liked it quite a bit. Bought a new set of rims and just haven't gotten around to it, but we getting ready to ride today, and a guy was coming back from the trail with a flat. He told us " I like walking in the morning" needless to say, I need to do it again, just being lazy. Off all next week, so I will have time then.
  15. Sep 28, 2012 at 2:05 PM
    #3555
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    hey i may decide to go tubless on my new bike might get you to come on over and help! and does anyone one in the downhill community run tubless?
  16. Sep 28, 2012 at 2:08 PM
    #3556
    tacomaforlife
    Robbie
    AIKEN, SC
    also i lost your phone number.:rolleyes:
  17. Sep 28, 2012 at 10:09 PM
    #3557
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    did you get the new stumpy fsr or something else?
    look at a trek, specialized, giant, etc. those are going to be better quality than walmart bikes. if you can check out a bike shop. try that but be careful because some definetely just want to sell a bike and not really care. most i have been to actually want to help you out though
    just make sure it fits well and your not cramped or stretched out. usually if it has an air fork it is better also.
  18. Sep 28, 2012 at 10:16 PM
    #3558
    Deercantseeme
    Deercantseeme Well-Known Member
    Massachusetts
    I bought a giant revel 1 in the spring for $550. Pretty decent bike. I'm 5' 9" 170 lbs and the only complaint was the fork isn't great if you ride aggressively. I got a decent rock shox fork for about $170 and $6 grips (stock ones suck). Overall I'm pretty happy with the bike.
  19. Sep 29, 2012 at 7:25 AM
    #3559
    HEAVY WT
    HEAVY WT Well-Known Member
    Matthew
    LA
    16 T4R TEP
    New bike... Epic Elite
  20. Sep 29, 2012 at 5:38 PM
    #3560
    JirafaBo
    JirafaBo Well-Known Member
    Bo
    Orlando
    '12 Black Access Cab TRD Sport
    Alafia? Or Santos?
