Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. Mar 7, 2013 at 8:47 PM
    #4921
    keylay
    keylay Well-Known Member
    Kyle
    Houston
    03 4Runner 4WD
    2005 Gary Fisher Wahoo
    Kenda Nevegal front tire
    some Bontrager rear tire
    Rock Shocks Tora SL Air 100mm
    Avid BB7 mechanical brakes on stock pads
    Shimano clips
    Chillin' in the hotel room at Fruita Fat Tire in 2010. No trail pics because i was RIDING!
  2. Mar 8, 2013 at 9:05 AM
    #4922
    Supertramp
    Supertramp dismember
    NC Mountains
    2009 Double Cab TRD Off-road.
    That's from a movie called "From the inside Out" if you want to see the jump. On Hulu plus if you have an account.
  3. Mar 8, 2013 at 9:22 AM
    #4923
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    And it's a pretty good movie too.
  4. Mar 10, 2013 at 4:21 AM
    #4924
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    Anyone have any experience with the RIP from Niner mt bikes? I am going to test ride it the end of April. I think that might be my next bike not sure yet.
  5. Mar 11, 2013 at 6:41 AM
    #4925
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Thanks. Ill have to check it out
  6. Mar 11, 2013 at 9:44 PM
    #4926
    GAmtber23
    GAmtber23 Well-Known Member
    Georgia
    '10 Tacoma Access cab 4x4
    Window tint, debadged, fog-lite anytime mod, aftermarket taillights, low profile toolbox modded with three mountain bike mounts, JVC dvd headunit, Kicker hideaway, Fox 2.5" IFP with DSM UCA's, Allpro standard (soon to be expedition) leaf pack, 255/85r16 BFG KM2's, 1.25" spidertrax wheel spacers, powdercoated gloss black TRD offroad rims with color matched center caps.
  7. Mar 13, 2013 at 10:23 AM
    #4927
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    So the valves that are on my current tires have real skinny stems and I cant air them up... Does anyone know what these skinny vales are called?
    Also I need a new rear tire. Currently they are tubeless. I have brand new tires on my old bike that I would like to switch over if I can. Is there anything special that I would have to do to them? They are Kenda excavators
  8. Mar 13, 2013 at 11:51 AM
    #4928
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    youve got presta valves, i like them better, wayyy easier to air down. you probably need to get an adapter from a bike shop, some pumps come with them though or are compatible with both schrader and presta
    tires might work, i think its possible but i dont think they will be easy to set up or work well unless they are tubeless compatible. if you are already set up they most likely will work. only thing you will need is rim tape, valves and sealant. i think that should be it though, someone correct me if im wrong
  9. Mar 13, 2013 at 11:52 AM
    #4929
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Thanks!
    Yea the bike is already set up for tubeless, im just wanting to put a new tire on.
  10. Mar 13, 2013 at 11:56 AM
    #4930
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    You can always put a tube in there, you don't have to stay tubeless. If the tires you want to swap on are not "UST" or "tubeless ready," you could go the Stan's route but may or may not work very well.
  11. Mar 13, 2013 at 12:26 PM
    #4931
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Used to have a Windsor 29er. Sick bike. Looking to get another 29er maybe.
  12. Mar 13, 2013 at 12:28 PM
    #4932
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    So if I went back to a tube on the rear I would just remove the presta valve and change the tire like normal?
  13. Mar 13, 2013 at 3:04 PM
    #4933
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    You would have to remove the presta stem, which should just have a knurled circular nut holding it on to the rim (there may be some dried tubeless sealant in the tire making it stick).
    You will want to get a tube with a presta valve, which shouldn't be hard to find (wherever you get an adapter or pump that supports presta valves should also sell presta tubes). If you try to go with a Schrader valve tube, you may have to drill the hole out to get it to fit, which would kill the rim for any future tubeless setup.
    Just put the tube and tire on like normal -- my bike came with tubeless ready rims, but they had tubed tires on it. I rode those until they wore out and switched to tubeless. The tires are rims are similar, but tubeless tires usually have tighter tolerances and fit a lot tighter.
    Just as a note, to air up through a presta valve, there is a tiny knurled pin in the middle of the valve that should be loosened to put air in, and then tightened back down.
  14. Mar 13, 2013 at 3:15 PM
    #4934
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2021 Tundra TRD Sport 4wd
    Yes, I sold my '13 Taco. :'(
    The only time I think you'd want to go with a tube again is if you pop your tubeless set up on a trail and carry a spare tube. ;)
    I've run tubeless for the last 3 years, and it sure beats the hell out of getting pinch flats. Never popped once.
    I've never had problems with running non-ust tires on ust wheels using Stans. Just make sure you give enough time to let the sealant cure.
    If you're looking for a pump for presta, I recommend any $35-$40 BLACKBURN pump w/an "All Head" that can pump both presta and Schrader w/o adapters.
  15. Mar 13, 2013 at 3:18 PM
    #4935
    Supertramp
    NC Mountains
    Raced a Jet9 for a few seasons, one of the best bikes I've ever owned....until it broke, :(
    Niner customer service was great with a replacement rear triangle.
    My best friend rode his RIP9 with me across CO and UT during out San Juan Hut trip and he absolutely loved it, never had a problem.
  16. Mar 13, 2013 at 10:24 PM
    #4936
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    Usually just a lurker, but this may be post worthy....
    Got off work, decided to build up my old covert frame with spare parts in the garage.
  17. Mar 14, 2013 at 5:29 AM
    #4937
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Nice spare parts cache........and nice revival.
  18. Mar 14, 2013 at 6:43 AM
    #4938
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I tried to put a tube back in but I dont think my rims will accept the wider schrader valve. the hole was too small...
    I was having a hard time getting the damn bead to seal...Im not sure If it ever did since I never heard the "pop". also I couldnt get soapy bubbles to go away. will the sealant basically glue to tire to the rim or what?
  19. Mar 14, 2013 at 7:13 AM
    #4939
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    You need a tube with a presta valve, they are pretty standard these days.
    A non-tubeless tire should seat pretty easily, but it all depends on the tire. Pump it up to the max, bounce it around. There is usually a line on the tire around the edge of the rim that should tell you if it is seated. If it isn't, it probably will on your first ride.
    I am not sure what sealant you are using, but generally it is used to fill any pinholes in the tire and around the seal. It is also supposed to fill any small punctures. It does not glue the tire to the rim.
  20. Mar 14, 2013 at 8:04 AM
    #4940
    STiLL WILL
    CA
    As Rich said above me,
    It sounds like you'll need a tube with a presta fitting.
    As for sealing it, it will take a few tries---the sealant isn't suppose to act like a bonding "glue" but just to make sure every little hole is covered.
    Once you get the tire bead to lock in/"pop" apply the sealant and re-check for leaks. Once you know there isnt anymore leaks, let it cure. I do this by resting the wheel on top of a bucket or garbage can and flipping it on each side every 20mins for 1-2 hours(or whatever your OCD thinks is enough time lol).
    IF ALL ELSE FAILS....just take it to your LBS to have them mount it for you. They shouldn't charge you more than $5-$10 if anything at all.
