Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. Mar 14, 2013 at 8:20 AM
    #4941
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    So I was suppose to seat the bead first, then go back and pop the bead on one side and add sealant?
    I got some stans sealant.
    Ill check it when I get home tonight and see if its still holding air.
  2. Mar 14, 2013 at 9:03 AM
    #4942
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I put the sealant in when I first mount the tire. With some sealants, you can remove the core of the presta stem and pour it through the hole, but that can take a while and be a mess.
    Pump the tire to like 60psi to see if the bead will seat. You want the sealant to coat all internal surfaces, so you need to rotate it around like Still Will said.
  3. Mar 14, 2013 at 9:06 AM
    #4943
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2021 Tundra TRD Sport 4wd
    Yes, I sold my '13 Taco. :'(
    Depends how you're applying the sealant.
    If you use the method where you pour the stands in the tire with their measuring cup, then you must dismount a small section of the tire to apply(pour) the sealant and remount.
    ...BUT I PREFER seating the tire first, and then removing the core of the Presta valve and using this to add sealant VIA the Presta valve. I've had good luck doing it this way.
    or
    Pretty good instructions on the Stans page:
    http://www.notubes.com/detailed_kit_instruction.aspx
  4. Mar 14, 2013 at 9:08 AM
    #4944
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    I want!
    What's everyone think of the new Enduro 29'r?
  5. Mar 14, 2013 at 9:12 AM
    #4945
    scottg918514
    scottg918514 Well-Known Member
    2013 DC, TRD 6-spd Manual, 4wd
    Mine broke as well, right before the recall. So, I had to wait 6 months for a new frame. But, they gave me a deal on a One 9 frame $300, that I sold to my friend. However, that bike just fell off his rack and got run over, several times.
    Instead of waiting for my new Jet frame, I bought a Pivot Mach 429 and built that up. When my jet frame came in, I sold it.
    Love the 429. Also had a Air 9 for my ht, but was a medium and I started have back issues. I switched to a Specialized SJ HT, expert (large) and love it.
  6. Mar 14, 2013 at 9:12 AM
    #4946
    STiLL WILL
    CA
    It's a great bike. Where I ride, I'm seeing tons more Spesh Enduro niners & SC Tallboy LTc's on the trails.
  7. Mar 14, 2013 at 11:09 AM
    #4947
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    it looks like a solid bike, I want a 29er but now that i know they are opening a new bike park close by i don't know that I would want to go to 29er anymore...unless i had 2 bikes haha which probably wont happen for a bit
  8. Mar 14, 2013 at 12:27 PM
    #4948
    teneighty
    It would be so nice to have two bikes!! Haha I wish...
    It seems like a one bike quiver for what I ride. I do a lot of climbing and downhill but the downhill isn't mach10 off 30 footers... I love my buddy's Enduro 26 and think this would be the same but just climb a bit better...
  9. Mar 15, 2013 at 3:09 AM
    #4949
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    Thanks I am looking into that bike, going on a test ride in April.
  10. Mar 18, 2013 at 6:18 PM
    #4950
    113tac
    Stephen
    Northern Virginia
    just saw this video about the ripley 29, this bike looks pretty awesome. I would love to take a closer look at the suspension too, from an engineering standpoint it looks pretty innovative. its a sexy bike too, i cant wait to see one in person, hopefully my shop gets one in stock soon, i would definitely take it for a test ride.
    http://youtu.be/f_4Lj3j3FJY
    another thing, ill be demoing treks 2013 lineup on sunday, atleast hopefully, if the snow melts and dries enough. i really want to get a ride on the rumblefish and finally see if all the hype is true.
  11. Mar 18, 2013 at 6:54 PM
    #4951
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Cool video. I didn't understand the comment about the taper. Basically, all that the taper in the steerer tube does is allow the tube to be press fit to the shock and from what I remember, it's not all that long to begin with-certainly not as long as head tube?
    The other big question I have is regarding the pivot and eccentric. Those two parts make a big gap in the seat tube-I wonder if they'll see problems in that section of the frame?
  12. Mar 18, 2013 at 7:05 PM
    #4952
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    That linkage system is crazy cool! I wonder if there's any concern over dirt and water penetrating the link and jamming up those bearings though :confused:
  13. Mar 18, 2013 at 7:10 PM
    #4953
    113tac
    Stephen
    Northern Virginia
    yeah i dont know, i guess it was longer in 2011? haha idk i see what you mean though
    do you mean from a strength standpoint? i could see that being a possible problem, but there looks to be a lot of carbon around the bottom bracket and im guessing they use more around the pivots to help. i wouldnt see many more problems than the yeti sb66 since they both use an eccentric type pivot. The weight is comparable to the SC tallboy LT though so maybe not as much extra carbon fiber as i think.
  14. Mar 18, 2013 at 7:14 PM
    #4954
    113tac
    Stephen
    Northern Virginia
    other than there being more moving parts, i dont see there being too much of a problem compared to other bikes... although seeing this does scare me a little haha so many pieces to break/wear
  15. Mar 18, 2013 at 7:51 PM
    #4955
    jodiddly33
    Jonah
    DFW
    2010 Golf TDI
    Oh dang, haha that's intimidating. I'm sure Ibis saw some benefits in there somewhere so we'll see
  16. Mar 18, 2013 at 8:12 PM
    #4956
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Yes. From a strength perspective. Just seems like a weak point.
  17. Mar 18, 2013 at 8:18 PM
    #4957
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    You have to admit that the design is pretty interesting and ingenious.
  18. Mar 18, 2013 at 8:50 PM
    #4958
    jodiddly33
    Jonah
    DFW
    2010 Golf TDI
    oh yeah without a doubt
  19. Mar 19, 2013 at 5:50 AM
    #4959
    113tac
    Stephen
    Northern Virginia
    yeah definitely, its awesome seeing companies changing things up
  20. Mar 19, 2013 at 7:21 AM
    #4960
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I see that a couple of guys from a local shop managed to take two for a ride...waiting for opinions. Big grins in the picture tho.
