Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. May 30, 2013 at 7:31 PM
    #5281
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Yeah it's a great place. Let me know if you come out this way. Ill join ya. I don't know about your brake issue though. I know I'm going to need new pads after this trip.
  2. May 30, 2013 at 7:34 PM
    #5282
    Bosworth5
    Bosworth5 Well-Known Member
    Orange County
    10 PreRunner Offroad
    Colormatched Satoshi, HID Converted Hella 500 behind grille, Bilstein 5100 X4 at 1.75" in front, extra drings.
    Finally broke 4 minutes on my favorite Dh trail! Lost my pedals twice on that run and have come to the realization that I need riding shoes. Anyone have any suggestions? I have Crankbros 50/50 pedals that came on the bike.
  3. May 30, 2013 at 10:38 PM
    #5283
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I'm running flats and 5.10's. Love them. I also have a pair of Lakes with Crank Bros cleats. Very happy with them too (with older style Mallets).
  4. May 31, 2013 at 12:23 AM
    #5284
    ninernation
    ninernation Well-Known Member
    WA
    TRDOR
    OME, ALUCAB, RCI
    5.10 impacts and teva links are both great
  5. May 31, 2013 at 6:02 AM
    #5285
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    yeah i like my links, they have pretty good traction. my only complaint is that they dont have much toe protection so i wouldnt recommend them if you were using them for really rocky terrain. other than that I used them with some old azonic flat pedals on my dirt jumper and they worked great
  6. May 31, 2013 at 6:16 AM
    #5286
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Zippity is awesome and so is Shoots and Ladders!
    Stephen, have you tried gently prying the pistons apart? Do you have a bleed kit handy?
  7. May 31, 2013 at 7:17 AM
    #5287
    Misfit
    Misfit Well-Known Member
    IL
    2017 SR 2.7L 4x4 5MT
    I would venture to say there is too much fluid in that line/caliper. Pick up the Avid bleed kit bc you'll need it. I would open the lower bleeder and see if it will compress in then, if it does then just re-bleed and be on your way.
    If it doesn't, then you have a caliper problem and will need at the very least a rebuild kit (If available). Remember to wipe and clean quickly, as the brake fluid eats paint.
  8. May 31, 2013 at 8:06 AM
    #5288
    113tac
    Stephen
    Northern Virginia
    yeah i left the old pads in the used a flat head and twisted it to try and get them to go back in. i dont have a bleed kit so im probably gonna buy one soon, the brakes could probably use a bleed anyways
    yeah thatss what I was afraid of. im gonna try and push the calipers in again today and if that doesnt work ill get a bleed kit and bleed the brakes then see what happens...im gonna be pissed if I can't get a bleed kit in time and have to take it to the shop because the only enduro race within a few hours is next weekend and the shop usually takes forever to do work...
  9. May 31, 2013 at 8:23 AM
    #5289
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yeah, unfortunately you may have to open the bleed port to relieve pressure, which means possible air in the line.
    You could try opening the upper bleed port just enough to let fluid seep out, that might relieve enough pressure with less chance of getting an air bubble down low. Close it up quickly.
    Bleed kits come with nifty wedges for pressing and holding the pistons in place. Bleeding is kind of a pain at first, getting used to the order of things you have to do, but it gets easier.
  10. May 31, 2013 at 8:31 AM
    #5290
    113tac
    Stephen
    Northern Virginia
    ill probably try that, i saw a few others recommend opening the port a little on mtbr also. i just dont understand how there would be too much fluid when fluid hasnt been added. i wonder if the high temps have anything to do with it, it was mid 90s yesterday.
  11. May 31, 2013 at 8:37 AM
    #5291
    Misfit
    IL
    Have you had them since new? If not, someone could have tried to bleed them, while worn and added fluid.
    There may also be a defective seal or valve that isn't allowing the back-flow like it did on the front caliper. Its been awhile since I worked on any though..
  12. May 31, 2013 at 12:07 PM
    #5292
    Hoyal
    Devin
    2013 Tundra
    We did joes ridge into mojo which is a newer trail came off a roller over a rock and boom on the ground I went. Mojo is awesome.
  13. May 31, 2013 at 10:31 PM
    #5293
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    Thoughts on mechanical vs hydraulic brakes?
  14. Jun 1, 2013 at 5:11 AM
    #5294
    Airun
    Aaron
    Show Me State
    I think those running cable driven discs are fine with them and they work great and reliable and easier to tweak on trail-side. However, anyone that has had hydros, can't imagine going to a clunky ole cable driven system.
    Pros and cons both ways I guess. Cost may figure in as well. I've had some major headaches bleeding hydros, but have always figured em out ok.
  15. Jun 1, 2013 at 6:01 AM
    #5295
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Mechanical discs are a good alternative but if you plan on getting pretty serious then a hydro setup is the only way to go. I am looking into getting a commuter bike to mess around on and it has mechanical discs that stop pretty well although the XT brakes on my Rumblefish will throw you over the bars if your not careful.
  16. Jun 1, 2013 at 6:20 AM
    #5296
    dexterdog
    Oly WA
    2012 F150
    My friend and I rode a nice, muddy 14 mile loop yesterday. Basically a 7 mile climb through muddy lowlands and muddy clay singletrack up to a nice flowing singletrack down. Nice rooty drops with some fun and tight switchbacks. The overgrown brush beat the hell out of me and I went down on one section but not too bad of a wreck. Overall, it was a blast. Should be really good when it dries out.
    My friend is a little out of shape so I got to rest on the climbs. He is quicker on the downhill sections but opted to follow. I hope I didn't hold him up too much. It was the first time for him on this loop so he was pleasantly surprised on the downhill. I have also decided I need to look at getting rid of the Nevegals. I just don't feel comfortable on the berms and they do not clean out in the muddy stuff.
  17. Jun 1, 2013 at 6:30 AM
    #5297
    Airun
    Aaron
    Show Me State
    Oh man dexter, I gotta plug the Continental Trail King. I've got a 2.2 up front and have been riding it for a year. Mounted up tubeless with Stans no problem and has a nice weight, long treadwear and bites super into turns. I'm finally seeing the TK getting some great props in the media now as well.
    Also looks badass!
    I just run whatever 2.1 in back with a finer faster rolling tread, currently the WTB Wolverine and got an Exiwolf TCS in the waiting as well as a Bronson. I like the WTB TCS lineup due to lower price, great tubeless function and decent performance. Just couldn't find a WTB offering that I liked for an aggressive front tire.
    I'm mostly riding hard pack and Ozark rock however. No loam here:(
  18. Jun 1, 2013 at 6:36 AM
    #5298
    dexterdog
    Oly WA
    2012 F150
    I am running tubeless as well. Not alot of hardpack at the moment thanks to the amount of rain we have had. I might modify the Nevegals a little so that they clean out a little better and then when it dries out look at switching. I agree the TKs are a nice option. I am also looking at a Specialized tire as it got good reviews but is it bad juju to run a Specialized tire on a Trek?
  19. Jun 1, 2013 at 6:52 AM
    #5299
    Airun
    Aaron
    Show Me State
    No bad juju there. Spec makes some great offerings.
  20. Jun 1, 2013 at 7:11 AM
    #5300
    Hoyal
    Devin
    2013 Tundra
    I have the continental trail king 2.2 in the rear of my trek and a 2.3 up front. But ill be putting a maxxis ardent up front soon.
