Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. Jul 12, 2011 at 3:17 PM
    #561
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    x2 on the weight. I used to have a haro bmx bike and that thing was sooooo heavy...part of it was probably because it was a low end bmx bike. But like he said you can always upgrade components later on.
    i also have a question guys, i want some clipless pedals but also want to be able to keep riding with flats when i dont want to ride with the clips. I was looking at getting the crank brothers mallets but i noticed a lot of people sell them...is there a reason like they are bad pedals or is it just because of weight?
  2. Jul 12, 2011 at 3:25 PM
    #562
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    My POS and wife's Specialized.......AND WIFE
  3. Jul 12, 2011 at 3:31 PM
    #563
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    I hear the egg-beater style tends to break easier. I would check out the Shimano SPD. they have a couple combo ones. I went all clipless, I think the M520s. I've had them a couple weeks now and really like clipless. I used flat pedals yesterday and it felt so awkward. If you area out for a sunday stroll you aren't required to clip in all the time FWIW.
  4. Jul 12, 2011 at 3:54 PM
    #564
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    I am going to counterpoint/disagree, but please, accept as open discussion - no offense meant!:)
    1. A light frame is great, but it is pretty rare to find
    a) frame weights on cheap frames
    b) frame weights on bikes sold as completes only
    Also, the weight on a frame is one of the least important things, it is centered, relatively well balanced, and in general, rarely more than 1/6th of the total weight of the bike. So losing 250g (~1/2lb) will not be very noticeable.
    2. Fork length is less important than geometry. Besides, in my experience, unless you get into the $500-750 bike range, very few will use full travel, and not have enough dampening to make much of a difference. Sucks, but the forks on $400 bikes 5 years ago were WAY better than those spec'd now.
    3. A valid point, and I love discs - BUT, it is pretty common to find really crappy discs, just to say it has discs. In the budget arena, rim brakes with good pads are generally comparable to to cheap discs. Not always, but a consideration.
    Lastly - Decent tires are all but impossible on a cheap bike. They all have wire beads, and weigh 200g + more than they should. I would say replace them, but decent tires will run $60-100 bucks a pair. And a fork or wheel upgrade will run $200 bucks on wheels and $400 on a fork.
    My advise would beto ride it until it breaks, or you decide you want to upgrade. If it is in good shape, you will get $150 bucks or so for it.
    Then spend the $700 bucks you would spend upgrade the old bike, along with that $150 from the sale, on a $1000 bike, or nicer.
    I tried the whole "upgrade the cheap bike". I ended up with a bike that had decent upgrades, but the geometry was a bit off, and I wanted a new bike anyways - as my riding progressed, the basic XC geometry of beginner bikes did not work for me. And I spent WAY more than buying a nicer bike off the shelf. Plus, unless you are spending money on high end components, you dont lose a ton of weight. Especially in wheels, tires, cranks,and forks.
  5. Jul 12, 2011 at 4:54 PM
    #565
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I've had Mallets for a couple of years. I will ride without clips frequently and it's no problem. I've had similar SPD's on my Zaskar and had no problems either.
    The egg-beater allows for more side to side movement making them easier on your knees. I prefer the Mallets for this reason but honestly, both are pretty good pedal systems.
  6. Jul 12, 2011 at 4:59 PM
    #566
    113tac
    Stephen
    Northern Virginia
    i have actually heard that too. I actually talked to the lady at my LBS today and she showed me some SPD's...i didnt like the ones she should me because they were the same size as my stock pedals but with more to break if i wear flats. i dont want something sticking out the bottom of my pedal because i found out yesterday it is very easy to rub the pedal on the ground if i fall haha. I will have to check out other models.
    what are the SPD's you have, id like to check those out
  7. Jul 12, 2011 at 5:07 PM
    #567
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    They are similar to the 530 but double sided (and older than dirt).
  8. Jul 12, 2011 at 5:10 PM
    #568
    113tac
    Stephen
    Northern Virginia
    okay cool thanks man
  9. Jul 12, 2011 at 9:11 PM
    #569
    113tac
    Stephen
    Northern Virginia
    alright cool stuff thanks for the info...i should have bought yours haha i didnt even think about that til now
  10. Jul 13, 2011 at 5:58 AM
    #570
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    thanks for the help. I will mostly be riding on paved trails with the wife but we do have some local off road trails that I really wanna hit up too. We have no mountains anywhere near here so I will not be spending 1k on a bike...haha sorry but I could not justify that kind of money for the moderate trails we have around here.
    I think 400 tops is what I am willing to spend.
    I would go with the specialized hardrock but no one sells them local and I cant find an online vendor that sells them. (free shipping prefered)
    Also what size bike do i need? Im 5'10" 150 lbs
  11. Jul 13, 2011 at 7:16 AM
    #571
    mattg43
    Texas
    08 Prerunner SR5 DC
    Specialized (along with most big companies) do not allow online sales, to protect dealers.
    I assume WF = Wichita Falls? Closest Spec dealer is up in Lawton.
    Sizing - If you have a long torso and short legs, something with a 23.5-24" TT should fit. If you are shorter torso/longer legs, a 23-23.5" top tube should fit. Generally, a Med-Large, depending on the brand.
    For the bikes - Check out Performance Bike and Nashbar.com . Both have regular sale coupons, for 10-25% off. Last year I got a guy at work into mtb, and he picked up this one - for about $325 shipped. The end of year clearances are going to start around September, so you may want to hold out for about 2 months.
  12. Jul 13, 2011 at 7:54 AM
    #572
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    yea, wichita falls. Lawton is about a 40 min drive so not too bad if I could get a good deal. the sizes i see online are like 14" through 21"
    im really liking the looks and specs of the GT 1.0 with the disk brakes.
  13. Jul 13, 2011 at 10:11 AM
    #573
    mattg43
    Texas
    08 Prerunner SR5 DC
    The sizing you see relates to the seat tube length, and is just a reference. It is less important now with differnt top tube shapes.
    The GT is probably a good bike, but this one looks like a better bike:
    http://www.performancebike.com/bikes/Product_10052_10551_1095570_-1_20000__400308
  14. Jul 13, 2011 at 10:25 AM
    #574
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    i went and rode the Haro flightline 2 at lunch. i didnt really care for it. the brakes squalled really bad, the front shocks seemed soft and would give pretty easily. I like the Giant better than the haro so far.
    And I didnt really care for the guy that helped me with the haro either, I think i knew more about their lineup than he did and I just started looking at them 2 days ago!
    that Raptor looks pretty nice.
  15. Jul 13, 2011 at 10:34 AM
    #575
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
    ^^^^ that looks like a pretty good bike with decent components for the price. If you can ride it before you buy it, it will definitely help you decide. I rode four different bikes before I decided on a cannondale trail 5. I rode a specialized rockhopper, nice and light. A giant, not sure of the name, didn't like the bars, a haro flighline, and the cannondale. The big selling point on the cannondale? the lockout mechanism on the front fork. I have already added a new rockshox front fork, new grips, new seat new bigger 180mm rotor in the front. It's all coming down to what you want and like. Good luck with that.
  16. Jul 13, 2011 at 1:41 PM
    #576
    113tac
    Stephen
    Northern Virginia
    alright let me know...i still want to think about it though since i would still need to get shoes too
  17. Jul 14, 2011 at 5:28 PM
    #577
    tacos
    tacos Well-Known Member
    Andrew
    NKY
    05 A/C Off Road 4x4
    BHLM,5100's set 2.5,Toytec 2" aal,FJ TRD wheels,AFE pro-dry, Duratracs
    No pics yet just need some help. I've been looking into getting into biking for a while now and have been searching craigslist for a decent bike. I just found a 09 Gary Fisher Wahoo (non disc brake) and was wondering your guys thoughts on the bike. I can get it for $300 or less hopefully, also the frame is a 19 and was wondering if it was too big for me or not. ( I'm 5'9") Looking at this thread has made me pull the trigger on multiple bikes but I'm trying hard to not waste my money and buy something that's going to be worthy.
  18. Jul 14, 2011 at 6:35 PM
    #578
    113tac
    Stephen
    Northern Virginia
    hey tacos, i think a 19" would be too big for you. im rockin a 2011 wahoo 19" and im about 6ft tall.
    what do you guys think of this?
    data by S.Mshots, on Flickr
  19. Jul 14, 2011 at 7:52 PM
    #579
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    I think your derailer has seen better days :eek:
  20. Jul 14, 2011 at 10:49 PM
    #580
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    thats why i dont spend a lot of money on derailers...i bust 2 each season (DH)
