Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. Jul 14, 2011 at 11:04 PM
    #581
    WizzyTRDTXPRO
    WizzyTRDTXPRO Well-Known Member
    William
    Nebraska
    TRD TX PRO 4x4
    I'm glad I haven't had that same issue with my Wahoo yet. I agree with you about frame size I'm 6'0 also and the 19" frame is perfect for me.
  2. Jul 15, 2011 at 11:48 AM
    #582
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    hopefully I will be getting this tomorrow. I searched and searched and found this used specialized hardrock disk pro
  3. Jul 15, 2011 at 4:14 PM
    #583
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    definitely dude...i talked to some guys over at mtbr and they think it might just be the hanger...i can only hope
    dang man that suckss haha. what do you usually go with then?
    you shouldnt have a problem with it...i think i bent it when i fell the other day...and that is also why you dont lay your bike down on that side
    :thumbsup:looks good dude as long as its the right size for you
  4. Jul 17, 2011 at 8:14 AM
    #584
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Cheaper ones seem to require less work to keep running.
  5. Jul 17, 2011 at 8:09 PM
    #585
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I ended up getting it! paid 300 bucks for it, specialized hardrock disk pro.
    I took it out for a ride tonight and I love it! now im ready to hit the trails! i just need to do a quick tune and i should be good to go.
  6. Jul 17, 2011 at 8:11 PM
    #586
    113tac
    Stephen
    Northern Virginia
    sick man! hope you ride the shit out of it haha
  7. Jul 18, 2011 at 6:19 AM
    #587
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I plan on it!
  8. Jul 18, 2011 at 6:50 AM
    #588
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Nice find, enjoy!
  9. Jul 18, 2011 at 10:55 AM
    #589
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I need to adjust the front deraullier (spelling?) how do you pronounce that word anyways?! haha
    when im on the highest gear on the front crank (3rd gear?) the deraullier is slightly hitting the chain making an annoying clicking noise. Ill get some better pics tonight
  10. Jul 18, 2011 at 11:09 AM
    #590
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Does it look like it is not going out far enough? Where the chain is rubbing on the outer side of the derailleur cage? The chainring up front should basically be centered in the derailleur cage if you only have 3 clicks on the left hand shifter. That way the chainline can swing either way a bit while going thru gears out back and not rub on the der cage much if any. If there is no adj on the shifter itself then you have to pull cable tighter by the derailleur. If there is then turn the adj on the shifter all the way back in(slack) then undo the bolt holding the cable to the derailleur and pull it tighter then use adj on shifter to dial it in. Do this with chain on smallest chainring up front to have slack in cable. The rear derailleur is similiarly adjustable but you have adjuster on right hand shifter as well as an adjuster on the rear derailleur. Use the ones on the shifters to microadjust and pull cable for front adjustment or use the adjuster on the rear derailleur for the bigger adjustments. May have to pull cable on that one if cable is stretched enough that the other 2 aren't helping.
  11. Jul 18, 2011 at 12:29 PM
    #591
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    awesome, thanks for the help! your first two sentences are spot on!
    on another question, I flipped the bike over upside down and the two cables (gear cables) are actually wrapped around each other two times, shouldnt they just be side by side and not touching?
    should I just losen the front der from the frame and unwrap them or just remove the cable from the der, unwrap, and put it all back (adjusting the tension while I do all this)?
  12. Jul 18, 2011 at 5:04 PM
    #592
    113tac
    Stephen
    Northern Virginia
    as far as the cables i think the only way would be to take the cables off and un twist them.
    for the derailleur i think you should probably adjust the high screw. there are two screw on the FD one that says h and one that says L. the h will change the position of the FD. if you take it to an LBS they should adjust that for free if you dont want to. i know they do that kind of stuff for free here.
  13. Jul 19, 2011 at 6:51 AM
    #593
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I adjusted the screw that is on the shifter and it worked. thanks t@co.
    im probably gonna get a new rear cassett and rear der and ill just have my shop untwist the cable at the same time.
  14. Jul 19, 2011 at 10:04 AM
    #594
    mattg43
    Texas
    08 Prerunner SR5 DC
    Not a bad idea, but keep in mind - if the cassette is bad, there is a good chance, even a probability, that the chain rings also need replaced. If the chain is worn out to the point of causing major wear on the cassette, the problem will be on the chainrings as well.
    Also, replace your chain at the same time.
  15. Jul 19, 2011 at 10:15 AM
    #595
    TRD Daddy
    TRD Daddy Well-Known Member
    Hayden , Alabama
    05 TRD Prerunner
    5100's front & rear, Fabtec AAL ,HID headlights and foglights, Painted lower valence, Painted engine cover, Undercover bed cover, MagnaFlow exhaust, Tinted windows & 3rd brake light, K&N filter, Bed lights, Debadged, LED interior lights, Anytime fog light mod,
  16. Jul 19, 2011 at 10:18 AM
    #596
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
  17. Jul 19, 2011 at 2:26 PM
    #597
    113tac
    Stephen
    Northern Virginia
    i just got some time clipless pedals. they are really nice and ive only heard good things about them. i just tried clipping in and out and they are VERY easy to get in and out of. ill be testing them out on saturday hopefully. i would test them now but i was out riding and am tired as shit!
    DSC_0552 by S.Mshots, on Flickr
    and here is an updated one of the bike
    DSC_0555 by S.Mshots, on Flickr
  18. Jul 19, 2011 at 3:05 PM
    #598
    mattg43
    Texas
    08 Prerunner SR5 DC
    I guess I will post this up here - I have some Crank Bros Candy C pedals and Answer shoes for sale. Both brand new, gray pedals and size 45 shoes.
    Lemme know if anyone is interested
  19. Jul 19, 2011 at 5:51 PM
    #599
    flyingface
    flyingface Well-Known Member
    Zach
    Auburn, AL
    2013 MGM DCLB TRD Sport 4x4
    Soon....
    Farting around this afternoon, nice to be able to ride in the backyard.
  20. Jul 20, 2011 at 6:02 AM
    #600
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    yea I forgot to mention I would get a new chain at the same time. what are the chain rings?
