Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. Aug 15, 2011 at 12:02 PM
    #721
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  2. Aug 15, 2011 at 12:13 PM
    #722
    GerhartCss
    GerhartCss Well-Known Member
    Harrisburg, PA
    08 TRD Sport
    Pioneer AVIC-X710BT w/ PAC SWI-PS, Leaf Spring TSB
  3. Aug 15, 2011 at 1:26 PM
    #723
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Nice! I went a bit opposite of you, and got my wife a 2011 Safire comp, basically the womens stumpy FSR. It comes in a solid 4lbs lighter than my Pitch (which will gain about 6-8oz when my new Fox 36 shows up :D), and gives her the FS, which she has become accustomed to.
    How much does the 29er weigh, and if you dont mind, about what did you pay (knowing you probably got a discount for buying 2 bikes, etc). I am wondering if that is the route to take, or building her a lighter bike with 26" tires is still the best option.
    Also, how tall is your Fiance?
  4. Aug 15, 2011 at 2:15 PM
    #724
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  5. Aug 15, 2011 at 3:41 PM
    #725
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
  6. Aug 15, 2011 at 4:06 PM
    #726
    LBCdan
    LBCdan TACO --> TUNDRA
    Dan
    Long Beach , CA
    2018 Tundra CM 4x4
    Toytec Coilovers, TotalChaos UCA, Icon w/ Resi, Toytec Lift Shackle, Methods w/ 285/75/18 Tires.
  7. Aug 15, 2011 at 7:56 PM
    #727
    forgotten1
    forgotten1 Well-Known Member
    Adam
    Chandler, AZ
    06 DCSB TRD Sport 4x4
    Bilstein 5100 set at 0, OME 885 coils, 1/2" Top Plate Spacer, Light Racing Upper Control Arms, Alcan AAL, 17" Moto Metal 951 ALL BLACK, 285/70/17 BFG A/T, Depo Black Housing Headlamps, Onex 4300K HID/3000K Fogs, FLM, Toyota Optional Skid Plate, Avid Offroad Sliders, K&N Drop In Filter, Centric Posi-Quiet Front Brake Pads, USA-Spec DF-Toy, Sirius Sportster 4
    Funny you mention the Pitch, I was trying to buy a near new 2010 off of Craigslist but the seller was taking his sweet time to reply. We did end up getting a better deal on both bikes since we bought them together, plus this shop offers free unlimited maintenance for life. This is my fiance first "real" bike, so it should be a good starting point for her and hopefully we won't need to upgrade anytime soon. The frame is a men's Small and she is 5'5", fits her perfectly. Weighs about 30lbs. She tried out the woman's specific Myka, but she preferred the feel of the 29er. They discounted her bike to $520 and also they swapped out the handlebars for some more comfortable riser bars, changed the grips from white to black and also changed the seat from white to black at no charge. She was worried about them getting too dirty lol.
  8. Aug 15, 2011 at 8:12 PM
    #728
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    One of our two off-road tandems
    This is our Ventana ECDM, Fox 40 Kashima fork, Fox DHX5.0 rear, DT hubs, SRAM drivetrain and Avid brakes.
    Photo is taken during a tandem event at Dupont Forrest.
    PK
  9. Aug 15, 2011 at 10:10 PM
    #729
    acdronin
    acdronin Well-Known Member
    Ok you knuckleheads, this Mod addiction is getting out of hand. I've been modding up my MTB and figured I'd do a little write up, It's a beast now and quite fast.
    Here it is before I started reading TW
    First up were tires, I went with these UK's which have a harder compound to last longer on the road, but enough of a tread for middlin off-road, the best part is that I can pump these up to 65 PSI so they're damn quick on the road.
    Next was the Aero bars, ya'll might think WTF? On a MTB? I'll admit not everyone does this but fancy carbon fiber ten speeds are for pussies and I would snap one of those in half. Most of what I do is for endurance and time, I'm not some 135lb euro-trash spandex wearin "team colors" shrimp, my body catches wind like a fucking sail. I went with Profile Designs which has a lot of ways to adjust it, you can rotate the whole deal higher or lower and the arm pads are spring loaded that stay up when not in use, the pads can also be adjusted higher relative to the handle bars, forwards or backwards AND they can be swiveled. Also the bars themselves can be moved forwards or backwards. It took awhile for my bike guy to track down the right handlebars for this but it was worth it.
    Cat-Eye 8 function computer, it does average speed, top speed, distance time elapsed, two trip logs AND when you come to a stop, the timer stops so it only records time when you are in motion. It has a magnet dealie that is in the spokes with a reader on the forks.
    Lights, taking a cue from you nuts, I can never have enough light. I didn't want to shell out the bread for the top end lights so I went with a 7 LED Cat's Eye up top and I modded my bright little Husky headlamp to fit on the neck post. I adjusted the straps and zip tied it in place. The little headlamp bezel swivels for either horizontal or vertical spread of light.
    I should note here that the computer and LED have mounts that are designed for crossbars (like handlebars), This means they can't be mounted on Aero-bars which run front towards back, notice the white pipe where the computer is mounted and also the LED is mounted upside down, that's Sch 40 3/4 PVC pipe milled out to fit in between the Aero bars and it had to be lightly tapped into place which insured it will not slip out.
    Other mods include the hard case Fox deal under the seat post, it has lot's of room and even has a little pocket on the underside of the upper lid that fits my Crackberry perfectly!, I took the old seatpost bag and strapped it under the upper bar. Rounding it out is the air-pump on the lower bar.
    It's a beast, it's fast my normal ride is around thirty miles or so three to four times a week. the tuck with the Aero-bars added 1.25 MPH to my average and allows me to stay in higher gears against the wind. The ab workout with the tuck is insane at full throttle, it feels like sit-ups at 25mph.
    Thanks to Scott and Mike at Alamo Bikes in Alamo CA for the parts and help!
  10. Aug 16, 2011 at 5:56 AM
    #730
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Ive never seen anything like that before! badass!
  11. Aug 16, 2011 at 6:40 AM
    #731
    Black3144
    Black3144 Well-Known Member
    Bellevue, NE
    '07 TRD Off Road
    This is my Mongoose Teocali Super
  12. Aug 16, 2011 at 8:25 AM
    #732
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    That's cool!
  13. Aug 16, 2011 at 9:01 AM
    #733
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    So any of u experienced full susp riders out there got any strong opinions on which system is best? My Motolite has been a superb bike, but in the next year or so I'm gonna be looking for a 5.5 to 6.3" travel carbon frame to upgrade. I think fsr, vpp and dw link are all great, but mostly what I've read and heard from other riders is that the cream at the top seems to be dw. I'm definitely gonna ride before I buy but just wanted opionions. The Mojo SL-R is at the top of my list now. Pivot is getting ready to release a 5.7 carbon frame and of course Santa Cruz Nomad and Blur LT are possibilities.
  14. Aug 16, 2011 at 4:43 PM
    #734
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    2011 Specialized Camber Elite that replaced my 1994 Specialized A1 Comp.
  15. Aug 16, 2011 at 4:56 PM
    #735
    mickyd9990
    mickyd9990 Well-Known Member
    marc
    ri
    07 tacoma off road
    ok tacoma world its time to buy a new bike hahaha.. ive been beating a gt avalanche 3.0 for 4 years now.. its a med frame and im 6 foot 2 so i need something that fits me...
    what would be a decent bike in the 700 +/- range.. i think i want to stick on a hardtail and i think i would like a 29er.. but really want something that lasts.. i ride mostly medium single track trails and state parks fire roads.. nothing to serious but i would like to start hitting new hampshire ski mountains up during the summer..
    a couple i had spotted online were the wahoo, rockhopper, raleigh talus and the like.. anyone have good things to say about these bikes..
    is there a lesser known bike out there with better components?? im going shopping tomorrow but my local shops only carry big name bikes..
    thank you!
  16. Aug 16, 2011 at 7:34 PM
    #736
    mickyd9990
    marc
    ri
    07 tacoma off road
    Just found a 2010 rockhopper 29 expert disc for 800 bucks.. seems like a nice light used bike.. but it is a 17 in frame.. im six foot two.. is this too small?? The guy selling is six foot and says it fits home fine.. but I've been told I need a 19 in frame at least.. what do you guys think??
  17. Aug 16, 2011 at 8:20 PM
    #737
    WizzyTRDTXPRO
    WizzyTRDTXPRO Well-Known Member
    William
    Nebraska
    TRD TX PRO 4x4
    I'm 6'0, I have a 19" Trek Gary Fisher Collection Wahoo so I think you being 6'2 you'll atleast need a 19. I know I got my Wahoo for a little over $700.
  18. Aug 16, 2011 at 9:56 PM
    #738
    113tac
    Stephen
    Northern Virginia
    x2 on a 19" frame. im 6' also and ride a 19. Check out the 2012 Wahoo i know it went to mechanical brakes for 2012 but thats probably a good thing since the hydraulic brakes on the 11 are shitty. I think you could find a 2011 Trek Marlin for under 700 used since i think new they went for around 700. Idk what the specs are for the rockhopper but i feel like 800 might be a little high.
    check out pinkbike.com they always have a ton of bikes and usually arent priced too high so it will probably be easy to find what your looking for
  19. Aug 17, 2011 at 9:42 AM
    #739
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    check Clist too. I got my lightly used 07 specialized hardrock pro disk for 300.
    Im 5' 11" and its a 19" frame.
    I rode last night for a few mins and I went to stand up to sprint and one of the reflectors on a pedel exploded off! haha I turned around to see what fell off my bike thinking it was gonna be my new rear deraillur...thank god it was just a shitty reflector :laugh:
  20. Aug 17, 2011 at 6:06 PM
    #740
    mickyd9990
    marc
    ri
    07 tacoma off road
    ok so ive checked craigslist and pink bike with nothing really too good..
    so i shopped around a couple shops today..
    and really only found 2 ok deals.. 1 being a kona mahuna for 739 or a specialized hard rock sport 29er for 700 bucks.. what do you guys think??
    im thinking about waiting till winter and trying to get a better deal.. neither shop will budge on there prices..
