Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. May 31, 2016 at 7:29 AM
    #9001
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    What's a holy war about it... if you can climb steep technical trails with flat pedals more power to you. In a 2 to 3 hour ride 24 miles or so...I'm dog tired by then and being clipped in helps me go up hill... I forgot my SPD shoes one time and going up hill with eggbeaters was a bitch and a half. That was a short ride. With flats...it can be done no problem, but long rides and technical up or downhill...clipped for me works. Plus if you are more into weight...you are not using flat pedals anyways...
    But what do you call clipless? It either clipped (spd type pedals that have special hardware that mounts to your shoes) or flat pedals. I hope you are not talking about that old school cage around top of the shoe. No one rides that crap anymore except old timers. If you never had a clipped in pedal.. you really should try it.
    Just 8% grade... that's a pleasant climb. There's area here in SoCal are very steep and much higher grade... clipped in helps me given I'm in granny gear and trying to keep the front of the bike down while climbing.
    ChadsPride likes this.
  2. May 31, 2016 at 7:43 AM
    #9002
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    eggbeaters are clipless pedals. spds...are clipless pedals. they use a different cleat setup, but still both are varieties of clipless.
    i did not invent the terminology nor say that it makes sense.
    old school cage around shoe = toe clips
    modern clipless pedals are called clipless to differentiate themselves from the original toe clips
    pedals without anything mechanically holding your shoe to the pedals = flats/platforms/etc.
    https://en.wikipedia.org/wiki/Bicycle_pedal
  3. May 31, 2016 at 7:51 AM
    #9003
    imom
    CAL
    2014 Regular Cab
    Where do you ride or what state are you in? I know places like Texas it's mostly flat so you can get away with flat pedal for mountain biking. Also if you are a strong rider than it doesn't bother you. I'm not a good climber nor do I have tree trunk for legs. I also ran into a true roadie and his legs were tree trunks...so climbing would be easy for him. Quite a few trails here in SoCal are very steep and climbs for miles before any downhill sections.
  4. May 31, 2016 at 8:04 AM
    #9004
    drwx
    M'boro, TN
    and....holy war.
  5. May 31, 2016 at 9:15 AM
    #9005
    Square
    Square Well-Known Member
    Brian
    Mission Viejo, CA
    '14 DCSB SR5 4WD MGM
    This month I've done 30k feet of elevation gain almost entirely on trails, I use only flats. I use Spank Spike pedals with 5.10 Freerider shoes. I've done up to 40 mile rides on these flats and have had zero issues climbing with them. Would clips be more efficient? Probably. But I love bombing down hills just as much as I love getting to the top of those hills and there is no way in hell I'm clipping into a pedal when going down some of these trails. It's all about personal preference.
    drwx, ChadsPride and JerryTaco like this.
  6. May 31, 2016 at 10:23 AM
    #9006
    drwx
    M'boro, TN
    in total agreement.
    i used clipless briefly on my mountain bike a few years ago. i was determined to use them since everyone said it was the next step rider advancement. so i bought some spd520s and shoes and learned to use them. i rode them for about 6 months with no issues. i wasn't any faster than before, but lost the ability to dab in rock gardens. i became overconfident and washed out my front wheel trying to go too fast into a turn. i stayed connected to the pedals and cracked 3 ribs when i hit the ground. i removed those pedals and went back to flats. now i only use clipless on my roadbike. i actually use the spd520 mountain bike pedals and shoes on the road bike. it's much easier to walk around in mountain bike clipless shoes than road bike ones. i use azonic switchback pedals and 5.10vxi freerider shoes. if i ever wanted to switch back to clipless on the mountain bike, i could do it without spending a dime and would likely be way better on them now than i used to be....................but i never want to shy away from a technical section of trail out of fear of not being able to get my foot out in time.
    tl;dr.......use whatever pedals you want to use, but don't waste your breath trying to convince other people to switch to whatever you are using.
  7. May 31, 2016 at 10:30 AM
    #9007
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It's too sketchy to pull off can-cans, superman seat grabs and tail whips clipped in.............
    ChadsPride and Square like this.
  8. May 31, 2016 at 2:25 PM
    #9008
    imom
    CAL
    2014 Regular Cab
    Think how helpful it'll be to do 720 no hand flips stretched out being clipped in.
    drwx and square... more power to you...I find it more efficient and less energy to be clipped in. Far as crashing...I've crashed many times clipped in...I like my egg beaters... they are easy to clip in and out...only time I was stuck to the bike was when the handlebar turned 90 degrees in an instant down a fast fire road. I hit some sort of sand trap and went head first into the sand/dirt. Other times I crash, I'm just clip out and walk over the bars... it's easy engagement and dis engagement with eggbeaters. I ride with bmx style spd shoes from sixsixone. they are flat bottom and recessed spd.
  9. May 31, 2016 at 3:03 PM
    #9009
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    Being clipped in is the only way to ride when you are focused on long miles with a mtn bike. Can't have a fast smooth
    spin with plat form pedals. If you are taking lifts or rides to the top of the mountain and racing down then you can get
    away with not being clipped in just for fun. It's all about personal preference.
  10. Jun 1, 2016 at 4:53 AM
    #9010
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I used to run only flats, hated toe clips, but did eventually switch to clipless and cannot go back. I thought I could, and I started with flats on my fat bike. Went for one ride, and my feet would bounce off the pedals on fast, rough stuff, roots, basically hitting any kind of buimp at speed would shift my feet on the pedals. Probably not using the right technique, and with better pedals and the right shoes it might be different. But I run XT Trail pedals on all my bikes.
  11. Jun 1, 2016 at 6:41 PM
    #9011
    foxhead
    foxhead Well-Known Member
    Andrew
    Colorado Springs, CO
    2016 DC Tundra
    Picked this thing up a few weeks ago. By far the best bike i have ever ridden and completely worth the money. Also have new pedals for it lol :thumbsup:
  12. Jun 1, 2016 at 6:48 PM
    #9012
    ChadsPride
    Sponsored by TacomaWorld.com
    Thats a sharp looking bike man!!!
  13. Jun 2, 2016 at 4:44 AM
    #9013
    Irongrave
    Irongrave Well-Known Member
    Drew
    Knoxville TN
    1998 T4R Limited
    The key is good shoes and good pedals. I run both depending on what I feel like on my mountain bike. My gravel grinder is clipless only so my feet stay in place
  14. Jun 2, 2016 at 5:31 AM
    #9014
    Irongrave
    Drew
    Knoxville TN
    1998 T4R Limited
    20160514_103315.jpg My budget parts bin Dawes Haymaker 1x9. I really need to replace the boat anchor pogo stick suntour fork on it. But other then that it's a great riding bike and I have less then 400 into it total.
  15. Jun 2, 2016 at 5:35 AM
    #9015
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    ive been eying up a entry level rockshox fork for my old bike. they aren't too expensive really. I had a suntour on another bike I had and yea it was pretty rough haha. who knows, the rockshox may be just as bad.
  16. Jun 2, 2016 at 6:01 AM
    #9016
    zth25
    zth25 Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    Anyone have experience with trek card financing?
  17. Jun 2, 2016 at 6:13 AM
    #9017
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Yes, I have done 3 or 4 bikes through their 12 month no interest deal. As long as you get it paid off in the 12 months, it is a good deal. I think Specialized has their S-Card as well and I would bet the terms are similar.
    I don't think they offer it anymore, but I did the Trek Care Plus on my carbon Fuel -- I never buy warranties but they gave me 15% off the bike if I bought the warranty. Basically they will replace anything you break while riding it for 3 years. I got debris in the deraiilleur, folded it up into the spokes, and they replaced the wheel, derailleur and hanger, shift cable and chain for no charge. So, I am more than even on that deal.
  18. Jun 2, 2016 at 6:19 AM
    #9018
    jpneely
    Charleston, SC
    that sounds like a hell of a deal actually. I always see those credit accounts as a scam outright, but maybe I should start looking into them a little more.
  19. Jun 2, 2016 at 6:24 AM
    #9019
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    You have to pay 5% of the balance monthly, don't pay late or miss a payment, and make sure it is paid off in the 12 months, or they will screw you (well, you know the terms going in, so that would basically be screwing yourself). They will apply the 20-something percent interest from day 1.
    If you need pedals or other accessories, get them to add that to the bike and the price at the time of original purpose. Don't use the card for anything else, the interest rate sucks.
    Follow the terms and it is a great deal if you don't have the cash all at once.
  20. Jun 2, 2016 at 6:27 AM
    #9020
    jpneely
    Charleston, SC
    duly noted!
