Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. Jul 26, 2018 at 5:14 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Ripping through a tight series of turns, Hand slipped off the bar here, sent it right off the trail, bike hit the rock and right tree, and I flew through the trees. I'm surprised I walked away from that one. Im like 3/3 this season, all my bad crashes have been sending it too hard through turns. Jump after jump after jump, all fine so far, the turns tho
    JJ TACO likes this.
  2. Jul 26, 2018 at 5:55 PM
    Dadypig
    Dadypig Aka daddy pig
    Jaime
    East bay Kali
    2001 silver extended cab sr5
    Stock for now
    Time to play the lottery IDtrucks!
    JuanitoBonito likes this.
  3. Aug 2, 2018 at 9:00 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I fuckin lost lol
    Wanted to go ride tomorrow, figured out the true extent of that crash...cracked the tube about a third of the way around, only figured it out because I tipped the bike over and fluid came oozing out!
    Compared to my dirt bikes I used to have...this thing isn’t very tough lol! One medium wipe out and I’m out 700 bucks for new forks. B57EE81F-6243-4E39-AE24-77F0BF1402AB.jpg
  4. Aug 2, 2018 at 9:15 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Oh man that sucks..... on the fork?
  5. Aug 2, 2018 at 9:28 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Hello everyone, I have a Mongoose Blackcomb. I use it to commute to work every day and do light trail riding. I've only added a seat post rack and EBC green disc brake pads which are 100% better than the previous pads. I also removed the "dork disc", and added security skewers and seat post mount. The rest of the bike works for what it is, but the front fork is useless. I need help figuring out what fork to replace it with. I don't know anything about the headset sizing, pitch, all that stuff. I'm a noob. The only info I could find on the fork was on a Chinese website.
    I was thinking of getting a Suntour fork but not sure what to get. My budget is <$200.
    Before all of you jump on me for having a shitty bike, I wouldn't be upset if this bike were stolen. It sits outside all day while I'm at work, I do use a cable lock but they're easily defeated. I've already had this same bike model stolen from me in college. I guess it looks better than it really is.. who knows. I've been the victim of all sorts of theft.. so I don't want to ride around a $2k bike in the city.
    Here's the "information" about my current fork. What replacement options do I have?
  6. Aug 2, 2018 at 9:44 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Here's some pictures of it. I've been riding it 2 miles round trip to work almost every day since Christmas. Snow, ice, torrential downpours, 10 degrees, 100 degrees. I've only washed it once but I've made sure to clean and lube the chain often, and adjust the brakes and derailleur as necessary. I've sprayed down rust prone areas with lube as well as areas that get squeaky.
  7. Aug 3, 2018 at 5:13 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I don't think that fork info is accurate, that info is for a 20-24" wheel and you have 26". Oh, and you need to charge your phone.
    Plenty of options on Amazon, Suntour XCM is probably the cheapest. There's a Manitou as well: https://www.amazon.com/Manitou-Moun...1533298023&sr=8-3&keywords=mountain+bike+fork
    If you haven't done it before, I would recommend taking it to a local shop to have it installed. The tube has to be cut to the right length and relatively straight, star nut installed, and adjusted properly.
    ThunderOne[QUOTED] likes this.
  8. Aug 3, 2018 at 7:15 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Does it matter which fork I get? Or do I just need to focus on getting a 26" fork? I'm not sure if I have a "tapered" headset or not. I think I'm using the right terms. :anonymous:
  9. Aug 3, 2018 at 7:37 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Ya, the outer fork tube. It’s still an Xc bike so no triple clamp, so I can’t just replace one fork can I?
    Gonna call the place I bought it from and see what they recommend/can do. Probably nothing but it’s worth a try
  10. Aug 3, 2018 at 7:50 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    That fork is 100% McFucked. Should be able to just replace the lower fork and keep the steerer/stanchion assembly/innards.
    Only concern I would have is that if it cracked the outside that bad, the stanchion inside got schwacked as well.
    honda50r and JuanitoBonito like this.
  11. Aug 3, 2018 at 8:19 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    I love the color schemes on those forks
    I second this notion. All very good advice
    Holy shit I've never seen that happen to a mtb fork. Also I laughed out loud about being mcfuckedup
    Gunshot-6A[QUOTED] likes this.
  12. Aug 3, 2018 at 9:02 AM
    Gunshot-6A
    Conner
    Everett, WA
    I've seen the lower fork snap both stanchions clean off once, but never rupture like that. Had to have hit a sharp edge rock like REALLY hard to do that.
  13. Aug 3, 2018 at 9:54 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    From the pics, your fork is a 1 1/8" straight, not tapered. Your wheels appear to be 26", so get a 26" fork. What is hard to tell is whether you might need a new headset (the bearings and races that the steerer turns inside of). A bike shop would help you figure that out. Hard to tell if that is a 100mm or 80mm travel fork, but I would just go with 100mm. So, 26", 1 1/8" steerer, 100mm travel. Or just go to your LBS and tell them your fork is terrible. They might be able to tune that one up, and if not, they can get you everything you need. At least it's not McFucked like that other guy's.
    honda50r likes this.
  14. Aug 3, 2018 at 10:13 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Awesome thank you! What other guy's? Lol
  15. Aug 3, 2018 at 10:16 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    You're welcome, good luck. Further up this thread, a guy posted a pic of his completely busted fork.
  16. Aug 3, 2018 at 10:43 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Oh damn! The $700 one?! That sucks!
  17. Aug 3, 2018 at 3:24 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Would this work? It says it for disc, I've seen some odd looking mounts on others that I know for sure will not work, but I think my current calipers will bolt up to this one.
    https://www.ebay.com/itm/SR-Suntour-XCM-Suspension-Fork-26-1-1-8-255mm-threadless-steer-100mm-Black/401559604481?epid=1038439463&hash=item5d7ed14d01:g:il4AAOSwtoVbNVPb&_sop=15&_sacat=0&_nkw=sr+xcm+fork+26&_from=R40&rt=nc&LH_TitleDesc=0
    I probably won't get this one but idk, maybe something a bit better. But want to make sure I'm getting the proper specs correct. The only thing I'm not sure of is threaded or not threaded. I assume mine is threadless since I dont see anywhere it would "thread" on.
    Maybe these? It says they're coil but they look like an air fork. Description says they can be set up either way??
    https://www.ebay.com/itm/NEW-SR-Sun...8&_sacat=0&_nkw=1+1/8+26+fork&_from=R40&rt=nc
  18. Aug 3, 2018 at 4:55 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  19. Aug 3, 2018 at 5:03 PM
    Dadypig
    Jaime
    East bay Kali
    Stock for now
    Keep your eyes open on CL,might find a nice Fox or rockshox for that amount or cheaper.
  20. Aug 3, 2018 at 8:00 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I guess that's true. I'll take a look now. Would any of the links be ok if CL is a bust?
