Show off your Mountain Bike!!!
Discussion in 'Sports, Hobbies & Interests' started by godofspeed, Mar 3, 2010.
  1. Dec 12, 2020 at 3:10 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    When I was leaving Trail Head, I asked one of the guys to put the bike on my rack for me. That thing is heavy! :rofl:
    The Heckler is a great bike w/o the motor! As for comparison, the Specialized is only a little better spec'd motor wise that you could argue they're the same. Fantastic bike. Congrats!
    gargamel05[QUOTED] likes this.
  2. Dec 28, 2020 at 8:00 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Morgan Territory
  3. Jan 2, 2021 at 8:20 AM
    along16
    along16 Well-Known Member
    2020 DCOR
    DA22D2D4-BC44-492D-975A-1EC3D61263B0.jpg YT Jeffsy 2018
  4. Jan 6, 2021 at 12:19 PM
    LaXCarp
    LaXCarp Well-Known Member
    '09 DCSB V6 4x4 base
    Knolly Warden C
    paleh0rse, 99kx250, Coolerman and 5 others like this.
  5. Jan 9, 2021 at 11:23 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Made the mistake of renting a Turbo Levo to see what they were all about. I ended up selling my Surly and gave a deposit on one at my LBS. I ordered the Comp in Spruce green. I have a pile of upgrades just sitting waiting
    Coolerman and ian408[QUOTED] like this.
  6. Jan 9, 2021 at 11:33 AM
    Dirtjunkie
    Dirtjunkie Well-Known Member
    Northern Colorado.
    2006-Taco-Sport-TRD-Quad Cab-Short Bed, 4x4 No mods to speak of.
    Just curious, to the guys buying ebikes, how old are you? I’m 59 and just bought a new bike, did I think about an ebike? For a second, I’m just not there yet. I like the exercise this sport demands.
    str8edgMTBMXer, TroutBum and Pablo8 like this.
  7. Jan 9, 2021 at 11:35 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    I’m 28 and if I didn’t have a million hobbies I’d probably have 3 mountain bikes: one hardtail, one trail bike, and one ebike
  8. Jan 9, 2021 at 11:38 AM
    svendough
    svendough Well-Known Member
    Colorado
    2020 Cement DCSB OR
    Skinny rubber, Bilstein lift, iKamper
    Yeti SB130, only upgraded the rear cassette to an X01 and changed out the grips—oh and switched from flats to clips for more power on technical climbs. I have a deep BMX background, so I'll ride either. Love this thing, climbs and descends so well. Photo of the day I got her plus a few pics from some rides in natural habitats.
    Attachments are from:
    • Nelson Loop trail, Lyons, CO
    • Ribbon Trail, Grand Junction, CO
    • Kenosha Pass, Park County, CO
    • Devils Backbone, Loveland, CO
  9. Jan 9, 2021 at 11:45 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Youngan
    113tac[QUOTED] likes this.
  10. Jan 9, 2021 at 11:53 AM
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    My wife’s bike13E754BC-3F35-4B8F-95F7-9843AC6654C5.jpgjust installed a dropper post on her bike it was hard to find one that fits that frame38D631C7-989B-47DF-8E7E-7060ACFAE940.jpgmine
  11. Jan 9, 2021 at 12:05 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I think if you rode one, you'd understand an e-bike can give you the same and (maybe better) workout because of the way you ride it.
    It's not a replacement. It's just different.
    Bentrodder and Pablo8 like this.
  12. Jan 9, 2021 at 12:40 PM
    Itchyfeet
    My right knee has been a piece of crap since a sports mishap in my teens. I don't see myself ever going back to a regular bike unless I was buying a downhill bike. I have found myself with the rental staying out longer. I felt like I got a good workout vs. riding my normal bike where I felt beat up.
  13. Jan 17, 2021 at 6:12 PM
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
    I don't buy new bikes, I just continue to upgrade my old bikes.
  14. Jan 17, 2021 at 11:29 PM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    So many good deals on used bikes. So many peeps get bikes and don’t really ride them end up selling them.
  15. Jan 17, 2021 at 11:39 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    my lil get a long
    need front forks................... not sure what to get
    supple spring type much like a Moto bike ..........................any suggestions
    E-Paz 732NJ likes this.
  16. Jan 18, 2021 at 4:01 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Good, top end bikes? Where? Not here at all, like hardly if ever. And if there is a used good bike, just a couple hundred bucks less than new.
  17. Jan 18, 2021 at 5:43 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Check on Pinkbike. I tend to keep stuff for a couple of years and then get the itch for something new (I'm pretty settled now, though). What I see on Pinkbike is typically quite a bit less than new.
  18. Jan 18, 2021 at 5:51 AM
    backcountryj
    Jonathan
    GA
    There’s still some deals to be had out there. Haven’t seen anything I’d call a ‘good deal’ in a while though.
    Pablo8[QUOTED] likes this.
  19. Jan 18, 2021 at 5:56 AM
    LVYOTA
    LVYOTA Well-Known Member
    2014 TRD Sport MT
    New Trek Roscoe. Love it so far!
  20. Jan 18, 2021 at 8:41 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Anyone know how much I can expect to pay to have my front fork rebuilt? The bike is a '09 or '10 Giant Reign and the front fork recently just depresses all the way down without much effort. It's an air fork, i bought a pump specifically for it just thinking some air had escaped. It pumps back up and works for like 5 seconds then just goes back to being broken.
