Show Off Your PRINSU Rack
Discussion in 'PrInSu Design Studio' started by zscott, Jan 26, 2016.
  1. Dec 20, 2017 at 6:27 AM
    #101
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I have a double cabrac so it was just straight bolt on. If you are referring to a topper rack then, I BELIEVE the feet are adjustable, but don't quote me on this.
    The install instructions are on the prinsu website, peruse through and it will probably answer that question for you.
    BraskaTaco[QUOTED] likes this.
  2. Dec 20, 2017 at 6:32 AM
    #102
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Yep it'll be for my shell. I'll take a peek at those instructions!
  3. Dec 21, 2017 at 8:13 AM
    #103
    RucksackRev
    RucksackRev Well-Known Member
    RucksackRev
    Tacoma DCSB Off Road
    Off Road Adventures
    I had a Prinsu rack on order through CBI but cancled the order two months later. I think that Prinsu makes a good product from having installed a few of these.
    While I think it would be a good addition to the truck I'm not sure if it would be ideal for this resto-mod project I have taken on paired with the 2nd gen Tacoma
  4. Dec 27, 2017 at 9:21 AM
    #104
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
  5. Jan 3, 2018 at 4:12 PM
    #105
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Now that's just wrong..... aren't those limited to Hilux only?
  6. Jan 3, 2018 at 4:18 PM
    #106
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Yes, it's wrong.
    I've since traded up to an M240B airsoft copycat. :D
  7. Feb 23, 2018 at 11:01 AM
    #107
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @uurx
    uurx likes this.
  8. Apr 5, 2018 at 3:01 PM
    #108
    Gunshot-6A
    Conner
    Everett, WA
    A little steeper and chunkier than the camera makes it look.
    My poor attempt at #FlexyFriday
    ready6delta likes this.
  9. Apr 5, 2018 at 7:29 PM
    #109
    RebelliousOne
    RebelliousOne Well-Known Member
    Cliff
    Frisco
    2017 Tacoma TRD Off-Road 4x4 DCSB, previous 2016 TRD Sport 4x4 DCSB
    Just put it on yesterday....
  10. Apr 13, 2018 at 3:44 PM
    #110
    HackD
    William
    Objective of the next few weeks for me, is to 'tray' my Access Cab rack .. as i do 95% of my driving, at speeds of 50-80mph, i have gotten somewhat OCD with my setup. I am on a continuous quest for sound reduction. I went to considerable time and expense in lining the roof with 9mm sound insulation last fall, developed my own auxiliary wings for the front air dam of the Prinsu (Scrap stainless kicking around in back of garage, FTW..) and now am looking at isolating / enclosing the bars from the underside, or topside with a 3/16" sheet of Thermoform plastic. Kinda expensive at $65.00 CDN for a 4'x4' sheet.. but all in, for a good cause.
    I've been eyeballing a mate's Nissan Pathfinder, early 2000's vintage, with it's more integral roof rack - i'm going to try to 'wrap' the leading edge of the tray off with the front air-dam to smooth out turbulent airflow. I'm also dropping the lightbar as close to the cutout as possible, and going to try to barrier-isolate that with the tray, in addition.
    Anyone done similar?
    Tachord and Manfred like this.
  11. Apr 13, 2018 at 4:08 PM
    #111
    Rames
    Rames Well-Known Member
    James
    Oakland, CA
    OME 3" lift, BAMF sliders, Demello front bumper
  12. Apr 13, 2018 at 7:26 PM
    #112
    RebelliousOne
    Cliff
    Frisco
    Need some wisdom from those that have gone before me....Has anyone on here mounted a Rough Country LED on the Cabrac? My wind deflector is pictured above on #109 with 32 inch cut out....I've used the Rough Country, small brackets on each end with the 1/4 inch bolts, but I'd like to secure it using the larger 3/8th inch bolts that have the built-in multi-positional locks. I've mounted it with those two 3/8th inch bolt threads pointing towards the back so I can tie into them from the crossbar immediately behind the light. I have not seen anything that mounts to the Prinsu crossbars larger then 1/4 inch. Thanks in advance guys.
  13. Apr 13, 2018 at 7:44 PM
    #113
    Dank24
    Dank24 Well-Known Member
    3rd gen OF
    I want to pick one up for my topper :spending:
    Should do a group buy
  14. Apr 16, 2018 at 10:28 PM
    #114
    C-squared'11Tacoma
    C-squared'11Tacoma Well-Known Member
    2011 Black Tacoma TRD TX Pro
    Get ahold of CBI they are the owners of Prinsu now.
  15. Apr 17, 2018 at 6:34 AM
    #115
    ScottyR
    ScottyR Well-Known Member
    Vancouver BC
    2016 DCLB TRD Sport
    It's been made very clear that CBI does not do group buys
  16. Apr 22, 2018 at 5:35 AM
    #116
    Dank24
    3rd gen OF
    I want one, but I cannot justify the cash amount for a rack... ugh
  17. Apr 22, 2018 at 2:24 PM
    #117
    HackD
    William
    Now, where's the fun in that? o_O
    I got a good start to it today. I got the 4x4' sheet reduced to final outside dimensions, and slotted the front for the front wrap-around on the front wing. This is thermoform plastic sheet, so i need to make a couple wood contour forms, to follow the curve of the side pieces down into the windshield. A little heat, and presto, it should be good. I will reduce the center slotted section over the lightbar, so that it sits close to flush with a rubber gasket against the lightbar itself. I had dropped the lightbar itself in height, earlier this week, by an approximate 3/8" with different mount spacers.
    This is meant as a cover, easily removable. I do need to order some more T-Slot nuts to secure it in place, and i need reposition already placed tie down points on the cross-bars themselves, to final mount. Another weekend should do it.
    Another benefit of this, that i just thought of, in trial fitting - this should be ideal to keep snow build up under the roof racks to a minimum.. it packed in pretty densely this past winter, and as temps got mild, turned into a slab of ice.
    It should make the rack appearance be more tidy and "aero", as well as improve upon the audible turbulence issue. It sits recessed by 1/8" inside of the rack sides resting on the cross-bars, so almost flush. Just enough to not be externally visible, standing side on to the truck.
    T-slot covers might well have been the cheaper, more economical solution.. but nothing ventured, nothing gained.
    As is apparent, i also need to do some cleaning, and repainting of the rack surface itself... it's taken a kicking in our salt-slurry winter environment.
    doublethebass and ready6delta like this.
  18. May 18, 2018 at 8:39 AM
    #118
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Still going strong years later. Love the rack.
  19. May 18, 2018 at 1:43 PM
    #119
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    CE03D4FB-3D00-4199-8B5F-A17D6E165DBB.jpg F093D946-CAE8-4987-901A-B2FB5929EA35.jpg 3810AABB-719F-4BA7-92E1-02951DA306DE.jpg 7C2F8FFC-01C4-4F95-846F-930C4342FACC.jpg
    finally picked one up off a local buddy for a great deal.......now to adjust my shell rack to match.
    AZBACKCOUNTRY and BYJOSHCOOK like this.
  20. May 20, 2018 at 12:04 PM
    #120
    Dudeman86
    Dudeman86 Well-Known Member
    Scottsdale, AZ
    2016 Black DCLB OR
    Anyone have an RTT mounted above the cab on a bedrack put one of these racks up to act as an air dam? Looking to reduce some of the drag I have and was wondering if this rack might be helpful.
