Show Off Your Steel Wheels
Discussion in 'Wheels & Tires' started by DustStorm4x4, Dec 30, 2016.
  1. May 4, 2019 at 11:21 AM
    #421
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Ok gents! We have a problem!
    So today I did a brake fluid flush and vacuumed in new Redline synthetic, well while I had the truck on four jack stands I decided to rotate the tires and hit the zerks.
    Then I said to myself, “try out that 255 on your spare rim that’s sitting in the shed!”
    Holy Crap it looks so good!!,
    So I’m now checking prices as I am pretty sure once I have a complete set of spare steelies 8m going pizza cutters!
    I’ll admit though the 2018 OR susp under my truck helps as my front is almost 1.5” taller than it was stock. I also have an OR sway bar under there.
    What you guys think?
    Rear tire is a 265/75/R16 Hankook on a 1sr Gen Trundra rim.
    Front tire is my original spare rim with a 255/85/R16 Cooper ST, 8-ply.
  2. May 4, 2019 at 1:07 PM
    #422
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    I think the steelie looks better but thats just me.
    Greenbean likes this.
  3. May 4, 2019 at 2:50 PM
    #423
    Appalachia Man
    Appalachia Man Well-Known Member
    03 Prerunner X-cab
    2.7L Detroit Truetrac 2" lift OME 880's & Dakar's
    all 4 wet sanded and prepped, primer in the mourn. your truck looks killer in black steel... lugs set dat black off!!!
    Greenbean[QUOTED] likes this.
  4. May 4, 2019 at 3:03 PM
    #424
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    Tundra rims FTW:thumbsup:
  5. May 4, 2019 at 4:12 PM
    #425
    Greenbean
    Zack
    Western NC
    Thanks guys, I think it looks awesome!
    I like em both though.
    I’ll be keeping the Tundra rims and putting 255s on steel spares.
    The lug nuts were just the ones from the Tundra wheels. Toyota aluminum wheels have the cone provision to run your spare.
  6. May 6, 2019 at 4:19 PM
    #426
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    I have a set of 16x7 steel rims that I was told are from a 97 4runner.
    I did a quick search of the number stamped on the outside and didn't see anything conclusive- these should fit my 2016, correct?
    Attached photos for reference
    Any insight is appreciated.
  7. May 7, 2019 at 3:39 AM
    #427
    Appalachia Man
    03 Prerunner X-cab
    think you're gtg. check out @Greenbean post #420 & #426. 1st gen steels have ~4 5/8 backspace. put a straight edge on back of rim, measure down to lug hole. i physical put mine on truck (1st gen), double checked brake & UCA, all good! ordered tires yesterday.
    Greenbean and boynoyce[QUOTED] like this.
  8. May 7, 2019 at 5:34 AM
    #428
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Thank you, will check this later.
  9. May 7, 2019 at 1:18 PM
    #429
    amont
    amont Well-Known Member
    2019 Black TRD Pro 6MT
    rocking some method wheels on ko2s
  10. May 9, 2019 at 6:30 PM
    #430
    Hunterdc1
    Brrrrother
    13 8 lug ltz gasser
    Nice to see an understated Pro and not one that says !!!!!look at me!!!!! That's a damn good looking rig.
    amont[QUOTED] likes this.
  11. May 9, 2019 at 10:21 PM
    #431
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    Dressed up that cheep ass silver with some Hammertone paint and shod the rims with Geolander AT20190420_122502.jpg
  12. May 16, 2019 at 7:31 AM
    #432
    yodatoyota
    yodatoyota Scrub
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    Do steel rims come with different back spacing?
  13. May 16, 2019 at 5:45 PM
    #433
    Appalachia Man
    03 Prerunner X-cab
    yes. my gen 1 (6 lug) offset is positive ET15 (15mm). back of rim to where rim mounts on hub has a back spacing of ~4 5/8. think (?) gen 2 is ET30 (30mm).
    check this site out for your make and model,
    5hanman and yodatoyota[QUOTED] like this.
  14. May 25, 2019 at 4:55 AM
    #434
    Shooter78
    Shooter78 Active Member
    Cody
  15. May 25, 2019 at 5:15 AM
    #435
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    There is a thread with a user who installed 3rd gen 4Runner steelies and they don’t quite clear the front calipers and he needed a spacer on the fronts.
    boynoyce[QUOTED] likes this.
  16. May 25, 2019 at 6:05 AM
    #436
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    Did you look at car-part.com? That's where I got mine. 3 were local, and I had 2 shipped from out of state. I wanted real OEM<, not knockoffs. No clue what quality the knockoffs are, but didn't want to take the chance. If you do go with car-part, make sure to verify what shape the wheels are in, I got a couple that had more rust than I was expecting, still trying to sort that out.
    Appalachia Man likes this.
  17. May 25, 2019 at 10:35 PM
    #437
    BCTRD357
    BCTRD357 Well-Known Member
    Jarrett
    2018 dcsb cement TRD off road
    none yet
  18. Jun 15, 2019 at 11:43 AM
    #438
    xxTacocaTxx
    Best Slope CO
    Powder coated FJ steelies, Cooper Discoverer S/T Maxx 255/80/17, stock TRD OR suspension
    No cutting, no grinding, and no rubbing during my trip to the mall.
  19. Jun 15, 2019 at 11:45 AM
    #439
    Wulf
    Wulf no brain just damage
    rock raisin
    Anyone running 17x9 Procomp or similar steelies?
  20. Jun 17, 2019 at 7:55 PM
    #440
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
