Show Off Your Steel Wheels
Discussion in 'Wheels & Tires' started by DustStorm4x4, Dec 30, 2016.
  1. Apr 18, 2020 at 11:13 AM
    #541
    sewerpickle
    sewerpickle I say FUCK way too fuckin much!
    Erik
    Hesperia
    Stuff to make it more springy and bouncy... but less crashy...
    Social distance
    ToyTech_PNW, MarcM, STOBLES and 10 others like this.
  2. Apr 27, 2020 at 5:32 PM
    #542
    MiamiFLA
    MiamiFLA Active Member
    2020 TRD Off Road
    What is the exact difference between the steel wheels 42601AD030 (indicated for my 2020 Tacoma) and 42601AF010 (indicated for earlier Tacomas/Tundras/Sequoias)? Looking for weight, offset, backspace - whatever reliable number you've got. Either I am terrible at search or this is not published well at all.
    At the dealer, Tacoma spare is cheaper $100 vs $135. Salvage the pricing is reversed $70 vs $40. Used Tundra spare plus some elbow grease comes out a lot cheaper.
    Ultimately, I hope to go to a skinny tire and stay on a 16 inch wheel. Gonna be on stock suspension for a while.
    yub likes this.
  3. Apr 30, 2020 at 8:00 PM
    #543
    nickhalla
    nickhalla Active Member
    Nick
    Edwards, CO
    2014 SR5 Access Cab
    OME 886 w/SPC uppers, Dakar leafs and Nitrocharger shocks. Slee Rock Sliders 285/75/16 Yokohama Geolandar MT's on Toyota steelies
    16" steelies on 285's. Just got the geolandars mounted up.
    trktwo, socal73, sewerpickle and 4 others like this.
  4. Apr 30, 2020 at 9:30 PM
    #544
    Triple P
    Triple P Well-Known Member
    Tech Land, Washington
    2015 TRD OR ACCESS
    J. Garcia CD✌ ADS- Deaver
    Nice truck. ( sorta kinda off topic question). I am wondering if I can put a 285/75/16 on my spare steelie?
  5. Apr 30, 2020 at 9:43 PM
    #545
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Anyone on this thread know where I could pick up a OEM 17” spare steel wheel?
  6. Apr 30, 2020 at 10:20 PM
    #546
    nickhalla
    Nick
    Edwards, CO
    2014 SR5 Access Cab
    Yep you can. I put one of the old 285 Trail Grapplers on my spare and it fit no problem. Only had about 20% tread left though
  7. Apr 30, 2020 at 10:36 PM
    #547
    Triple P
    2015 TRD OR ACCESS
    Thanks. I knew I could squeeze it under the truck, but I wasn't sure if spare rim was for temp or regular use. Newb question:crazy:
  8. May 4, 2020 at 5:54 AM
    #548
    Taco_414
    Taco_414 Member
    Ian
    2020 Tacoma TRD OR
    Looks really good! Do you have a lift? Looking at getting wheels and tires before a new suspension. Do you know if 285/75/16's would this fit stock suspension?
  9. Jun 4, 2020 at 5:31 PM
    #549
    Hgreg
    Hgreg Member
    Does anyone know is the spare steel rims weigh anymore than the stock steelies that come on most trucks? I want to switch to spare steelies only if they weigh the same or less. Many thanks
  10. Jun 4, 2020 at 5:35 PM
    #550
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    FJ Steelies on 285/70/17
  11. Jun 4, 2020 at 10:17 PM
    #551
    dubktrd
    dubktrd Well-Known Member
    Wichita Kansas
    Doesnt matter just do it
    uploadadventure likes this.
  12. Jun 5, 2020 at 12:58 PM
    #552
    Hgreg
    Hgreg Member
    If is it okay/safe to run spare wheels for all 4 wheels all the time? As far as stength and whatnot.
  13. Jun 5, 2020 at 1:12 PM
    #553
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    yes. If your spare happened to be a Forged Alcoa wheel would you have a concern? Its just the one they chose.
    dubktrd and Hgreg like this.
  14. Jun 5, 2020 at 1:22 PM
    #554
    dubktrd
    Wichita Kansas
    Yes , you can . I rather just run oem 1st gen 16inch Tacoma and tundra steelies. To tell the difference spares has a slotted hole by valve stem and regular steelies have all circular holes.
    yub and boynoyce like this.
  15. Jun 5, 2020 at 1:24 PM
    #555
    Hgreg
    Hgreg Member
    good point, thanks!
  16. Jun 5, 2020 at 8:07 PM
    #556
    Hgreg
    Hgreg Member
    anyone notice a major MPG drop switching to the FJ 17" steelies?
  17. Jun 7, 2020 at 9:03 PM
    #557
    Estephe21
    Estephe21 Well-Known Member
    Stephen
    Seattle, WA
    2008 DCLB, 2023 DCLB
    Sadly, not much.
    I did notice a drop. But also coincided with transition to all terrain tires and bigger tires. 16>>17. I am at 16-17 mpgs with lift, roof rack, 265/75/17 AT and canopy.
    Hope that helps!
  18. Jun 8, 2020 at 8:05 PM
    #558
    Hgreg
    Hgreg Member
    Thank you, helps a lot! I just scored some FJ steelies on FB market place, can't wait to get them on my truck
    Estephe21 likes this.
  19. Jun 11, 2020 at 9:31 AM
    #559
    chriscc
    chriscc Member
    17 Tacoma SR 2.7l
    Wanted to contribute as a 5-lug owner (will never again!) I had a hell of a time trying to find some steelies.
    I went with dodge caravan 15x6.5's they're the exact fit and offset maybe 10mm wider? No rubbing, caliper modifying etc. I also got hub-centric spacers as the CB was larger (71.5).
    Cooper AT3 75/235/15's no lift etc. Just stock otherwise.
    JoeWillie, whatstcp and Taco critter like this.
  20. Jun 11, 2020 at 3:18 PM
    #560
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    FJC Steelies
    2nd Gen;
    and now 3rd Gen;
