Show Off Your Steel Wheels
Discussion in 'Wheels & Tires' started by DustStorm4x4, Dec 30, 2016.
  1. Nov 1, 2020 at 8:22 PM
    #641
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Dang. That was quick.
  2. Nov 1, 2020 at 8:38 PM
    #642
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
  3. Nov 3, 2020 at 2:00 PM
    #643
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    [​IMG]IMG_8034[2179] by Mike M, on Flickr
    This is my snow set. FJ steel wheels on Nokian Hakka R3s in 265/70-17.
    TBH, I don't love them as much as I had anticipated. Maybe I just need to clean the truck as glaringly clean wheels on an otherwise gross truck doesn't help. Maybe I should have went back to the stock OR wheels on slightly larger tires, or maybe I'll eventually hunt down a set cheap of Sport alloys in the next few years. They seem to trade cheap as they're less desirable than the 3G OR wheels. Whatever happens 5-6 years when I replace these snows, I'll likely go back to a 16" tire and run the TRD OR wheels.
    The FJ center caps SUCK to get on the truck correctly.
    Thoughts?
  4. Nov 11, 2020 at 8:17 AM
    #644
    barretta
    barretta -
    San Clemente, CA
    '18 White TRD OR 4x4
    I've been wanting to go the steel wheel route for a while and I'm starting to get serious about it.
    I see a lot of people going the FJ steel wheel route and was wondering if 1st gen tundra steel wheels would work. The offset is very similar it's just a 16" vs 17". From what I've read the 16" tacoma stock steel wheel offset is 25, the 17" FJ ones are 15, and the 16" tundra ones are 14 (correct me if I'm wrong on any of that). Is there a caliper/general clearance issue I'm unaware of or is it just that most people prefer the 17"? Or maybe the 1st gen tundra steel wheels are impossible to find? I've seen them online, but out of stock.
  5. Nov 11, 2020 at 8:22 AM
    #645
    skee
    skee Well-Known Member
    North Coast, CA
    2006 Tacoma TRD 4x4 Access Cab
    I compared the specs on the Road Ready 16” steel wheels I bought to the stock TRD OR wheels on my 2006 Tacoma and they appeared to the be same width and offset as stock. They also don’t look like they stick out any more or less than the stock alloys did either.
    I’m sure the 16” tundra wheels are the same.
    xxTacocaTxx and barretta[QUOTED] like this.
  6. Nov 11, 2020 at 8:36 AM
    #646
    barretta
    barretta -
    San Clemente, CA
  7. Nov 11, 2020 at 8:41 AM
    #647
    velomutt
    velomutt Well-Known Member
    2018 Taco DCLB OR INFERNO
    A bunch of Meso Custom stuff.
    1st gen steelies with Cooper At3s. Put ‘em on yesterday.
    skee and barretta like this.
  8. Nov 11, 2020 at 8:45 AM
    #648
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
  9. Nov 11, 2020 at 8:50 AM
    #649
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    85?
  10. Nov 11, 2020 at 8:56 AM
    #650
    excorcist
    Reno, NV
    86, would have loved a solid axle but couldn't pass this one up.
  11. Nov 11, 2020 at 8:58 AM
    #651
    Dubiousveracity
    2018 TRDOR DCSB MT
    none
    It’s sweet. Had to pass up a sweet 85 a few years back. Still wishing I coulda made it work, same cream color but the extra cab. Had a really raggedy 85 many years ago.
    excorcist likes this.
  12. Nov 11, 2020 at 9:07 AM
    #652
    skee
    North Coast, CA
  13. Nov 11, 2020 at 10:21 AM
    #653
    MiamiFLA
    MiamiFLA Active Member
    2020 TRD Off Road
    My dealer said it was just a matter of ordering the Tundra ones $134 per. I went with the 16" Tacoma version.
    From my research...
    Tundra Wheel
    42601AF010
    16" wheels - Width: 7", Offset: +15mm, Backspacing: 4.5", Hub Bore Diameter = 106mm
    barretta likes this.
  14. Nov 11, 2020 at 1:48 PM
    #654
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    That's exactly how a Toyota pickup should look. It's going in my spank bank.
  15. Nov 11, 2020 at 5:05 PM
    #655
    excorcist
    Reno, NV
    I appreciate that! I had the factory steel wheels powder coated to match the "Toyota creme 557" paint. Hadn't seen anyone do it but I love how it looks. It's nice to have a vehicle that I am 110% happy with without endless "mods" its perfect how it is now imo.
    xxTacocaTxx and DJB1[QUOTED] like this.
  16. Nov 11, 2020 at 5:47 PM
    #656
    DJB1
    Dave
    SLC, UT
    That’s probably the coolest truck I’ve ever seen on TacomaWorld. Tan with white steelies looks glorious!
  17. Nov 12, 2020 at 8:07 PM
    #657
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    The FJ Cruiser wheels are 17 x 7.5 whereas I believe all the 16" steel wheels are 7" wide. Be aware that the aftermarket steel wheels don't have the provisions to run the OEM metal center caps. Also, be aware that the OEM metal caps and the SR5 steel wheel lug nuts don't play well together in terms of clearance. Lastly, the steel wheel center caps are pricey if you purchase them as FJ center caps, but these are the same center caps run on most Toyota steel wheels since the 1990's. I believe mine are re-pops (but they weren't explicitly called out as such) and shown as a T100 center cap. However, they're the same part number and same piece, at $15 / wheel less.
    As for why I went FJ over spare, I simply liked the larger size wheel since I wasn't planning on an aggressive AT tire as I'm only running these for winter. I wanted the industrial look and thought the proportions looked better in 17" than 16".
    barretta[QUOTED] likes this.
  18. Nov 12, 2020 at 8:23 PM
    #658
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Wood.
    DJB1[QUOTED] likes this.
  19. Nov 13, 2020 at 6:30 AM
    #659
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    Obviously not from the 80's, but I went the same route with my 3rd gen land yacht.
  20. Nov 13, 2020 at 12:49 PM
    #660
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    That looks great!
    xxTacocaTxx[QUOTED] and 69 Jim like this.
