Show Off Your Steel Wheels
Discussion in 'Wheels & Tires' started by DustStorm4x4, Dec 30, 2016.
  1. May 22, 2022 at 10:45 AM
    #801
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
    painted with carbon mist rustoleum.
    TacoGeeloor likes this.
  2. May 22, 2022 at 10:53 AM
    #802
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Real nice:thumbsup:
  3. May 25, 2022 at 9:13 AM
    #803
    nl_tacoma
    nl_tacoma Well-Known Member
    Newfoundland
    2018 Tacoma TRD Sport DCLB
    Looks great.
    I have winter steel wheels on my 2018 Sport. I think they're a set of the spare rims and look very similar to yours. Just wondering if those center caps would fit?
    Thanks.
  4. May 25, 2022 at 11:23 AM
    #804
    SCUfan117
    SCUfan117 Well-Known Member
    2021 DCSB TRD-OR 4x4 Cement
    Thanks!
    I believe the center caps I went with specifically clip into the OEM 17" FJ wheel (or same style) from the front. See some reference pics below for how they clip in. If your steelies have the notches in the center opening, I can't see why they wouldn't fit. If you have the 16" Tacoma spare wheels (with the oval hole), I haven't seen anyone running these center caps with those.
  5. May 26, 2022 at 5:46 AM
    #805
    nl_tacoma
    Newfoundland
    Gotcha. Thanks. My rims have a different center. Round without the indents. Sucks that Toyota doesn't have a center fthat fits spare steel wheels that a lot of us use for winter rims.
  6. May 26, 2022 at 8:39 AM
    #806
    SCUfan117
  7. May 26, 2022 at 5:57 PM
    #807
    69jbass
    69jbass Member
    I bought them from this seller directly, they had center caps for an extra $7.50 + free shipping. 4 new rims with caps to my door for like $320. Will post pics once I get tires and get them mounted.
  8. May 31, 2022 at 8:53 AM
    #808
    69jbass
    69jbass Member
    Is there anything special with these I need to consider regarding lug nuts on these steelies? Any standard Tacoma "acorn style" will work? Or not?
    like these?
    https://www.amazon.com/White-Knight...fix=black+tacoma+lug+nut+night,aps,53&sr=8-11
    https://www.amazon.com/dp/B07R127HM...0a93-49e0-a0ba-2e6682173334&s=automotive&th=1
  9. May 31, 2022 at 10:50 AM
    #809
    SCUfan117
    I went with spline drive style acorn nuts to avoid any clearance issues with my FJ center caps. I thought that a standard hex acorn nut may interfere when you're trying to loosen/tighten them with a socket (when you have the center caps on).
    The first link you posted (20 pack) is the right size and style, should work as long as you don't have any clearance issues. The second link you posted (4 pack) is the right size but the wrong style, you need the matching acorn style.
  10. May 31, 2022 at 11:05 AM
    #810
    69jbass
    69jbass Member
    Thanks so much!
    SCUfan117[QUOTED] likes this.
  11. May 31, 2022 at 1:12 PM
    #811
    69jbass
    69jbass Member
    One more question, why they come in 20 packs? Don't I need 24 for a tacoma? :)
  12. May 31, 2022 at 1:26 PM
    #812
    SCUfan117
    I think most hubs intended for use with steel wheels are 5 lugs (like for trailers or base model trucks), hence the 20 pack for 4 wheels. I bought a 20 pack and a 4 pack.
  13. May 31, 2022 at 2:28 PM
    #813
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    These are what I used assuming you just want standard hex lug nuts.
    https://www.amazon.com/dp/B00JNEBL66?ref_=cm_sw_r_cp_ud_dp_AVCFR7JAQA9WETF22YRE
    no issues with the FJ center caps on mine.
  14. Jun 1, 2022 at 6:40 PM
    #814
    TacoHilux
    TacoHilux Well-Known Member
    Ben
    2009 tacoma access cab 4x4
    Here's are my steelies with a new pair of Yokohama Geolandar G003 255/85/16 tires. It's perfect now! 61D6B121-DFFD-4541-8348-6F8B99611E83.jpg
  15. Jun 3, 2022 at 6:45 PM
    #815
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    Those tires just look so good on those wheels.:thumbsup:
    TacoHilux[QUOTED] and 69 Jim like this.
  16. Jun 3, 2022 at 8:17 PM
    #816
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    Yup, perfect. Nice job:thumbsup:
    TacoHilux[QUOTED] likes this.
  17. Jun 8, 2022 at 7:10 PM
    #817
    Inbred
    Inbred Well-Known Member
    Phinnius
    2nd generation euphoria
    Just put on a set of 16" steelies. They're the spare rims with the much coveted double oval. Why settle for one oval when you can have two? As an oval-shaped small rock collector these are great when using as a filter to separate out oval stones and rocks I find along the trail. Bought them in black and had them powder coated an off white. For those wondering, the TPMS sensors are Denso 550-0103 and they worked perfectly. I went from the factory alloy rims and original 265/65/17 GrandTrek AT20's to 245/75/16 Micheline LTX M/S's. One thing I learned is that the powder coating process added mass to the wheels' axle hole making them tough to get on. Was like trying to get a small wedding ring on the finger of a three hundred pound woman. I took them to a Road Force Wheel balancing shop and them cats said they were well balanced to begin with. Very little weight was needed.
    It may just be phantom pain, but I seem to be able to notice the added weight while driving. Little bit sluggish. Oh well, form over function!
  18. Jun 10, 2022 at 2:00 PM
    #818
    69jbass
    69jbass Member
  19. Jun 14, 2022 at 6:36 AM
    #819
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Those black Steelies look sooo good on your black taco
    :yes:
    phreddyfoo and 69jbass[QUOTED] like this.
  20. Jul 27, 2022 at 9:42 AM
    #820
    EcoVntr
    EcoVntr New Member
    2019 Tacoma TRD
    Been looking for a new 17" steel spare wheel for a 2019 Tacoma. When calling around for possible Toyota wheels, I get the following two part numbers: 4261135430 (specifically for a 4 Runner) and 42601AD050 (for the Tacoma). Could anyone explain the difference between the two wheels?
    Thanks for any input.
