Show Off Your Steel Wheels
Discussion in 'Wheels & Tires' started by DustStorm4x4, Dec 30, 2016.
  1. Dec 15, 2022 at 8:30 PM
    #861
    Blue-steel
    Blue-steel Well-Known Member
    wow this is paint and not powdercoat?
    DustyMcTaco and fatz[QUOTED] like this.
  2. Dec 16, 2022 at 5:47 AM
    #862
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    They are the same lug pattern, but I don't know about center bore. What steel wheels do you have? If they're OEM Toyota and have the notches for center caps, you have some options.
  3. Dec 16, 2022 at 7:21 AM
    #863
    nl_tacoma
    nl_tacoma Well-Known Member
    Newfoundland
    2018 Tacoma TRD Sport DCLB
    Oh. Never thought about the center bore. My idea was just to use the GM style center.
    I have OEM Toyota rims. I believe they are the same as the spare tire rim so no notches.
  4. Dec 16, 2022 at 1:59 PM
    #864
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Oh okay. Without the notches I don’t have a great answer for centers. I’m curious what you might be able to get to work.
  5. Dec 19, 2022 at 6:58 AM
    #865
    ToughTaco99
    ToughTaco99 Well-Known Member
    Jerry
    1999 White Tacoma Base
    Exhaust
    Stock 14’s. Trying to get away from a 14”. Tires are impossible to find around here.
  6. Dec 19, 2022 at 8:46 AM
    #866
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    15-inch may be a consideration. Plenty of steel options in 5-114.3 and 205/70R-15 may be easier for you to source locally.
    ToughTaco99[QUOTED] likes this.
  7. Dec 19, 2022 at 9:20 AM
    #867
    ToughTaco99
    Jerry
    Exhaust
    Thanks for the info. I do like the 17” steelies from a FJ but they’re 6 lug. Seems everything I like is either 5x5 or 6 lug.
  8. Dec 20, 2022 at 5:45 AM
    #868
    Discount Tire
    Arizona, USA
    Parksareforever likes this.
  9. Feb 10, 2023 at 10:19 AM
    #869
    invisiblemandrew
    invisiblemandrew New Member
    andrew
    nyc / so-cal
    23 TuRD, 22 RAVh, Chevrolegs
    Steamshifters, Gungulators, Turbo nozzles.
    swapped to 17 steelz. off to find a spare!
  10. Feb 10, 2023 at 1:38 PM
    #870
    WrappedTaco
    WrappedTaco Well-Known Member
    J
    Ontario, Canada
    2003 Tacoma Regular Cab Prerunner
    3M Wrap 2 inch Bushwacker flares 2" Pro Comp AAL Bilstein 5100 rear 2" Spacers up front(for now) 31 x 10.5 / 15 tires PlastiDipped OEM 15" Steelies
    Dont have a pic of them on the truck yet. Original 15" steelies that the PO painted dark grey. Picked up a set of barely used LT235/75r15 Laufenn triple peak rated tires at the wreckers.
  11. Feb 20, 2023 at 7:39 AM
    #871
    agent304
    agent304 Member
    2020 SR
    Done for now. not sure whether to save for re-gear or just get it tuned.
  12. Feb 20, 2023 at 3:39 PM
    #872
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Looks good! Mine drove like a new truck after the tune.
    Unless you went up several tire sizes or made any drastic changes I think a tune would be all you need.
    agent304[QUOTED] likes this.
  13. Feb 22, 2023 at 6:17 AM
    #873
    agent304
    agent304 Member
    2020 SR
    talked to a guy about kdmax tune yesterday. will have that done in the next month. $400.
    Road_Warrior likes this.
  14. Feb 24, 2023 at 5:57 AM
    #874
    brev
    brev Member
    Hi all,
    I am looking at purchasing some 17" steel wheels for my 3rd gen SR. I see Toyota sells (at least) two similar versions, is the only difference the rim width? Do they both accept the FJ center caps? I will be running 235 / 245 width tires.
    1) #4261135330 - fits FJ cruiser 17x7.5
    2) #4261135400 - fits 4runner 17x7
    How well does the factory powder coat hold up?
    Thanks!
  15. Feb 24, 2023 at 7:25 AM
    #875
    agent304
    agent304 Member
    2020 SR
    brev and fatz like this.
  16. Feb 24, 2023 at 10:34 AM
    #876
    brev
    brev Member
    Thanks for the link!
  17. Mar 21, 2023 at 9:10 PM
    #877
    TuesdayTaco76
    TuesdayTaco76 Well-Known Member
    Moochacho
    California… thanks for leaving
    23 Tacoma TRD OR SB CB (chrome bumper✊)
    Still all in my head… but I’m keeping the chrome bumper!
    So today I had a blowout and had to throw on my spare and was like “damn girl, look at you!” Was way stoked on the look. I know a lot of you are running the old FJ’s but is there an oem 16 inch that Toyota still makes that looks like the spare… or can I use a set of the spare rims? BFF4C3E1-4383-4B55-964D-B3CEB22CF9EA.jpgCE0D8AFB-14F3-4362-A5F5-A68930C24561.jpg
  18. Mar 21, 2023 at 10:46 PM
    #878
    SCUfan117
    SCUfan117 Well-Known Member
    2021 DCSB TRD-OR 4x4 Cement
    To my knowledge, the only 16-inch OEM steel wheel with the circular hole pattern for the Tacoma is the OEM spare steel wheel, with the oval slot (Toyota P/N: 42601-AD030). The spare steel wheel is a full size spare and so it's perfectly okay to use full time, which many people do (i.e. some run their alloys during the summer with all-seasons and a separate steelie set in the winter with snow tires). If you wanted to bump up to a 17-inch OEM steel wheel, the most popular option is the Toyota FJ ones (Toyota P/N: 42611-35330).
    **I'm not 100% that that's the P/N for the 16-inch steel wheel, but I think that's it.
    ***Just know that you'll also have to get a set of acorn style lug nuts for the steel wheels, as they have a conical seat where the alloys have a flat seat.
  19. Mar 21, 2023 at 11:15 PM
    #879
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Correct part # for OEM 16-inch steel spare. @TuesdayTaco76 I quoted your comment in the 'what' thread.
  20. Mar 22, 2023 at 4:30 AM
    #880
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Yup. If you dig through this thread I think there's some in it that do just that. There was a pair of them for free in the classifieds on this site the other day.
